Speech Synthesis On A 10 Cent Microcontroller
Speech synthesis has been around since roughly the middle of the 20th century. Once upon a time, it took remarkably advanced hardware just to even choke out a few words. But as [atomic14] shows with this project, these days it only takes some open source software and 10-cent microcontroller
The speech synth is implemented on a CH32V003 microcontroller, known for its remarkably low unit cost when ordered in quantity. It’s a speedy little RISC-V chip running at 48 MHz, albeit with the limitation of just 16 KB of Flash and 2 KB of SRAM on board.
The microcontroller is hooked up to a speaker via a simple single-transistor circuit, which allows for audio output. [atomic14] first demonstrates this by having the chip play back six seconds of low quality audio with some nifty space-saving techniques to squeeze it into the limited flash available. Then, [atomic14] shows how he implemented the Talkie library on the chip, which is a softwarehttps://www.youtube.com/watch?v=RZvX95aXSdM implementation of Texas Instruments’ LPC speech synthesis architecture—which you probably know from the famous Speak & Spell toys. It’s got a ton of built in vocabulary out of the box, and you can even encode your own words with some freely available tools.
We’ve seen [atomic14] tinker with these chips before, too.
62 thoughts on “Speech Synthesis On A 10 Cent Microcontroller
    1. C64 did not cost 10 cents :-)
      And BTW S.A.M. reciter on C64 was pretty advanced and did not need that much memory, there was still lot of free space for BASIC programs with new SAY command.
      I remember writing number guessing game for it in BASIC as a kid and my parents did understand what it is saying and could play it :-) And BTW it was not in english, the built in phoneme syntax was good for most languages.
      1. Yes, sure. But come on, 48 MHz! 😃
        And merely ~2048 ASCII characters of random access memory!
        A blank text file alone occupies 512 Bytes on a FAT medium.
        That’s like combining an AMD Ryzen with 512 KB of Conventional Memory as RAM..
        All the processing power in the ALU and SIMDs but then
        there’s no RAM for sophisticated applications to put all the power to good use! 😢
        1. A blank text file alone occupies 512 Bytes on a FAT medium.
          It does not. That’s just the reserved allocation unit due to the file system. The file system is just a map of where the data is, not the data itself. The file system could pretend it has allocated 512 bytes for the file even if it could actually only store e.g. the first 128 bytes.
          1. Hi, thanks. I meant to say it occupies the smallest allocation unit, which is 512 Bytes.
            That an “blank” file contains not 512 Bytes of characters is understandable, I thought.
          2. It can be understood to say that just the file allocation entry takes 512 bytes to make a blank file, which is not the case.
        2. That’s like combining an AMD Ryzen with 512 KB of Conventional Memory as RAM.
          Clock speed doesn’t say anything about what computing resources are available. This CPU is a RISC-V2A with a RV32EC instruction set, which has a reduced number of registers to use among other simplifications. It’s not a particularly powerful CPU.
          1. Then again, the 6502 was an 8-bit processor with what, three, user registers and ran 1-2 MHz?
            The fact that the modern RISC chip is a 32-bit processor and has 32-bit commands make the RAM and flash less capable.
          2. True, but that still does not make this core comparable to an AMD Ryzen in comparison to other microcontrollers.
            If you wanted to make the point, you’d look at something like a SAMD21 running at 48 MHz in an Arduino board. Those have 32KB SRAM, but they also cost $1-5 so that’s 10-50 times more.
        3. The ch32 has different flavours. If you need more RAM, take a bigger one.
          The RISCV32 core itself is cheap and small, the RAM makes it expensive.
    2. Moore’s law reality. They made transistors inside the chip smaller to make it cheaper. But that also made it faster. And (spoiler) with more leakage, the deep sleep consumption of that chip isn’t that good.
      1. Yes, but 64 KB of RAM were affordable 40 years ago!
        Why can’t this thing have 32 KB of internal SRAM, at least?
        After 40 years of progress and in these times of 64 GB RAM DDRx modules and SD cards in the TB range.
        The way it is now, it barely beats an Atari 2600. 🥲
        1. Because most embedded applications running on a chip with only a few I/O lines simply do not need that much RAM. Adding unnecessary RAM would increase transistor count, chip size and power consumption.
          1. Hi, what I mean is the relation, the balance.
            The computational power is not nearly in balance with the RAM expansion.
            Here you have an advanced RISC-V architecture that barely has the memory capacity to play tic-tac-toe, yet alone chess.
            This is a waste of an otherwise precious creation of human intellect.
            I feel so sad for this little piece of silicon. It’s been restricted for no good reason.
            It’s like having a 10 HHz Pentium IV processor that has a couple of shift registers for memory and a paper punch card reader for mass storage. So sad.
          2. The computational power is needed for fast signal processing, which doesn’t necessarily need much RAM. Something like a FIR filter, which only needs a few hundred bytes for a buffer, but it has to run fast in order to process things like audio in real time.
          3. For example, if you want to push samples through at a rate of 96 kHz and your CPU is 48 MHz, you can only afford to spend 500 cycles on computing each sample.
            That sets the limit of how much RAM you can afford to access per each sample, because accessing memory takes clock cycles. You would be addressing less than 500 bytes of RAM because you have to do something with the data as well.
            For static data, that can go into flash memory.
          4. Except it is in balance. It is a low cost small MCU. It is only really meant for doing one or two things at a time and is very unlikely to be used to drive things like displays, although for small displays like the small OLED modules it might cope.
            Not every application is the same and needs lots of RAM. Plenty of algorithms for control that need a lot of compute wouldn’t need that much RAM, same with digital signal processing.
            Also their goal was to make a small, low cost chip, they lose nothing by letting it run at high speeds. Would you prefer they take the same chip and limit it to 2 MHz just so it seems more in balance to you? If you don’t need 48 MHz then reduce the clock speed.
      2. I mean, I see it this way:
        By adding a little bit more of RAM and making it 5 or 10 cent more expensive it becomes useful.
        Without it, silicon material is wasted for no good reason. And 10 cents are simply lost.
        I don’t get the profits thinking. If you do produce something, it should be functional.
        Just producing it to beat the competition is unlogical from a functional point of view.
        It’s better to save up money and buy something more expensive that functions properly (at very least) and doesn’t cause headaches.
        Because headaches and wasted human lifetime are more “expensive” than a bit of comparitively worthless money. IMHO. 🤷‍♂️
        1. Just buy a STM32C011 or CH32V006 or PY32F003 instead?
          This is pointless criticism, because there are plenty of applications for devices as small as this.
          There are even still applications for $0.03 8-bit MCUs. Every took one of those battery operated lights apart?
          1. Hi. It’s an opinion, not a criticism. And money isn’t my problem here.
            It’s not about me and not about me wanting something.
            It’s about restricting an precious piece of technology from a philosophical point of view.
            It could do so much more if it was reasonably being designed.
            My heart bleeds a little bit if I see such poor “creations”.
            That being said, the project itself is well done. I never meant to criticise that.
          2. It could do so much more
            Like what? MCUs like this with limited IO generally do not even need to handle that much data. Their main point is just to get whatever simple thing they do done quickly, so the device can go back to sleep to conserve batteries.
          3. For example, according to the data sheet the device consumes between 1-9 mA running depending on how many peripherals you have in use and what clock options and voltages you use. It goes down to 0.4 mA in sleep mode. With suitable power gating, that can go down to nanoamps.
            Now, if you wish to create a battery powered device, your realistic goal is in the low microamps, so you should use power gating timers to get there. Suppose your target is 10 microamps and we assume 7 mA at 48 MHz running: that means the device can only operate for 1.4 milliseconds per second. Your budget for computation is therefore about 68,500 clock cycles per second.
            If you wish the device to wake up and check some IO and do some action every 20 milliseconds for something like checking if a button is being pressed, your budget for computation per operation drops to just 1371 clock cycles. That includes booting up the MCU, checking the IO, doing some simple calculations, setting the outputs and then dropping power off. You really can’t do much in that time that would demand any amount of RAM because you don’t have enough time to process it. In the case outlined, even 2k would be totally overkill because you simply don’t have enough clock cycles to fill it with data and process it.
            Speed is the key. This is why these simple MCUs are “ridiculously” fast compared to the amount of memory they have. They’re intended for applications where the MCU is mostly doing nothing, so it can remain turned off.
          4. @Dude I see it differently. If the chip was constantly running at, say, 500 KHz it wouldn’t need to wake up/sleep all time, require little power but could be left standby the whole time and react in an emergency.
            Being awake at low operating frequency would reduce current spikes on the power line and the wear inside the chip due to thermal changes would be less.
            Electronics ages through on/off cycles, I learned. It’s better if it remains on same temperature for a long time.
            But anyway, I start to realize that people here have an point of view that’s 180° degree different to mine. But that’s okay, diversity is good. 🙂
          5. If the chip was constantly running at, say, 500 KHz it wouldn’t need to wake up/sleep all time, require little power
            The chip can be clocked down to 750 kHz but then it would be consuming a constant 1.1 mA in active idle mode even with all the peripherals off, just running a NOP loop and checking for the exit condition. That’s a hundred times more than what we want.
            Maintaining the SRAM state and registers, and running the rest of the circuitry including the sleep timer watchdog consumes about 400 microamps regardless of whether the CPU is running. This is why we need to use an external power gating timer to actually shut it down when we’re not using it. Sometimes a simple soft-on button is used where a button press restores power, and then the CPU pulls the power down until the next button press.
            There are chips with better sleep behavior going down to tens of microamps, but they have more elaborate circuitry to shut down power internally. Essentially, a second small MCU on the same chip that boots up the bigger CPU when action is required. With this simple 10 cent chip they’ve omitted that.
          6. Being awake at low operating frequency would reduce current spikes on the power line and the wear inside the chip due to thermal changes
            The chip consumes 50 milliwatts at worst. Thermal changes are simply not an issue. If your power source struggles to provide a couple milliamps without sagging, you have other issues and inadequate decoupling in your circuit design.
          7. could be left standby the whole time and react in an emergency.
            Define “emergency”. In the case outlined, the MCU wakes up and can react every 20 milliseconds or 50 times a second. We could reduce that to 10 milliseconds at the expense of doubling the current consumption. How fast do you need it to react?
          1. Hi! Programming in an IDE of a high-level language comes to mind, for example.
            For example: Even if you’d try to build a modern and flexible morse code beacon,
            you would need to encode the whole morse code alphabet.
            That’s a lot of dot/dash patterns to be held in RAM as some sort of, um, look-up table.
            Again, a flexible, programmable morse code beacon.
            You could hard-code the message in flash storage, of course, but that’s not the point here.
            (That relates to live rendering of 3D graphics vs using pre-rendered animations.)
            If it was, then the 1-Bit microcontroller (MC 14500) with its unique “result register” would do.
            Anyway, I’m not asking for megabytes of SRAM, of course.
            But 2KB in 2025 is really stingy, I think. It doesn’t do the chip’s core any justice.
            4 or better yet, 8 KB would been more generous, for example.
            If the chip was an 2 MHz model with a primitive instructions set, then 2 KB of SRAM would be more in balance to it, I think.
          2. Programming in an IDE of a high-level language comes to mind, for example.
            There is no limitation on that. The IDE is not running on the MCU. It’s just about optimization, and modern compilers are so good that you’re more likely to produce less efficient code if you try to code in assembly yourself.
            If you want to run scripting languages like Python on the MCU, you’re in the wrong ballpark.
            you would need to encode the whole morse code alphabet. That’s a lot of dot/dash patterns to be held in RAM
            Even if you wrote that down in ASCII as literal dots and dashes, you would only need about 156 bytes to store the lookup table. Not much at all. 2 KB is plenty here.
          3. Not to mention that the lookup table can go into flash memory, where you have 16 kB available, so you don’t need to waste RAM to hold static data.
        2. okay… so you have a problem with the fact that a 48MHz microcontroller has only 2k of RAM… you completely miss the point that it only costs 10 cents?!?! You completely miss the point that most applications do not require that much of RAM anyways!??! Yet you seem to be completely OK with the fact that it only has 8 pins of which two are reserved for power, so six IO-pins… why do you need more then 2K of RAM on a device with only 6 IO-pins?!? To be honest, I do not think the 2K is a restriction and for what it is and does it’s more than enough and in most cases it will be much more than needed. And for those rare occasions you do need more, shell out another 10 cents and get the bigger version.
          Regarding the project here, cool little project very inspirational, a nice explanatory video too.
          1. I think the implication is that because it’s 48 MHz it should be able to run DOOM or something. It’s totally missing the point of what these things are made for.
            Hi, no. I’m not missing it. I’m thinking that +/- 10 cents are less relevant, though.
            I’m not focused on products being cheap, but about them being usable.
            I’d like to respectfully point out that just because I have other priorities or point of views doesn’t automatically mean I’m dumb/mentally limited etc.
            See, let’s see it this way for once: You bind production capability of a factory to build artificially inferior chips that could been better spent,
            if the capacity was used to produce quite good chip for just a little bit more money (say 5-8 cents more, so the specs was changed so it can have 4, 6, 8 or 16 KB of SRAM).
            Because RAM for living application code and short time storage is the most limiting factor.
            “Fast but dumb” doesn’t make sense in control applications, I think.
            Even a coffee making machine has to remember different settings for different types of coffee.
            I “grew up” with the PIC16C84 and RAM often was the limiting factor, it caused headaches because programming had to be in
            ASM and had required clever workarounds.
            In the mid 90s, a RAM limit of 68 Bytes was equally silly like 2KB are now 35 years later.
            But back then it at least was understandable, given the technological limitations. The measuring unit still was micro metres rather than nano metres (micron, µm; that’s 1000 nm).
            If we consider the advancements in lithography, it would be a piece of cake to produce microcontrollers with a reasonable amount of RAM. For very little money.
            Because, higher integration levels (smaller sizes) do save the amount of raw material (molten sand) rather than requiring more.
            So if the expensive lithography machines are already here, already bought, going to smaller structures will increase the production.
            The yields are already good, the wafers are well utilized.
            Compared to say, 1995 when the PIC16F84 was new.
            Good point. They could (should) be multiplexed if needed.
            Basically, yes. Though I’d prefer Commander Keen. ;)
            What hurts a bit is seeing an advanced architecture like RISC-V to be abused for carrying out dumb tasks only.
            Sure, production is cheap. But from a point of human civilisation it’s still a shame.
            It’s like smashing a pretty mosaic window of a church with a baseball and a bat.
            Even if the the glass is just painted by a machine and produced en masse,
            and not built from individual pieces like in medival times, it still hurts seing this destruction happen.
            It’s not about the worth of the material, but about immaterial “loss”.
            The painted glass contains precious structures that had been created by human imagination.
            Just like the die structure of an Z80, 6502, PIC16C84 or ATtiny13.
            PS: I’m a bit baffled that no other person sees at least a little bit like this, to be honest.
            The world must have changed more than I had assumed.
            I remember times when people were astonished/amazed by technology and valued it.
            Reducing micro electronics to mere monetary units is something I can’t mentally comprehend.
            I mean, sure I do see how things are connected, but I have trouble understanding the priorities.
            If a project involves a small production run of a few dozen units, like it’s usual for hobby use,
            then spendind 50 cents more or less per microchip doesn’t financialy hurt anyone.
            And if it’s a big production, the cost can be given further to the customer.
            He/she doesn’t even notice if the product does cost $9.95 or $9.75 in the end.
            Because the seller/producer will rise the final price tag a lot anyway, to have sicjk profits.
            So production cost is covered, anyway.
            No matter if the chip used costs 10 cents, 25 cents or 100 cents.
          3. “Fast but dumb” doesn’t make sense in control applications, I think.
            A bar code for a coffee capsule is a handful of bytes, and that’s static data that doesn’t live in RAM but in flash memory anyways.
            How many different types of coffee do you want it to remember? Thousands?
          4. if it’s a big production, the cost can be given further to the customer.
            Or, the company could pocket the difference. 10 cents over a million units sold is $100k in profit.
          5. I’m a bit baffled that no other person sees at least a little bit like this, to be honest.
            That’s because you don’t seem to understand the scope or scale of the tasks you’re talking about. You seem to think that simple things are complicated and complicated things are simple.
          6. They could (should) be multiplexed if needed.
            Or, you could buy the bigger MCU that has more IO and more RAM, so you don’t need to increase the parts count and size of your circuitry.
          7. Joshua you are thinking on the scale of small production batches and single components. Yes if the MCU costs 10 cents more it might not be much extra cost, but what about every other component used? Those extra but unnecessary costs to get “better” components that don’t give any benefits in the intended application is just a waste.
            Looking at it from the other side, why would you use a relatively simple MCU with lots of RAM for a simple task where most of its RAM and resources are unused?
            If the product ends up limited by the MCU and it’s amount of RAM then that is a design issue.
          8. Also they wouldn’t make this if there wasn’t a market for it. Clearly there is a market for it because it is popular and sells a lot of units. A companies purpose is to make things their customers want and clearly their customers want this. Unless you know better than all their market research?
            The fact that it sells so well should also tell you something. Lots of people want it and don’t share the same views you do. Maybe 40 years ago this chip would be impressive but these days it is as simple and mundane as you can get so why should we revere it just because it is RISC-V and runs at 48 MHz? These are inanimate objects you know, basically just resources.
        3. It is useful as it is, for simple controlling tasks with little I/O.
          Don’t confuse general purpose microprocessors with gigabytes addressing, against simple microcontrollers. Yes the humble controller today has more CPU power than your dad’s C64, but is not designed to address large RAMs. It is a perfect fit to control your washing machine, toaster or whatnot with its internal 2kB RAM. But you would not make a BASIC homecomputer with it.
          1. Hi, thanks. That’s right, of course.
            Still, it reads a bit as if I would require a history lesson just because I see things from a different angle here. vy73s.
          2. PS: A toaster, yed. A washing machine is not a simple thing, though.
            Us men not familiar with household appliances maybe think so, but the algorithms for different washing programs aren’t unsophisticated, either.
            I dare to claim that a washing machine from ~1985 had an amibitious microcontroller board for its time.
            A sophisticated microcowave oven from 1997 had an LCD display with animations and more than 2KB of RAM, likely.
            Example: https://m.youtube.com/watch?v=UiS27feX8o0
            I wouldn’t mind if we would be talking about an 2 MHz chip with a very simple instructions set and a die with a few hundreds to thousand transistors.
            But even an 6502 CPU or MCS-48 microcontroller from the 1970s deserved better, I think.
            The 8i842 of late 70s already had 256 Bytes of RAM, which both was a limitation of its time and also a lot for its time (for on-chip-RAM).
            Not ideal, though. If the manufacturer had “today’s” technology (=technology of past 25 years) at the time the RAM could been 24, 32 or 64KB instead.
            If you program by hand in ASM, perhaps yes, I think.
            If you’re developing the application code using a full-fledged IDE and a high-level language like Basic, Pascal or Python, then it looks different.
            Those languages/compilers hold default values in memory for processing when the application code runs on the microcontroller.
            While I do appreciate ASM, it’s also a danger once complexity increases.
            Lots of if-then clauses and jumps, for example.
            In a full-fledged IDE, code can be written in a more clean fashion that can be managed more easily.
            A different example, for those more familiar with homebrew on PC:
            Turbo Pascal or QB45 on MS-DOS were such a case of a clean IDE with structured programming (no line numbers needed).
            I mention DOS environment, because DOS was used in embedded applications, often.
            And in DIY projects with electronics on a breadboard.
            Old XTs or 80186 single board computers could be used as controllers.
            And even here, the 64 KB limit per segment was a hurdle often.
            – 64 KB which seem so vast compared to 2 KB, by the way.
            COM files with that limit were quick and simple, but relocatable EXE files were very welcome.
            (DatalightbROM-DOS, for example, was used in embedded sector.)
          4. It is a perfect fit to control your washing machine, toaster or whatnot with its internal 2kB RAM.
            I just think that by 2025, such “low-end” chips should be given a reasonable amount of RAM.
            Not in the Megabytes range, but at least 24 or 32 KB of SRAM in 2025. For sake of the architecture’s dignity.
            So the RISC-V core can run applications that match its capabilities.
            The source material needed wouldn’t change because of this little change, either.
            I’m afraid that the 2 KB limit is the result of “market segmentation” of some sort, rather than technological reasons.
            The idea that castr*ted chips must exist for sake of different price points. Silly, IMHO.
          5. If you program by hand in ASM, perhaps yes, I think.
            You don’t need to do that. Modern high level compilers are perfectly good at optimizing for small MCUs.
            Python is an interpreted language, that’s a different deal entirely because you need the interpreter to run on the MCU to use it. It’s much too inefficient and slow to use on a small computer like this and would not run well.
            You would need to scale up to 256 kB to be effective, but it would still be slow, so the question is why would you? The answer is cross-compatibility between different MCUs, but then if you’re developing for a specific application you’re not dealing with any random MCU and can optimize for the actual hardware.
          6. Not in the Megabytes range, but at least 24 or 32 KB of SRAM in 2025.
            The jump up from small MCUs doing simple tasks and complicated tasks is a bigger jump in resource use than you seem to realize. For example, if you want to add a Bluetooth stack, that’s going to take 20-30 kB and that’s before you actually do anything with it.
            Just reading some buttons and outputting some bit streams to control something really doesn’t need tens of kilobytes of RAM. That’s what these things are made for.
            The argument for “dignity” is nonsense. What does that even mean?
          7. by 2025, such “low-end” chips should be given a reasonable amount of RAM.
            With RAM comes power consumption. Why should we increase power consumption without actually needing the RAM?
          8. Your options are not ASM or python. Python really has no place in MCUs such as this, it isn’t designed for them. You are looking at this from the wrong perspective.
            Python is too slow and inefficient, it is only really good for a few select things, even the big libraries used in python for data processing or machine learning are actually written in a compiled language because it is so much faster and more efficient.
            Going along your line of thinking why would you use something as bloated, slow and inefficient as python?
            The go to choice for the majority of MCUs is C and that is because it gets very close to assembly levels of performance with a relatively high level language (compared to ASM). Also in C the constant values are not stored in RAM, they are stored in flash, so your animations, washing machine cycles, etc would be stored in the 16 kB of flash, so that leaves the RAM for real time values like sensor readings and control loops and 2 kB is more than enough for that.
      3. 10 µA isn’t horrible, but it’s not going to run for years on a coin cell. It won’t be an issue for a device running from a larger battery though.
  1. I did something very similar few years ago using an ATtiny and an SPI flash for the samples. I used the data from the festival project (https://www.cstr.ed.ac.uk/projects/festival/) and log encoded (https://en.wikipedia.org/wiki/%CE%9C-law_algorithm) the samples. The sounds in the festival “voice” I used were encoded as digram transitions (eg. Hello would look something like [he][el][lo][ou]) so it was just a matter of concatenating the proper sounds together.
    My language (czech) required high sample rate (= more storage) though, because of the high frequency component of our softened sounds (žščř..) that most people do not know how to pronounce :D.
  2. Ah, memories of that General Instrument SP0256 chip from Radio Shack, wired up to a VIC-20. With all its 1 MHz and 3.5 kB of RAM, though that chip with its 2 kB of ROM did all the real work. That was a lot of fun.
    Hey, HaD, how about an article on Dennis Klatt, “Father of speech synthesis”?
    1. I used SAM (software automatic mouth) on my Atari 8 bit machines. Sounded robotic, but it was understandable and, required no extra hardware. I recall making a “hitchhikers guide” door that welcomed you on entry and thanked you for using it on your exit.
    2. My first ever computer project! So many hours of fun, I even bought a SPO256 and matching 3.12Mhz crystal a couple of years ago to recreate it.
  3. … now if only Radio Shack would suddenly come back to life just in order to have these 10c chips in stock … and knowledgeable salesmen (remember the rare breeds?) would know how to assemble those into a board AND help with programming … in a separate universe, perhaps (or in the backstreets of Shenzhen or Akihabara).
      1. I am in the US and shipping anything out of non-US countries is hit and miss at best. For now (until US Congress awakes from its idiotic slumber and starts representing average Sam’s interests, which, in the parallel Universe, happens a lot).
        Usual resellers on Amazon want three prices per. Temu seem to be shipping to the US still (so does Banggood), but it is unclear when it will arrive, before New Year or after.
  4. Incidentally, I recently started working on my own microcontroller speech synthesizer software project after more than 11 years. It first ran on an ATmega328p but soon (with some fat removed) ran on an ATtiny85 without much loss in audio quality. I was pleasantly surprised that it worked as well as it did on the ’85 since that MCU doesn’t have a multiplication instruction like the ‘328p does. And I think it still managed a respectable 16 kHz sample rate, which is good for producing that /s/ frication noise around 5 kHz or higher.
    But now I’m trying to clean up the code and fine tune the formant parameters and adding things like syllabic and prosodic stress so it sounds better. I’m also working on the English-to-phoneme translation rules (for a translator based on code from 1985 by John Wasser who frequents, or at least used to frequent, the Arduino forums). Right now I’m trying to think of a good optimization algorithm to generate a minimal set of rules from the 230 kiloword CMU pronouncing dictionary.
Leave a Reply to JoshuaCancel reply
