Boss Byproducts: Calthemites Are Man-Made Cave Dwellers
Some lovely orange calthemite flowstone colored so by iron oxide from rusting steel reinforcing.
Some lovely orange calthemite flowstone colored so by iron oxide from rusting steel reinforcing. Image via Wikipedia
At this point, we’ve learned about man-made byproducts and nature-made byproducts. But how about one that’s a little of both? I’m talking about calthemites, which are secondary deposits that form in those man-made caves such as parking garages, mines, and tunnels.
Calthemites grow both on and under these structures in forms that mimic natural cave speleothems like stalactites, stalagmites, flowstone, and so on. They are often the result of an hyperalkalinic solution of pH 9-14 seeping through a concrete structure to the point of coming into contact with the air on the underside. Here, carbon dioxide in the air facilitates the necessary reactions to secondarily deposit calcium carbonate.
These calcium carbonate deposits are usually white, but can be colored red, orange, or yellow thanks to iron oxide. If copper pipes are around, copper oxide can cause calthemites to be blue or green. As pretty as all that sounds, I didn’t find any evidence of these parking garage growths having been turned into jewelry. So there’s your million-dollar idea.
Continue reading “Boss Byproducts: Calthemites Are Man-Made Cave Dwellers”
Purdue’s Powerful Paint Could Cancel Climate Change
What if a building could stay cool simply because of its paint job? We’re not talking about putting flames on the sides. Purdue engineers have come up with a formulation of white paint that reflects the heat from sunlight and keeps surfaces cooler than their surroundings. Depending on the location, a building with this paint on the roof may not need air conditioning.
Radiative cooling paint is not a completely new animal, but the formulation developed at Purdue is quite impressive compared to commercially-available paints that only reflect 80-90% of sunlight.
Purdue’s paint reflects 95.5% of sunlight. It can keep surfaces up to 18°F cooler than their surroundings, even in direct sunlight. Where does the heat go? The paint radiates infrared heat, so it escapes the atmosphere and goes into deep space.
How does it do this? With abundantly available calcium carbonate fillers — the chalky stuff that antacids are made of. The paint absorbs next to no UV rays because of the wide band gaps in the atomic structure of calcium carbonate. Take a brief tour of this amazing paint after the break.
We wonder how many rooftops and roadways we’d have to paint with this stuff to have a chance at reversing climate change. It’s not terribly expensive to make, so the problem shifts to widespread education and adoption. What do you think?
Continue reading “Purdue’s Powerful Paint Could Cancel Climate Change”
