Making Smart Bulbs Smarter With The Power Of MQTT
What’s the point of smart home automation? To make every day tasks easier, of course! According to [Tomasz Cybulski], that wasn’t the case when he installed IKEA smart lights in his closet. It’s handy to have them in a common switch, in this case a remote control, but having to look for it every time he needed the lights could use some improvement. Enter his project to make smart bulbs smarter, through the use of a simple ESP8266.
While hooking a door switch to the lights’ power supply could provide a quick solution, [Tomasz]’s wife wanted to keep the functionality of the remote control, so he had to look elsewhere. These light bulbs use the simple Zigbee protocol, so arranging for other devices was rather trivial. A USB dongle to interface with the protocol was configured for his existing Raspberry Pi automation controller, while an ESP8266 served as the real-world sensor by connecting it to reed switches installed in the closet doors.
With all the hardware sorted out, it’s a simple matter of making it all talk to each other. The ESP8266, using the Tasmota firmware, sends a signal to an MQTT server running on the Raspberry Pi, which in turn translates it to a remote trigger on the Zigbee frequency with the dongle. The lights turn on when the door opens, and off again once it closes. And since there were no further modifications to the lights themselves, the original IKEA controller still works as expected, which we’re sure [Tomasz]’s wife appreciates!
MQTT can be an interesting piece of software that goes beyond just home automation though, and if you already have a server in your home you can use it to transfer your clipboard’s contents to another device. If you are using it for home automation though, here’s an inspiration for a rather unusual dashboard to keep things interesting. Check out this hack in action after the break.
Continue reading “Making Smart Bulbs Smarter With The Power Of MQTT” →
Skyscraper Tetris Lets The City Know How Good Or Bad You Are
If you’ve clocked one-too-many hours at Tetris, it might be time to show the world your skills on this skyscraper-sized display on the Shell Centre in London. [Benjamin], [Tom], and their “army of volunteers” took to the Shell building and assembled their super-screen from a collection of 182 networked wireless lightbulbs, some tracing paper, and mylar to create a playable interface from the Jubilee Gardens below.
[Benjamin] doesn’t deliver many of the technical details on his post, but he does give us an overview. He achieves full wireless coverage of all floors by spacing out 14 TP-Link WR702n routers, each running the same version of OpenWRT. This interface wasn’t [Benjamin’s] first choice, as he would’ve preferred to tap into the building’s existing wireless network; unfortunately, he was left without support from the building’s network team. Equipped with a large donation of wireless bulbs controlled by a central bridge, [Benjamin’s] Python-adaptation of Tetris can refresh the building about about 1-to-2 frames per second. Given his description of the bulb interface, we suspect he’s using the all-too-familiar Philips Hue smart lightbulbs to illuminate the building.
In case you haven’t heard of Faraday’s Christmas Lectures, they’re the UK’s nationally broadcasted “science special” featured at the end of the year and founded in 1825 by [Michael Faraday] himself. The goal of these Lectures is to introduce young people to some aspect from the sciences. We’ve seen giant Tetrises before, but not in a way that inspires such a young audience. We’re thrilled to see that hacking both in software (Python, LAN networks) and hardware (ZigBee, OpenWRT) made the cut for this year’s special. After all, why should MIT keep all the fun to themselves?
If the building-scale is just too big for your taste, why not have a go on your oscilloscope?
Continue reading “Skyscraper Tetris Lets The City Know How Good Or Bad You Are” →
Giving Siri Control Of Some Smart Bulbs
After getting his hands on the Philips Hue smart lightbulb [Brandon Evans] cracked open some of the hardware to see what is inside. He also spent time working out the software tricks necessary to use Siri to control light bulbs from iOS.
If you haven’t heard of the Hue product before it’s an LED bulb that fits in a standard medium base whose color and intensity can be controlled wirelessly. Included in each unit is Zigbee compatible hardware that lets the bulbs form their own mesh network. [Brandon] didn’t crack open the bulb since these things cost a pretty penny and disassembly requires cutting. But he did point us to this post where [Michael Herf] shows what the bulb’s case is hiding. We do get to see the other piece of the puzzle as [Brandon] exposes the internals on the base unit that bridges the mesh network to your home network via Ethernet. An STM32 chip is responsible for controlling the base unit.
Aside from a look at the guts [Brandon] hacked Siri (Apple’s voice activated virtual assistant) to control the system. You can see a demonstration of that in the clip after the break. The details are found in the second half of his post which is linked at the top. The code is found in his siriproxy-hue repository.
Continue reading “Giving Siri Control Of Some Smart Bulbs” →
