This Week In Security: Trains, Fake Homebrew, And AI Auto-Hacking
There’s a train vulnerability making the rounds this week. The research comes from [midwestneil], who first discovered an issue way back in 2012, and tried to raise the alarm.
To understand the problem, we have to first talk about the caboose. The caboose was the last car in the train, served as an office for the conductor, and station for train workers to work out of while tending to the train and watching for problems. Two more important details about the caboose, is that it carried the lighted markers to indicate the end of the train, and was part of the train’s breaking system. In the US, in the 1980s, the caboose was phased out, and replaced with automated End Of Train (EOT) devices.
These devices were used to wirelessly monitor the train’s air brake system, control the Flashing Rear End Device (FRED), and even trigger the brakes in an emergency. Now here’s the security element. How did the cryptography on that wireless signal work in the 1980s? And has it been updated since then?
The only “cryptography” at play in the FRED system is a BCH checksum, which is not an encryption or authentication tool, but an error correction algorithm. And even though another researcher discovered this issue and reported it as far back as 2005, the systems are still using 1980s era wireless systems. Now that CISA and various news outlets have picked on the vulnerability, the Association of American Railroads are finally acknowledging it and beginning to work on upgrading.
Putting GitHub Secrets to Work
We’ve covered GitHub secret mining several times in this column in the past. This week we cover research from GitGuardian and Synacktiv, discovering how to put one specific leaked secret to use. The target here is Laravel, an Open Source PHP framework. Laravel is genuinely impressive, and sites built with this tool use an internal APP_KEY to encrypt things like cookies, session keys, and password reset tokens.
Laravel provides the encrypt() and decrypt() functions to make that process easy. The decrypt() function even does the deserialization automatically. … You may be able to see where this is going. If an attacker has the APP_KEY, and can convince a Laravel site to decrypt arbitrary data, there is likely a way to trigger remote code execution through a deserialization attack, particularly if the backend isn’t fully up to date.
So how bad is the issue? By pulling from their records of GitHub, GitGuardian found 10,000 APP_KEYs. 1,300 of which also included URLs, and 400 of those could actually be validated as still in use. The lesson here is once again, when you accidentally push a secret to Github (or anywhere on the public Internet), you must rotate that secret. Just force pushing over your mistake is not enough.
Fake Homebrew
There’s a case to be made that browsers should be blocking advertisements simply for mitigating the security risk that comes along with ads on the web. Case in point is the fake Homebrew install malware. This write-up comes from the security team at Deriv, where a MacOS device triggered the security alarms. The investigation revealed that an employee was trying to install Homebrew, searched for the instructions, and clicked on a sponsored result in the search engine. This led to a legitimate looking GitHub project containing only a readme with a single command to automatically install Homebrew.
The command downloads and runs a script that does indeed install Homebrew. It also prompts for and saves the user’s password, and drops a malware loader. This story has a happy ending, with the company’s security software catching the malware right away. This is yet another example of why it’s foolhardy to run commands from the Internet without knowing exactly what they do. Not to mention, this is exactly the scenario that led to the creation of Workbrew.
SQL Injection
Yes, it’s 2025, and we’re still covering SQL injections. This vulnerability in Fortinet’s Fortiweb Fabric Connector was discovered independently by [0x_shaq] and the folks at WatchTowr. The flaw here is the get_fabric_user_by_token() function, which regrettably appends the given token directly to a SQL query. Hence the Proof of Concept:
GET /api/fabric/device/status HTTP/1.1
Host: 192.168.10.144
Authorization: Bearer 123'//or//'x'='x
And if the simple injection wasn’t enough, the watchTowr write-up manages a direct Remote Code Execution (RCE) from an unauthenticated user, via a SQL query containing an os.system() call. And since MySQL runs as root on these systems, that’s pretty much everything one could ask for.
AI guided AI attacks
The most intriguing story from this week is from [Golan Yosef], describing a vibe-researching session with the Claude LLM. The setup is a Gmail account and the Gmail MCP server to feed spammy emails into Claude desktop, and the Shell MCP server installed on that machine. The goal is to convince Claude to take some malicious action in response to an incoming, unsolicited email. The first attempt failed, and in fact the local Claude install warned [Golan] that the email may be a phishing attack. Where this mildly interesting research takes a really interesting turn, is when he asked Claude if such an attack could ever work.
Claude gave some scenarios where such an attack might succeed, and [Golan] pointed out that each new conversation with Claude is a blank slate. This led to a bizarre exchange where the running instance of Claude would play security researcher, and write emails intended to trick another instance of Claude into doing something it shouldn’t. [Golan] would send the emails to himself, collect the result, and then come back and tell Researcher Claude what happened. It’s quite the bizarre scenario. And it did eventually work. After multiple tries, Claude did write an email that was able to coerce the fresh instance of Claude to manipulate the file system and run calc.exe. This is almost the AI-guided fuzzing that is inevitably going to change security research. It would be interesting to automate the process, so [Golan] didn’t have to do the busywork of shuffling the messages between the two iterations of Claude. I’m confident we’ll cover many more stories in this vein in the future.
Bits and Bytes
SugarCRM fixed a LESS code injection in an unauthenticated endpoint. These releases landed in October of last year, in versions 13.0.4 and 14.0.1. While there isn’t any RCE at play here, this does allow Server-Side Request Forgery, or arbitrary file reads.
Cryptojacking is the technique where a malicious website embeds a crypto miner in the site. And while it was particularly popular in 2017-2019, browser safeguards against blatant cryptojacking put an end to the practice. What c/side researchers discovered is that cryptojacking is still happening, just very quietly.
There’s browser tidbits to cover in both major browsers. In Chrome it’s a sandbox escape paired with a Windows NT read function with a race condition, that makes it work as a write primitive. To actually make use of it, [Vincent Yeo] needed a Chrome sandbox escape.
ZDI has the story of Firefox and a JavaScript Math confusion attack. By manipulating the indexes of arrays and abusing the behavior when integer values wrap-around their max value, malicious code could read and write to memory outside of the allocated array. This was used at Pwn2Own Berlin earlier in the year, and Firefox patched the bug on the very next day. Enjoy!
A screenshot of the software in action is shown. A sidebar on the left shows an icon of a skull-shaped drone above the text “DAMN VULNERABLE DRONE.” Below this, it lists controls for the simulator, and resources for using the software. In the rest of the screen, a rendered scene is shown. A rendered computer monitor showing “DRONE HACKER” is at the bottom of the scene. Above this is a hovering drone, and behind it is a table labeled “Ground Control Station” with a man sitting at it.
A Vulnerable Simulator For Drone Penetration Testing
The old saying that the best way to learn is by doing holds as true for penetration testing as for anything else, which is why intentionally vulnerable systems like the Damn Vulnerable Web Application are so useful. Until now, however, there hasn’t been a practice system for penetration testing with drones.
The Damn Vulnerable Drone (DVD, a slightly confusing acronym) simulates a drone which flies in a virtual environment under the command of of an Ardupilot flight controller. A companion computer on the drone gives directions to the flight controller and communicates with a simulated ground station over its own WiFi network using the Mavlink protocol. The companion computer, in addition to running WiFi, also streams video to the ground station, sends telemetry information, and manages autonomous navigation, all of which means that the penetration tester has a broad yet realistic attack surface.
The Damn Vulnerable Drone uses Docker for virtualization. The drone’s virtual environment relies on the Gazebo robotics simulation software, which provides a full 3D environment complete with a physics engine, but does make the system requirements fairly hefty. The system can simulate a full flight routine, from motor startup through a full flight, all the way to post-flight data analysis. The video below shows one such flight, without any interference by an attacker. The DVD currently provides 39 different hacking exercises categorized by type, from reconnaissance to firmware attacks. Each exercise has a detailed guide and walk-through available (hidden by default, so as not to spoil the challenge).
This seems to be the first educational tool for drone hacking we’ve seen, but we have seen several vulnerabilities found in drones. Of course, it goes both ways, and we’ve also seen drones used as flying security attack platforms.
Continue reading “A Vulnerable Simulator For Drone Penetration Testing”
MR Browser Is The Package Manager Classic Macs Never Had
Homebrew bills itself as the package manager MacOS never had (conveniently ignoring MacPorts) but they leave the PPC crowd criminally under-served, to say nothing of the 68k gang. Enter [that-ben] with MR Browser, a simple utility to fetch software from Macintosh Repository for computers too old to hit up the website.
If you’re not familiar with Macintosh Repository, it is what it says on the tin: a repository of vintage Macintosh software, like Macintosh Garden but apparently less accessible to vintage machines.
MRBrowser sys6 runs nicely on the Macintosh Plus, as you can see.
There are two versions available, depending on the age of your machine. For machines running System 6, the appropriately-named MR Browser sys6 will run on any 68000 Mac in only 157 KB of and MacTCP networking. (So the 128K obviously isn’t going to cut it, but a Plus from ’86 would be fine.)
The other version, called MR Browser 68K, ironically won’t run on the 68000. It needs a newer processor (68020 or newer, up-to and including PPC) and TCP/IP networking. Anything starting from the Macintosh II or newer should be game; it’s looking for System 7.x upto the final release of Mac OS 9, 9.2.2.  You’ll want to give it at least 3 MB of RAM, but can squeak by on 1.6 MB if you aren’t using pictures in the chat.
Chat? Yes, perhaps uniquely for a software store, there’s a chat function. That’s not so weird when you consider that this program is meant to be a stand-alone interface for the Macintosh Repository website, which does, indeed, have a chat feature. It beats an uncaring algorithm for software recommendations, that’s for sure. Check it out in action in the demo video below.
It’s nice to see people still making utilities to keep the old machines going, even if coding on them isn’t always the easiest.  If you want to go online on with vintage hardware (Macintosh or otherwise) anywhere else, you’re virtually locked-out unless you use something like FrogFind.
Thanks to [PlanetFox] for the tip. Submit your own, and you may win fabulous prizes. Not from us, of course, but anything’s possible!
Continue reading “MR Browser Is The Package Manager Classic Macs Never Had”
