Weaving Circuits From Electronic Threads
A person's hand wearing a black glove is shown in the right part of the image, making a series of gestures. A representation of a hand mimics those motions on a laptop screen.
Though threading is a old concept in computer science, and fabric computing has been a term for about thirty years, the terminology has so far been more metaphorical than strictly descriptive. [Cedric Honnet]’s FiberCircuits project, on the other hand, takes a much more literal to weaving technology “into the fabric of everyday life,” to borrow the phrase from [Mark Weiser]’s vision of computing which inspired this project. [Cedric] realized that some microcontrollers are small enough to fit into fibers no thicker than a strand of yarn, and used them to design these open-source threads of electronics (open-access paper).
The physical design of the FiberCircuits was inspired by LED filaments: a flexible PCB wrapped in a protective silicone coating, optionally with a protective layer of braiding surrounding it. There are two kinds of fiber: the main fiber and display fibers. The main fiber (1.5 mm wide) holds an STM32 microcontroller, a magnetometer, an accelerometer, and a GPIO pin to interface with external sensors or other fibers. The display fibers are thinner at only one millimeter, and hold an array of addressable LEDs. In testing, the fibers could withstand six Newtons of force and be bent ten thousand times without damage; fibers protected by braiding even survived 40 cycles in a washing machine without any damage. [Cedrik] notes that finding a PCB manufacturer that will make the thin traces required for this circuit board is a bit difficult, but if you’d like to give it a try, the design files are on GitHub.
[Cedrik] also showed off a few interesting applications of the thread, including a cyclist’s beanie with automatic integrated turn signals, a woven fitness tracker, and a glove that senses the wearer’s hand position; we’re sure the community can find many more uses. The fibers could be embroidered onto clothing, or embedded into woven or knitted fabrics. On the programming side, [Cedrik] ported support for this specific STM32 core to the Arduino ecosystem, and it’s now maintained upstream by the STM32duino project, which should make integration (metaphorically) seamless.
One area for future improvement is in power, which is currently supplied by small lithium batteries; it would be interesting to see an integration of this with power over skin. This might be a bit more robust, but it isn’t first knitted piece of electronics we’ve seen. Of course, rather than making wearables more unobtrusive, you can go in the opposite direction.
6 thoughts on “Weaving Circuits From Electronic Threads
  1. I don’t know man, maybe its my inexperience with flex PCBs but it feels wrong to have the substrate bend and curl. Maybe it would be fine if encapsulated…?
    Still feels off though
    1. i figure it’ll go through an evolution
      last long enough to brag to your friends about it (i.e., to publish a research article)
      lasts until the end of the halloween party
      survives one wash maybe
      survives as well as anything
      Not sure what technology will clear that last hurdle but the only thing i know is i will find out about it from it being proven in practice, not from any first principles about its construction :)
      1. @shinsukke + @Greg A:
        Hi from the FiberCircuits team!
        Indeed, encapsulation changes everything:
        Check the paper for more details but silicon waterproofing is kept robust with the over-braiding, up to 40 washing cycles ;)
        Thanks for the comments!
        1. over-braiding with silicone sounds to me like a composite to me, and exactly the sort of technology i’d believe might someday clear the hurdle :) 40 washes is impressive!
  2. What I’d like to know is who can make pcbs that take small bga or wlcsp chips. I’ve got a few csp-18 stm32g0’s of like to play with.
    1. Thanks for the comment!
      The paper compared a couple of manufacturers.
      If course they will improve over time, but the one that worked the best for this particular project was: isource-asia.com
Leave a Reply to Greg ACancel reply
