DIY SI5351 Radio Tunes In SW, MW, And More
There are plenty of radios you can buy that pick up MW and SW bands if that’s what you’re into. Or, you can follow [mircemk]’s example, and whip one up yourself instead.
The build employs an ESP32 as the brains of the operation. It’s hooked up to a rotary encoder and a small colour TFT screen, which displays an old-school style tuning dial for choosing the desired frequency. This setup is paired with an Si5351—a capable clock generator chip that can deliver just about any frequency from <8KHz up to 150+ MHz on command. There’s naturally a bunch of supporting analog hardware for the radio end of things, plus a NE612 mixer IC and a PAM8403 class D audio amplifier board, hooked up to a small 0.25W speaker for audio output. [mircemk] has set up the rig to act as a simple radio set, or, with the flick of a switch, it can be configured for SDR use with an attached computer.
It’s a handsome build, and one that likely proves a pleasant way to browse the MW and SW bands on a rainy afternoon. We’ve looked at other hardware in this category before, too. Video after the break.
Continue reading “DIY SI5351 Radio Tunes In SW, MW, And More” →
All-Band Radio Records Signals, Plays MP3s
In these days of everything-streaming, it’s great to see an old school radio build. It’s even better when it’s not old-school at all, but packed full of modern ICs and driven by a micro-controller like the dsPIC in [Minh Danh]’s dsMP3 build. Best of all is when we get enough details that the author needs two blog posts — one for hardware, and one for firmware — like [Minh Danh] has done.
This build does it all: radio, MP3 playback, and records incoming signals. The radio portion of the build is driven by an Si4735, which allows for receiving both in FM and AM — with all the AM bands, SW, MW and LW available. The FM section does support RDS, though because [Minh Danh] ran out of pins on the dsPIC, isn’t the perfect implementation.
Just look at that thru-hole goodness.
The audio section is a good intro to audio engineering if you’ve never done a project like this: he’s using a TDA1308 for headphones, which feeds into a NS8002 to drive some hefty stereo speakers– and he tells you why he selected those chips, as well as providing broken-out schematics for each. Really, we can’t say enough good things about this project’s documentation.
That’s before we get to the firmware, where he tells us how he manages to get the dsPIC to read out MP3s from a USB drive, and write WAVs to it. One very interesting detail is how he used the dsPIC’s ample analog inputs to handle the front panel buttons on this radio: a resistor ladder. It’s a great solution in a project that’s full of them.
Of course we’ve seen radio receivers before, and plenty of MP3 players, too — but this might be the first time we’ve seen an electronic Swiss army knife with all these features, and we’re very glad [Minh Danh] shared it with us.
Continue reading “All-Band Radio Records Signals, Plays MP3s” →
DIY Illuminator For UV Fluorescence Photography
The image shown is the mineral Hackmanite, which fluoresces under ultraviolet lighting. However, not all UV is created equal, and that makes a difference if you’re into UV imaging. The image for this article is from [David Prutchi] and shows the striking results of using different wavelengths of UV. [David] goes into detail on how to make your own DIY Long, Medium, and Short-wave UV Illuminator complete with part numbers and wiring diagram. The device isn’t particularly complicated; the real work was determining the exact part numbers and models of lamp, filters, and ballasts required to get the correct results. [David] has done that work and shared it for anyone interested in serious UV fluorescence photography, along with a white paper on the process.
We’ve seen [David]’s work before. We featured his DIY short-wave UV imager in the past, and his DOLPi camera project was a 2015 Hackaday Prize finalist. It’s clear he really knows his stuff, and genuinely enjoys sharing his discoveries and work.
