AI Code Review The Right Way
Do you use a spell checker? We’ll guess you do. Would you use a button that just said “correct all spelling errors in document?” Hopefully not. Your word processor probably doesn’t even offer that as an option. Why? Because a spellchecker will reject things not in its dictionary (like Hackaday, maybe). It may guess the wrong word as the correct word. Of course, it also may miss things like “too” vs. “two.” So why would you just blindly accept AI code review? You wouldn’t, and that’s [Bill Mill’s] point with his recent tool made to help him do better code reviews.
He points out that he ignores most of the suggestions the tool outputs, but that it has saved him from some errors. Like a spellcheck, sometimes you just hit ignore. But at least you don’t have to check every single word.
Continue reading “AI Code Review The Right Way”
Code Review Lamp Subtly Reminds You To Help Your Fellow Developer
[Dimitris Platis] works in an environment with a peer review process for accepting code changes. Code reviews generally are a good thing. One downside though, is that a lack of responsiveness from other developers can result in a big hit to team’s development speed. It isn’t that other developers are unwilling to do the reviews, it’s more that individuals are often absorbed in their own work and notification emails are easily missed. There is also a bit of a “tragedy of the commons” vibe to the situation, where it’s easy to feel that someone else will surely attend to the situation, but often no one does. To combat this, [Dimitris] built this Code Review Lamp, a subtle notification that aims to prod reviewers into action.
The lamp is based on a ring of RGB LEDs and a Wemos D1 Mini board. The Wemos utilizes the popular ESP8266, so it’s easy to develop for. The LED ring and Wemos are tied together with a slick custom PCB. Mounting the LED ring on the top of the PCB and the Wemos on the bottom allows for easy powering via a USB cable while directing light upward.  The assembly is placed in a translucent 3D printed enclosure creating a pleasant diffuse light source.
Every developer gets a Code Review Lamp. The lamps automatically log in to the change management system to check whether anything is awaiting review. If a review is ready, the Lamp glows in a color specific to the individual developer. All this serves as a gentle but persistent reminder that someone’s work is being held up until a review is completed.
We love the way that the device has a clear purpose: it does its job without any unnecessary features or parts. It’s similar to this ESP8266 IoT Motion Sensor in that it has a single job to do, and focuses on it well.
Continue reading “Code Review Lamp Subtly Reminds You To Help Your Fellow Developer”
