2023 Halloween Hackfest: Flickering Pumpkin Pin Is Solidly Built
Now first of all, [Steph] grants that you can already take your pick of several LED pumpkin badges out there on IO. That’s not the point. The point is that this flickering pumpkin pin is nicely-built as well as being open source.
Even though it’s fully featured — it flickers, it’s wearable, and it’s lightweight — the build couldn’t be more simple. It’s fancy through-hole LEDs and a coin cell holder, plus a tack pin to stick it through your shirt. But the final result is quite elegant thanks to clever use of PCB layering.
The first version was to get all the layers right to let the light through and embellish the jack-o-lantern’s lines with manufacturer-applied silver solder, but as [Steph] points out, it looked ‘like something a disturbed child might carve into their desk in detention’. So [Steph] enlisted [Mx. Jack Nelson], who improved the artwork.
Pretty much every component does double duty here, including the tack pin — it serves as a switch because it can hold the battery in place. The battery’s edges reflect the glowing light quite nicely around the edge of the pin. And the LEDs beneath the battery prevent it from slipping out. You can see how it goes together in the video after the break.
Continue reading “2023 Halloween Hackfest: Flickering Pumpkin Pin Is Solidly Built” →
Halloween Pumpkin Scares With An Evil Eye
These days, a classic Jack O’ Lantern just doesn’t cut the mustard. Kids are expecting to be scared by high-quality animatronics at a minimum. This haunting work by [Zero To Infinity] might just do the trick.
A real pumpkin is pressed into service in this build, with the usual threatening grin and candlelit interior. However, where it differs is in its single, animated eye. The eye itself is constructed of a pingpong ball, drawn upon with markers for a creepy bloodshot look. A pair of servos allow the eye to twitch and roll, under the command of an Arduino Nano. For further interactivity, an ultrasonic sensor is used to only trigger the pumpkin when it senses a person approaching.
It’s a fun holiday build that also serves as a great primer on how to work with servos and microcontrollers. We can imagine a more advanced setup using more sensors and pumpkins to train multiple eyes on the unsuspecting visitor. If that’s not scary enough, perhaps just make your pumpkins breathe fire instead. Video after the break.
Continue reading “Halloween Pumpkin Scares With An Evil Eye” →
Alexa Controls This Savage Pumpkin
Traditionally, pumpkins are carved during the holiday of Halloween to represent malicious and frightening beasts. Flying in the face of this is [minihannah]’s carving of Adam Savage, which she’s calling a hero pumpkin. It’s a fun twist on the custom, and of course, it’s packing WiFi too.
The build starts with a carving of the typical orange winter squash cultivar, using artwork cribbed from the cover of Mr. Savage’s biography. Inside, there’s a bunch of LEDs, all under the control of an adafruit feather M0, which talks to the broader internet over WiFi. The pumpkin can be controlled by Alexa, thanks to the combination of Adafruit.IO and IFTTT.
It’s a fun little Internet of Things build, and one that’s ready for the modern smarthome, where you’re already used to yelling at the lights to switch off. We’d love to see a similar Billy Corgan build, if only for the pun. If you give it a go, be sure to drop us a line. Video after the break.
Continue reading “Alexa Controls This Savage Pumpkin” →
It’s Never Too Early To Prepare For Halloween: With Flamethrowers
Using a legitimate flamethrower is on the bucket list for a lot of us. Even Elon Musk got into the action with his Not-A-Flamethrower flamethrower. For the rest of us non-billionaires though, we have to come up with clever reasons to build our own like “Halloween is only six months away”. [HandsomeRyan] took this approach six months ago to great effect, and recently released the files on Thingiverse for us all to enjoy.
The cover for building this project was making a Jack-o-Lantern shoot flames out of its face on-demand. The build is based around a car door locking solenoid, which has plenty of kick for applications like this. [HandsomeRyan] upgraded his old wood design with fancy 3D-printed parts which, with the help of the solenoid, deliver a blast of flammable material across a candle inside the Jack-o-Lantern via an aerosol can hidden in the pumpkin.
Part of the elegance of this project is that a car door locking solenoid is typically controlled by remote, meaning that if you want this to be remote-controlled the work has already been done for you. If you need a more timely excuse for building one of these, the Fourth of July is a little bit closer, which should work in a pinch as an excuse to build something crazy even if you’re not American.
Continue reading “It’s Never Too Early To Prepare For Halloween: With Flamethrowers” →
Hacklet 82 – Halloween Hacks 2015
Halloween is when the ghouls start haunting and the hackers start hacking. All hallows eve is the perfect holiday for eerie blinking LEDs, spooky audio oscillators, and wild animatronics. We had a double dose of Halloween hacks last year on the Hacklet. This year we’re bringing you even more of the best Halloween hacks on hackaday.io!
eyes1We start with [dougal] and Halloween Blinky Eyes. [Dougal] wanted to create the effect of creatures peeking at you from the dark corners of the room, and he’s certainly nailed it. A strip of WS2812 LEDs is the trick here. Pairs of LEDs light up, blink, and fade away like spooky eyes. The Strip is controlled by a Particle Core using Adafruit’s NeoPixel Library, though [Dougal] plans to move to the FastLed library. Everything is powered by a USB power pack. This hack isn’t much to look at with the lights on, so check out the video to see these eyes really shine!
witch1Next up is [controlmypad] with Blair the Witch Project. A normal trip to Home Depot turned paranormal when [controlmypad] spotted an awesome witch decoration. The free-standing mannequin had some basic animatronics and the all important manual trigger. [controlmypad] already had a discarded electric wheelchair. After replacing the chair batteries he modified it with a Sabertooth 2×32 Motor Controller and a standard radio control receiver. A spare channel was connected to Blair’s manual trigger. An aluminum tube joins the witch and the scooter. The hardest part of this hack was keeping Blair’s skirt out of the scooter wheels. Home Depot to the rescue! A simple hoop made of lawn edging plastic keeps the fabric and wheels apart.
tweet-trick
[Alex Cordonnier] and his team participated in Boilermake 2015, a 24 hour Hackathon at Purdue University. The fruit of their labor is Trick or Tweet, the tweeting Jack-o’-lantern. Yes folks, we now have the internet of gourds. Hiding inside Trick or Tweet is a Raspberry Pi and a Pi Camera. The pumpkin itself is also a giant capacitive touch switch. Touching the pumpkin triggers a count down after which Trick or Tweet snaps a photo. It then adds some spooky Halloween overlays, a pun or two, and throws the whole thing up on twitter @PumpkinPiPics. [Alex] hasn’t uploaded the code yet, but we’re guessing it consists of a few Python scripts. Pretty awesome for 24 hours of work!
hariSometimes Halloween hacks take on a life of their own. That’s exactly what happened when [Hari Wiguna] sat down with a few parts he ordered from China. Happy Halloween 2015 is the result. [Hari’s] order included some potentiometers, a two color OLED display, and some Arduino clones. In no time [Hari] had three pots wired up to the Arduino’s analog inputs. The OLED quickly followed, displaying graphics via the Arduino’s I2C bus. He really wanted a Jack-o’-lantern though. It took a bit more tweaking, but eventually [Hari] was successful. The first pot sets eye size.  The second controls eye rotation. The third pot changes the width of Jack’s mouth. [Hari] has all the code for this hack up on his most recent project log.
Not spooked enough? If you want to see more Halloween projects, check out our newly updated Halloween hacks list! Did I miss your project? Don’t be shy, just drop me a message on Hackaday.io. That’s it for this week’s Hacklet; As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
Animated Jack-o’-Lantern Really Connects
Days past people used to just carve a scary face in a pumpkin, drop in a candle and call it a day, but for our kind of crowd that’s not going to cut it. [Alexis] stuffed this Jack o Lantern with a lot of brain power and even connected it up to the internet for community control.
At the core of the festive decoration is a spark core, which allows micro controlled special effects to be triggered via Twitter. RGB LED’s change colors, flicker and flash and even a spooky ghost pops out of the top. Along with all that, a sound sensor is added in so the lights can react to the ambient sound around the lantern.
If you get too close an ultrasonic sensor will trigger the ghoulish treat with lights and animation, but what about spooky sounds? That is also included thanks to a toy found at the local discount store, which had its guts removed and its trigger button replaced with a transistor.
Now sights and sounds can all be controlled remotely or in an active response mode to entertain all the little goblins visiting the house this Halloween. Join us after the break for a quick demo video and don’t forget to send in links to your own pumpkin-based hacks this week!
Continue reading “Animated Jack-o’-Lantern Really Connects” →
The R2D2-‘O-Lantern Reddit Doesn’t Want You To See
The people here at Hackaday aren’t dedicating their entire lives to moderating comments and sending press releases to the circular file; some of us actually have jobs and hobbies. [James Hobson] works at a projector company that was having a pumpkin carving contest today. He came up with the best possible use of a pumpkin projector – a R2D2-‘o-lantern that plays the message from [Leia] to [Obi-Wan Kenobi]. [James] submitted this to reddit, but one of the mods deleted it. We’re much cooler than a few mods and their little empire, so we’re putting it up here.
Instead of a knife, [James] used a rather interesting method for carving a pumpkin – a laser cutter. By maxing out the Z height of his laser cutter, he was able to cut a perfect R2D2 graphic on the surface of a pumpkin. No, [James] isn’t removing any of the pumpkin’s skin after the lasering is done, but the result still looks great when backlit.
Inside the pumpkin is a projector playing the famous distress message made from the captured Tantive IV. It’s not entirely accurate – [James] put the projector behind R2’s radar eye and not the holographic projectors, and to project [Leia] in mid-air he would need something like this, Still, it’s a great project we expect to see cloned a year or so from now.
