Reverse Engineering A Robot Mower’s Fence
There are a variety of robot mower systems on the market employing different navigation methods, and [Eelco] has the story of how one of these was reverse engineered. Second hand Roomba lawnmowers kept appearing for very low prices without the electronics driving the buried-wire fence that keeps them from going astray. The story of their reverse engineering provides us with a handy insight into their operation.
The wire fence is a loop of wire in the ground, so it was modeled using a few-ohm resistor and the waveform across it from a working driver captured with an oscilloscope. The resulting 3 kHz waveform surprisingly to us at least doesn’t appear to encode any information, so it could be replicated easily enough with an ESP32 microcontroller. An LM386 audio amplifier drives the loop, and with a bit of amplitude adjustment the mower is quite happy in its fake fence.
Robot mower hacking has become quite the thing around here.
22 thoughts on “Reverse Engineering A Robot Mower’s Fence
      1. The base station for one mower is rarely compatible with another mower so you’d replace that at the same time but re-use the buried wire.
        I once blew up a base station by reversing polarity while swapping the mains power supply for a solar panel and battery. In my defence the wires were red and blue, why was blue positive? I called the manufacturer and said I wanted to buy a replacement base station but they wouldn’t sell me one even with proof of purchase “to reduce theft”. The only way to get a new one was to buy one bundled with a mower.
        So be very wary of a mower without a base station both because it might be stolen and you might not be able to use it.
      1. The article appears to show a distorted (looks like it’s generated by an H bridge and smoothed with passives) 3kHz sawtooth with no information (in the information theory sense) embedded in it, so most likely could be replaced with a simple signal generator. And that kind of makes sense, a sawtooth has phase information that could help reduce interference from nearby loops as long as they are all connected in the same direction. That’s just from their description, maybe the code shows some modulation that isn’t mentioned in the description. Or did you spot something I missed @pelrun?
  1. I picked up a Husqvarna version last fall and it ran beautifully through the spring until my neighbor shorted out the fence and destroyed it in a couple places by putting up his own fence to keep the deer away from his tomatoes. I’ve tried getting it working a few times over the summer, but I haven’t had the time to dig up the entire fence that I took about two weeks to get right the first time. And I really wish I could eliminate the fence completely and just use GPS or something.
    One of these weekends I got to borrow a signal generator from an electrician friend and see if I can find the break. I have an unusual shaped yard and there’s lots of turns so I’m hoping that will help me from having to dig up everything again.
    1. Why not build a receiver circuit and detect the signal?
      Half of the circuit should be detectable up until approximately the break point.
      An old AM radio could potentially work too, although that’s easier to test on a fully working setup first.
  2. Looking at the waveform that the author super-faithfully reproduced with his wave table and ESP32 DAC, my intuition tells me that the original hardware is even simpler, maybe just a pulse generator, with the sine wave “on the wire”derived not from an analog source, but a cheap low-pass filter. The waveform asymmetry is intriguing though.
Leave a Reply to JanCancel reply
