Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The RollerMouse Keyboard
I just love it when y’all send in your projects, so thanks, [Kai]! But were do I even begin with this one? Okay, so, first of all, you need to know that [Kai Ruhl] built an amazing split keyboard with plenty of keys for even someone like me. Be sure to check it out, because the build log is great reading.
A lovely split keyboard on a pair of rails that doubles as a mouse.
Image by [Kai Ruhl] via Land of Kain
But that wasn’t enough — a mousing solution was in order that didn’t require taking [Kai]’s hands off of the keyboard. And so, over the course of several months, the RollerMouse Keyboard came into being. That’s the creation you see here.
Essentially, this is an ortholinear split with a built-in roller bar mouse, which basically acts like a cylindrical trackball. There’s an outer pipe that slides left/right and rolls up and down, and this sits on a stationary inner rod. The actual mouse bit is from a Logitech M-BJ69 optical number, and [Kai] operates the roller bar using thumbs.
[Kai] found it unpleasant to work the roller bar using thumbs, so mousing is done via the palm rests. You may find it somewhat unpolished with all that exposed wiring in the middle. But I don’t. I just worry about dust is all. And like, wires getting ripped out accidentally.
Continue reading “Keebin’ With Kristina: The One With The RollerMouse Keyboard”
Keebin’ With Kristina: The One With The Part Picker
If you do a lot of 3D computer work, I hear a Spacemouse is indispensable. So why not build a keyboard around it and make it a mouse-cropad?
A Spacemouse with an arcing keyboard built around it.
Image by [DethKlawMiniatures] via reddit
That’s exactly what [DethKlawMiniatures] did with theirs. This baby is built with mild steel for the frame, along with some 3D-printed spacers and a pocket for the Spacemouse itself to live in.
Those switches are Kailh speed coppers, and they’re all wired up to a Seeed Xiao RP2040. [DethKlawMiniatures] says that making that lovely PCB by hand was a huge hassle, but impatience took over.
After a bit of use, [DethKlawMiniatures] says that the radial curve of the macro pad is nice, and the learning curve was okay. I think this baby looks fantastic, and I hope [DethKlawMiniatures] gets a lot of productivity out of it.
Continue reading “Keebin’ With Kristina: The One With The Part Picker”
Keebin’ With Kristina: The One With The Schreibmaschine
Choc switches on a ThumbsUp! v8 keyboard with IBM Selectric typewriter keycaps, thanks to some 3D-printed adapters.
Image by [Sasha K.] via reddit
Remember that lovely Hacktric centerfold from a couple Keebins ago with the Selectric keycaps? Yeah you do. Well, so does [Sasha K.], who saw the original reddit post and got inspired. [Sasha K.] has more than one IBM Selectric lying around, which is a nice problem to have, and decided to strip one of its keycaps and get to experimenting.
The result is a nice adapter that allows them to be used with Kailh chocs — you can find the file on Thingiverse, and check out the video after the break to see how they sound on a set of clicky white chocs.
Those white chocs are attached to a ThumbsUp! v8 keyboard, a line that [Sasha K.] designed. His daily driver boards are on v9 and v10, but the caps were getting jammed up because of the spacing on those. So instead, he used v8 which has Cherry MX spacing but also supports chocs.
As you can see, there is not much to the adapter, which essentially plugs the Selectric keycap’s slot and splits the force into the electrical outlet-style pair of holes that chocs bear This feels like an easier problem to solve than making an adapter for MX-style switches. What do you think?
Continue reading “Keebin’ With Kristina: The One With The Schreibmaschine”
Glove80 Keyboard Sure Fits Like One
If you’re what one might call unlucky, there comes a point in your life when you need to switch to a keyboard that’s more ergonomic than your average rectangle. A little prevention goes a long way, though, and there’s no time like the present to go ergo. Why not? You have everything to gain, from long-lasting comfort to satisfying key presses.
The only problem is that most severely ergonomic keyboards just aren’t portable. At this point, we all know how much I love my Kinesis Advantage, and how I wouldn’t be able to write the Keebin’ column or even a grocery list without it. I have two now, and I take the ugly, yellowed, sticker-bombed one with me out into the world. But as much as I love it, I would really dig a a slimmed-down version that’s just as comfortable, perhaps more so. Well, move over, Kinesis, because you’ve got stiff competition in the form of a flexible little two-piece called the Glove80.
You may recall that there was a Kickstarter for this keyboard about a year ago. I was pumped about it then, and I still am. Here’s why:
Continue reading “Glove80 Keyboard Sure Fits Like One”
Kinesis + Teensy = QMK Advantage Over Your Keyboard
Back in 2013, [Michael Stapelberg] created what is lovingly referred to as the Stapelberg controller: a replacement keyboard controller for the original Kinesis Advantage, the decades-old darling of the ergonomic clacking world. Whether you’re building a new keeb, you’ve got a broken Kinesis, or you simply want to run QMK on the thing and don’t mind getting your hands dirty, there’s a new Stapelberg controller on the block. It’s called the kinT, for Kinesis + Teensy.
[Michael] built kinT in response to the Advantage 2, which came along in 2017 and changed the way the thumb clusters connect to the main board from a soldered cable to an FPC connector. Whereas the original Stapelberg controller was built in Eagle, this one was done in KiCad and is open-source, along with the firmware. You can use a Teensy 4 with this board but if you don’t have one, don’t worry — kinT is backwards-compatible with pretty much every Teensy, and it will even work on the original Advantage.
Are you on the fence about going full ergo? Check out my in-depth review of the original Kinesis Advantage I got that’s almost 20 years old and still clacking along like new. But don’t wait for a repetitive stress injury to go full ergo. Trust me.
Keebin’ With Kristina: The One With The Chinese Typewriter
As much as I’d like to devote an article to each and every bit of keyboard-related what-have-you that I come across in my travels through the intertubes, there just aren’t enough hours. And after all, this isn’t Clack-a-Day. To that end, I gained editorial approval to bring you a periodic round-up of news and other tidbits on the keyboard and keyboard accessories front, and here we are. So let’s get to it!
Continue reading “Keebin’ With Kristina: The One With The Chinese Typewriter”
