[Harrison Krix’s] Marriott Chariot
Atlanta’s Mini Maker Faire had plenty of booths to keep visitors busy, but the largest spectacle by far was the racetrack smack-dab in the middle, and you’d be hard pressed to find a more eye-catching contender than [Harrison Krix’s] vehicle: the Marriott Chariot.
If [Krix’s] name looks familiar, that’s because he’s the master artisan behind Volpin Props, and is responsible for such favorites as the Futurama Holophonor replica and the Daft Punk helmet. (Actually, he made the other one, too).
The Chariot is yet another competitor in the Power Racing Series, an event that keeps popping up here on Hackaday. [Krix] drew inspiration from this Jeep build we featured earlier in the summer, and went to work sourcing an old plastic body to get started. The frame is 16 gauge square tubing, with a custom motor mount machined from 3/16 steel. After welding the chassis together, [Krix] chopped up a small bicycle to snag its head tube and headset bearings. A pair of sealed lead acid batteries fit horizontally in the frame, providing a slightly lower center of gravity.
[Krix] has a keen eye for precision and his build journal shows each step of his meticulous process. But, you ask, why “Marriott Chariot?” and why does the car look like someone threw up a kaleidoscope? Read on beyond the break, dear reader, to learn the Chariot’s origin and to see a video of it winding around the track.
Continue reading “[Harrison Krix’s] Marriott Chariot”
