CCA Ethernet Cables: Not Up To Scratch, But Are They Dangerous?
If you’ve ever bought a suspiciously cheap Ethernet cable from an online listing, there’s a decent chance you’ve encountered Copper Clad Aluminum. Better known as CCA, it’s exactly what it sounds like—an aluminium conductor with a thin skin of copper deposited on the outside. Externally, cables made with this material look largely like any other, with perhaps the only obvious tell being that they feel somewhat lighter in the hand.
CCA is cheaper than proper copper cabling, and it conducts signals well enough to function in an Ethernet cable. And yet, it’s a prime example of corner-cutting that keeps standards bodies and professional installers up at night. But just how dangerous is this silent scourge, found lurking in so many network cabinets around the world?
Not Up To Scratch
CCA wire is typically made by wrapping an aluminium core with copper strip and then extruding it through a die. Credit: USPTO
Everything you need to know about CCA is in the name—it refers to an aluminium wire with a thin copper cladding, typically applied through a die extrusion process. The reasoning behind this exploits a real physical phenomenon called the skin effect, wherein higher-frequency AC signals tend to travel along the outer surface of a conductor. The idea goes that since most of the current moves through the outer copper skin layer anyway, the less-conductive aluminium core doesn’t unduly impact the wire’s performance. Using copper-clad aluminium wiring is, in theory, desirable because aluminium is much cheaper than copper, which can really add up over long cable runs. Imagine you’re wiring a building with with hundreds of miles of Ethernet cabling, all with eight conductors each—the savings add up pretty quickly.
There’s a problem with CCA cabling in these contexts, though. Due to prevailing cabling standards, any cable made with CCA is technically not even a real Ethernet cable at all. The relevant documents are unambiguous.
ANSI/TIA-568.2-D requires conductors in Category-rated cable to be solid or stranded copper. No other materials are acceptable, and thus CCA is explicitly excluded from use in Category cable applications. A cable with CCA conductors cannot legitimately carry a Cat5e, Cat6, or any related designation under any circumstances. Similarly, ISO/IEC 11801 has the same requirement. The U.S. National Electrical Code also states that conductors in communications cables, other than coaxial cable, shall be copper. This isn’t a suggestion or a best practice; it’s the letter of the code. Anything lesser is simply not allowed. Continue reading “CCA Ethernet Cables: Not Up To Scratch, But Are They Dangerous?” →
The Heat Island Effect Is Warming Up The AI Data Center Controversy
There’s been a lot of virtual ink spilled in environmental circles about the cooling water requirements of data centers, but less consideration of what happens with all the heat coming out of these buildings. Naturally, it’s going to warm the surrounding environment, but how much? Around 2 C (3.6 F) on average, and potentially much more than that, according to a recent study on the data heat island effect.
It’s common sense, of course: heat removed from the data center doesn’t go away. That heat might go into a body of water if one is available, but otherwise it’s out into the atmosphere to warm up everybody else’s day. In some places — like a Canadian winter — that might not be so bad. In others, where climate change and urban heat islands are cranking up the summertime temperatures, it very much could be. Especially if you’re in the worst-case scenario micro-climate described by the paper, which saw a predicted increase of 9.1 C (16 F).
Now, these results are theoretical and need to be ground-truthed, but anyone who has huddled next to the air-exchange unit of a large building for warmth knows there’s something to them. Unfortunately there don’t seem to be before-and-after measurements available for existing data-centers — AI or otherwise — to show exactly what their heat output is doing in the real world, but the urban heat island effect from all the dark asphalt in our cities is well known. Cooling paint and green roofs can help with that, but they won’t do much for the megawatts being pumped out to keep your cousin’s AI girlfriend online.
Some would argue that all this heat wouldn’t be a problem if we could launch the data centers outside the environment — just have a care the front doesn’t fall off.
Image of data center cooling by Анна from Pixabay
934 MHz: When The Government Really Doesn’t Want You To Have CB
In the mid 1970s there were a spate of movies depicting the romance and lifestyle of truck drivers in the southern half of the United States. Over on the other side of the Atlantic these were naturally received not as works of drama but as documentaries, and thus began a craze for British drivers to do up their Ford Capri so in the right light and with your eyes nearly closed, it almost looked like Burt Reynolds’ Pontiac Trans Am from Smokey and the Bandit.
Such a fine automobile was of course incomplete without a CB radio, highly illegal at the time, which led to an underground CB craze and its eventual legalization in 1981. [Ringway Manchester] is here with a tale from that era, of 934 MHz CB, an odd and underused allocation that was eventually phased out for commercial services.
When UK CB was eventually legalized by the government, it was very obvious that they really didn’t want to. Brits got 27 MHz as FM only with meager power and a weird set of frequencies that nobody else had, and a second band way up in the UHF range, at 934 MHz. We remember they originally tried to make a UHF band the only allocation on purpose because it was nearly useless for mobile operation, and Brits only got 27 MHz by fighting back in the political lobbying space.
The video below tells the story of the band, with relatively scarce and expensive equipment leading to it being an exclusive band more similar to the amateur bands, with little resemblance to its raucous 27 MHz counterpart. How much activity there was depended very much on where in the country you were, which of course wasn’t where your Hackaday scribe was as a teenager even if it had been affordable. Eventually the government saw the little flashing pound signs and grabbed it back for a mobile radio service that never materialized, and now the frequencies are part of the mobile phone spectrum.
Have a watch for an odd bit of UK radio nostalgia and some 2020s illegal CB’ers, and if you want more it’s a subject we’ve touched on before.
Continue reading “934 MHz: When The Government Really Doesn’t Want You To Have CB” →
