Hydraulic Lifting Workbench To Save Your Back
Working on heavy mechanical machines at awkward heights can be a real back breaker. [Workshop From Scratch] knows this all to well, so he built himself a very clean hydraulic lifting workbench to use around the workshop.
As we’ve come to expect from this aptly named channel, everything on the device has been built from scratch. Though he did use an off-the-shelf manually operated hydraulic piston. The lifting mechanism consists of a parallel bar linkage which allows the benchtop to stay parallel through its entire range of motion. The hand lever of the hydraulic piston was converted to a foot pedal for comfort, and the base has some sturdy trolley wheels to move it around the workshop. Raising the table is admittedly quite slow due to the manual pumping required, but it gets the job done eventually.
Making your own tools and equipment provides a lot of satisfaction, especially if you end up using it a lot. [Workshop From Scratch] builds some excellent tools, like this magnetic drill press, magnetic vice and a workshop crane. We hope to see many more.
Continue reading “Hydraulic Lifting Workbench To Save Your Back” →
Scissor Lift Table From The Wood Shop, For The Wood Shop
The value of a mobile adjustable height cart in the shop can’t be overestimated. From moving tools around to installing heavy fixtures on walls and ceiling, a scissor-lift platform is a great tool. Commercial versions get a bit expensive, though, so a shop-built scissor lift table made of wood might be a nice project for the budget-minded to tackle.
Wood might not be your first choice for a fixture such as this, but it’s what [Marius Hornberger] is set up to use, and with proper species selection and careful engineering, it can make for an amazingly sturdy table. [Marius] chose ash for his parts, a wood with a long history of performing well under difficult conditions. The table is not all wood, of course; metal bushings and pins are used in the scissor mechanism, and the lift drive is a stout Acme-thread screw and nut. We’re impressed by [Marius]’ joinery skill, and with how sturdy the table proved to be.
Not a lot of woodworking projects seem to show up in our tip line for some reason, which is a shame. We love to feature wood builds, and like our own [John Baichtal] recently pointed out, the health of the wood shop is often a leading indicator of the health of a hackerspace.
Continue reading “Scissor Lift Table From The Wood Shop, For The Wood Shop” →
