Old Desk Phone Gets DOOM Port
Old desk phones are fairly useless these days unless you’re building a corporate PBX in your house. However, they can be fun to hack on, as [0x19] demonstrates by porting DOOM to a Snom 360 office phone.
The Snom 360 is a device from the early VoIP era, with [ox19] laying their hands on some examples from 2005. The initial plan was just to do some telephony with Asterisk, but [ox19] soon realized more was possible. Digging into a firmware image revealed the device ran a Linux kernel on a MIPS chip, so the way forward became obvious.
They set about hacking the phone to run DOOM on its ancient single-color LCD. Doing so was no mean feat. It required compilation of custom firmware, pulling over a better version of BusyBox, and reworking doomgeneric to run on this oddball platform. It also required figuring out how the keyboard was read and the screen was driven to write custom drivers—not at all trivial things on a bespoke phone platform. With all that done, though, [0x19] had a dodgy version of DOOM running slowly on a desk phone on a barely-legible LCD display.
Porting DOOM is generally a task done more for the technical thrill than to actually play the game on terribly limited hardware. We love seeing it done, whether the game is ported to a LEGO brick or a pair of earbuds. If you’re doing your own silly port, don’t hesitate to notify the tipsline—just make sure it’s one we haven’t seen before.
Running DOOM On Earbuds
In 1993, DOOM was a great game to play if you had a 486 with a VGA monitor and nothing to do all weekend. In 2026, you can play it on a set of earbuds instead, if for some reason that’s something you’ve always dreamed of doing.
The project comes to us from [Arin Sarkisian], who figured out that the Pinebuds Pro had enough processing power to run one of the seminal FPS games from the 1990s. Inside these earbuds is a Cortex-M4F, which is set to run at 100 MHz. [Arin] figured out it could easily be cranked up to 300 MHz with low power mode switched off, which would come in handy for one main reason. See, the earbuds might be able to run the DOOM engine, but they don’t have a display.
Thus, [Arin] figured the easiest way to get the video data out would be via the Cortex-M4F’s serial UART running at 2.4 mbps. Running the game at a resolution of 320 x 200 at 3 frames per second would consume this entire bandwidth. However, all those extra clock cycles allow running an MJPEG compression algorithm that allow spitting out up to 18 frames per second. Much better!
All that was left to do was to figure out a control scheme. To that end, a web server is set up off-board that passes key presses to the buds and accepts and displays the MJPEG stream to the player. If you’re so inclined you can even play the game yourself on the project website, though you might just have to get in a queue. In the meantime, you can watch the Twitch stream of whoever else is playing at the time.
Files are on GitHub—both the earbud firmware and the web interface used to play the game. It was perhaps only a matter of time until we saw DOOM on earbuds; no surprise given that we’ve already seen it played on everything from receipt printers to cookware. No matter how cliche, we’re going to keep publishing interesting DOOM ports—so keep them coming to the tipsline.
Thanks to [alialiali] for the tip!
You Can Now Play DOOM In Microsoft Word, But You Probably Shouldn’t
DOOM used to primarily run on x86 PCs. It later got ported to a bunch of consoles with middling success, and then everything under the sun, from random embedded systems to PDFs. Now, thanks to [Wojciech Graj], you can even play it in Microsoft Word.
To run DOOM inside Microsoft Word, you must enable VBA macros, and ignore security warnings, to boot. You’ll need a modern version of Word, and it will only work on Windows on an x64 CPU. As you might imagine, too, the *.DOCM file is not exactly lightweight. It comes in at 6.6 MB, no surprise given it contains an entire FPS. It carries inside it a library called doomgeneric_docm.dll and the whole doom1.wad data file. Once the file is opened, a macro then extracts all the game data and executes it.
If you think that Microsoft Word doesn’t really have a way of displaying live game graphics, you’d be correct. Instead, that DLL is creating a bitmap image of the game state for every frame, which is then displayed inside Word itself. It uses the GetAsyncKeyState function to grab inputs from the arrow keys, number keys, and CTRL and space so the player can move around. It certainly sounds convoluted, but it actually runs pretty smoothly given all the fuss.
While this obviously works, you shouldn’t get in the habit of executing random code in your word processor. It’s just not proper, you see, like elbows on the dinner table! And, you know. It’s insecure. So don’t do that.
Continue reading “You Can Now Play DOOM In Microsoft Word, But You Probably Shouldn’t”
DOOM Ported To A Single LEGO Brick
By now you’ve all seen the tiny LEGO brick with a working screen in it. The work of one [James “Ancient” Brown], it was truly a masterpiece of miniaturization and creativity. Since then, [James] hasn’t stopped innovating. Now, he’s demoing a playable version of DOOM running on a single plastic brick.
We’ve covered the construction of these astounding screen bricks before. Long story short, [James] designed a tiny PCB that hosts an RP2040 microcontroller which is then hooked up to a tiny OLED screen. The components are placed in a silicone mold, which is then filled with transparent resin to form the brick. The screen is then powered via contacts in the bottom, much like older-style LEGO motors.
Early experiments involved running various graphics to emulate a spaceship dashboard, but [James] has now gone much further. He’s implemented RP2040-doom to run the game. It uses tilt controls thanks to an accelerometer, combined with capacitive touch controls for shooting. The monochrome OLED is driven very fast with a special library of [James’] own creation to create three levels of grayscale to make the game actually visible and (just barely) playable.
It’s a hack, of course, and the controls are far from perfect. Nobody’s speed-running E1M1 on [James’s] LEGO brick, to be sure. Perchance. With that said, it’s still a glorious piece of work nonetheless. Just imagine, sitting with friends, and announcing you’re going to play some DOOM — only to pluck a piece of LEGO out of your pocket and start blasting away at demons.
Just because [James] doesn’t know when to quit, we’re going to lay down the gauntlet. Let’s get network play happening on these things, yeah?
Continue reading DOOM Ported To A Single LEGO Brick”
Porting DOOM But In The Opposite Direction
DOOM was first released for MS-DOS, and is one of the pillar titles of the broader first-person-shooter genre. It’s also become a bit of a meme for being ported to any and every weird platform under the sun. Now, a group of developers in Costa Rica have found a way to flip that joke around – by porting an old mobile DOOM game back to the PC.
The game in question is DOOM RPG, made for BREW and Java-compatible phones in 2005. A group named GEC.inc has taken that game and ported it to Windows, outlining their work on the Doomworld forums. As with many such projects, the port is freely available, but doesn’t include the raw game files themselves due to copyright. You’ll have to find the gamedata yourself, and combine it with the files the group published on the forum to get it to work on a modern PC.
For those that have missed the turn-based role playing game based in the DOOM universe (Doomiverse?), today is a good day. No longer must you pine for your ancient, crusty Java smartphone of yesteryear. Now you can play the game on a less awful platform, and listen to the unique and compelling MIDI-esque soundtrack.
Doom ports are hot right now, whether it’s to forgotten Apple OSes or Sega arcade hardware. Video after the break.
Continue reading “Porting DOOM But In The Opposite Direction”
