VCF East 2023: Retro Luminaries Take The Stage
Our friend [Fran Blanche] recently recorded what it was like to participate in an energetic round table at the recently held Vintage Computer Festival (VCF) East. Fran joined well known personalities [Jeri Ellsworth], [Adrian Black] of Adrian’s Digital Basement, and Usagi Electric creator [Dave Lovett] with yours truly moderating.
The table-less roundtable discussed the pros and cons of streaming about retro and tech, and what its like to hang yourself out there in video format. Goals and motives differed widely from speaker to speaker and there was some good-natured ribbing about who makes money vs. who simply gets away with spending less.
Most of all fun was had by the speakers as they interacted with each other, and with the audience — and that comfort came across to the standing room only crowd of avid retro-enthusiasts who only told us good things about what they saw and heard that night.
One thing we did note was that every speaker actually knew what microphones were and how to use them.
Want to learn more about the 2023 Vintage Computer Festival East? You can start by checking out our previous coverage, and don’t miss the first in a series of fascinating interviews recorded by the Hackaday crew as they explored this phenomenal retrocomputing event.
Continue reading “VCF East 2023: Retro Luminaries Take The Stage”
Re-Creating The Apollo DSKY’s Display
Apollo astronauts used the DSKY (Display-Keyboard) to interact with the flight computer with a series of 2-digit codes punched into a numeric keypad. Above the keyboard was a high voltage electroluminescent (EL) display whose segments were driven by electromechanical relays; old-ass technology not seen in operation in decades.
[Fran Blanche] is working to re-create the DSKY’s display, and is raising funds to make her first prototype. She was actually able to go dismantle a real DSKY at the Smithsonian, and this drove her desire to re-create the DSKY’s unusual display.
As [Fran] points out, cinematic re-creations typically involve LED displays and CGI rather than the authentic EL 7-segs. Who would want that when you could have the original?
The DSKY is one of the most recognizable and historically relevant parts of the Apollo Command Module and it’s also quite rare. There are only a handful of  them around and of course none of them work. [Fran]’s display could help museums, collectors — and yes, moviemakers — re-create DSKYs with greater authenticity.
How Commercial Printed Circuit Boards Are Made
Most of us who have dabbled a little in electronics will have made our own printed circuit boards at some point. We’ll have rubbed on sticky transfers, laser-printed onto acetate, covered our clothing with ferric chloride stains, and applied ourselves to the many complex and tricky processes involved. And after all that, there’s a chance we’ll have ended up with boards that were over or under-etched, and had faults. For many the arrival of affordable online small-run professional PCB production from those mostly-overseas suppliers has been a step-change to our electronic construction abilities.
[Fran Blanche] used to make her own boards for her Frantone effects pedals, but as she admits it was a process that could at times be tedious. With increased production she had to move to using a board house, and for her that means a very high-quality local operation rather than one on the other side of the world. In the video below the break she takes us through each step of the PCB production process as it’s done by the professionals with a human input rather than by robots or ferric-stained dilettantes.
Though it’s twenty minutes or so long it’s an extremely interesting watch, as while we’re all used to casually specifying the parameters of the different layers and holes in our CAD packages we may not have seen how they translate to the real-world processes that deliver our finished boards. Some operations are very different from those you’d do at home, for example the holes are drilled as a first step rather than at the end because as you might imagine the through-plating process needs a hole to plate. The etching is a negative process rather than a positive one, because it serves to expose the tracks for the plating process before etching, and the plating becomes the etch resist.
If you’re used to packages from far afield containing your prototype PCBs landing on your doorstep as if by magic, take a look. It’s as well to know a little more detail about how they were made.
Continue reading “How Commercial Printed Circuit Boards Are Made”
[Fran Blanche] Goes In-Depth With The Maillardet Automaton
We’re not specialists, but the Maillardet Automaton is one of the more amazing mechanical machines that we’ve seen in a while, and [Fran Blanche] got to spend some time with it in an attempt to figure out how it’s mysterious missing pen apparatus would have worked. The resulting video, embedded below, is partially her narrative about the experiment she’s running, and part straight-up mechanical marvel.
If you need a refresher course on Maillardet’s Automaton, we’ll send you first to Wikipedia, and then off to watch this other video , which has a few great close-ups of the cams that drive everything.
Continue reading “[Fran Blanche] Goes In-Depth With The Maillardet Automaton”
