Controlling Nokia Phones With Arduino
While [Ilias Giechaskiel] was waiting for his SIM900 shield to arrive, he decided to see what he could do with an old Nokia 6310i and an Arduino. He was researching how to send automated SMS text messages for a home security project, and found it was possible to send AT commands via the headphone jack of Motorola phones. But unfortunately Nokia did not support this, as they use a protocol known as FBus. With little information to go on, [Ilias] was able to break down the complicated protocol and take control with his Arduino.
With the connections in place, [Ilias] was able to communicate with the Nokia phone using a program called Gnokii — a utility written specifically for controlling the phone with a computer. Using the Arduino as an intermediary, he was eventually able tap into the FBus and send SMS messages.
Be sure to check out his blog as [Ilias] goes into great detail on how Nokia’s FBus protocol works, and provides all source code needed to replicate his hack. There is also a video demonstration at the end showing the hack in action.
A Dev Board For The ESP Lua Interpreter
From the great minds behind the NodeMCU Lua interpreter for the ESP8266 comes a proper dev board for the WiFi platform of 2015. They are calling it, the NodeMCU-devkit, and it’s a reasonable, cheap, and breadboardable breakout board for the ESP8266.
The version of ESP8266 used in this project is the ESP-12, the newer, fancier model with RF shielding, a questionable FCC logo, and every single one of the GPIOs exposed on castellated connectors. The rest of the board is a USB to serial converter (the CH340G – probably the cheapest USB to serial chip out there), a few passives, and a USB micro connector. It’s simple, cheap, and open source. You can’t do better than that.
This dev board is explicitly designed to work with the NodeMCU firmware, a Lua-based firmware for the ESP. Already we’ve seen some projects make the Hackaday front page with this firmware. Sure, it’s just a garage door opener, but that’s extremely impressive for a chip that’s only a few months old.
Thanks [Baboon] for the tip.
What’s In A Name?
Take thirty seconds out of your day and try to make fun of the last name of the person who wrote this post. Go ahead, it’s okay. You probably won’t need more than ten seconds to come up with something that uses the same first, middle, and last letter. While nothing can be done to prevent last name-based harassment in the schoolyard, first names are another matter. [Ranthalion] recently dined with friends who are expecting twins and have yet to decide on names for them. It’s difficult enough to name one child, and we can imagine ourselves spending an entire day or two getting funny name pairs for twins out of our systems (Flora and Fauna, Scylla and Charybdis, &c). With the baby shower two weeks away, [Ranthalion] had to act fast in creating his Baby Namer.
It needed to be something he could make relatively cheaply with parts on hand. Although he made a prototype with an Arduino, he wasn’t about to just give one away. [Ranthalion]’s Baby Namer uses two arrays, one with awesome names like, well, Sharktooth Chompenstein, and one with regular names from census data such as Bob, Carol, Ted, and Alice. Things got a bit hairy with the volume of names he got from census data and he learned the value of PROGMEM for storing things.
On startup, it displays four names from the Awesome pile as a gag and then pulls from the Ho-Hum group. However, each time it pulls a regular name, there’s a 25% chance that part of an Awesome name will be included. Get thee to the gits and have a laugh at other names on the Awesome list.
Game Boy With Lithium Batteries And USB
[Alan] procured a few Game Boys from a Yahoo auction with the intent of using them for some other projects, but one of the Game Boys was shipped with a very corroded battery which had eaten up one of the terminals. When [Alan] had repaired it, he was left with a Game Boy with no battery terminal at all, so he decided to splice in some lithium-ion batteries.
Not only does the Game Boy now have a new battery pack, but [Alan] was able to source a USB charger to handle the batteries’ charging needs. However, he realized that his battery pack was 3.7 volts, while the Game Boy only needed 3 volts. To lower the voltage of the battery pack to the required voltage, [Alan] grabbed a 1N4148 diode and put it in series with the battery pack, which also helps prevent any accidental reverse polarity.
This isn’t the most technically advanced Game Boy hack we’ve ever seen but it’s great to see new life breathed into these classic video game systems. Not to mention that [Alan] saved some lithium batteries from the landfill!
Skyscraper Tetris Lets The City Know How Good Or Bad You Are
If you’ve clocked one-too-many hours at Tetris, it might be time to show the world your skills on this skyscraper-sized display on the Shell Centre in London. [Benjamin], [Tom], and their “army of volunteers” took to the Shell building and assembled their super-screen from a collection of 182 networked wireless lightbulbs, some tracing paper, and mylar to create a playable interface from the Jubilee Gardens below.
[Benjamin] doesn’t deliver many of the technical details on his post, but he does give us an overview. He achieves full wireless coverage of all floors by spacing out 14 TP-Link WR702n routers, each running the same version of OpenWRT. This interface wasn’t [Benjamin’s] first choice, as he would’ve preferred to tap into the building’s existing wireless network; unfortunately, he was left without support from the building’s network team. Equipped with a large donation of wireless bulbs controlled by a central bridge, [Benjamin’s] Python-adaptation of Tetris can refresh the building about about 1-to-2 frames per second. Given his description of the bulb interface, we suspect he’s using the all-too-familiar Philips Hue smart lightbulbs to illuminate the building.
In case you haven’t heard of Faraday’s Christmas Lectures, they’re the UK’s nationally broadcasted “science special” featured at the end of the year and founded in 1825 by [Michael Faraday] himself. The goal of these Lectures is to introduce young people to some aspect from the sciences. We’ve seen giant Tetrises before, but not in a way that inspires such a young audience. We’re thrilled to see that hacking both in software (Python, LAN networks) and hardware (ZigBee, OpenWRT) made the cut for this year’s special. After all, why should MIT keep all the fun to themselves?
If the building-scale is just too big for your taste, why not have a go on your oscilloscope?
Continue reading “Skyscraper Tetris Lets The City Know How Good Or Bad You Are” →
Reverse-Engineering A Superior Chinese Product
It makes an Arduino look like a 555.  A 364 Mhz, 32 bit processor. 8 MB RAM. GSM. Bluetooth. LCD controller. PWM. USB and dozens more. Smaller than a Zippo and thinner than corrugated cardboard. And here is the kicker: $3. So why isn’t everyone using it? They can’t.
Adoption would mandate tier after tier of hacks just to figure out what exact hardware is there. Try to buy one and find that suppliers close their doors to foreigners. Try to use one, and only hints of incomplete documentation will be found. Is the problem patents? No, not really.
[Bunnie] has dubbed the phenomenon “Gongkai”, a type of institutionalized, collaborative, infringementesque knowledge-exchange that occupies an IP equivalent of bartering. Not quite open source, not quite proprietary. Legally, this sharing is only grey-market on paper, but widespread and quasi-accepted in practice – even among the rights holders. [Bunnie] figures it is just the way business is done in the East and it is a way that is encouraging innovation by knocking down barriers to entry. Chinese startups can churn out gimmicky trash almost on whim, using hardware most of us could only dream about for a serious project.
Continue reading “Reverse-Engineering A Superior Chinese Product” →
Parametric Spherical Speakers Are Not A Moon
A good speaker enclosure is not just about building a box out of plywood and covering it with carpet, although playing with 1F capacitors is pretty cool. No, for a good speaker enclosure you need the right internal volume, the right size bass port, the right speaker, and it should definitely, certainly, not be a moon.  [Rich] figured out he could do all of this with a 3D printer, resulting in the NOMOON: The NOMOON Orbital Music-Making Opensource, Openscad-generated Nihilator.
This work is a continuation of earlier work that designed parameterized speakers in the shape of Borg cubes. Now [Rich] is on to Borg scout ships,  and this version has everything you would expect for speaker design.
The NOMOON is available on the Thingiverse Customizer with variables for the internal diameter, the volume of the enclosure in liters, wall thickness, speaker hole, bass port, and wire holes. Of course a customized design is also possible with a stock OpenSCAD installation.
[Rich] has printed a few of these not moons and even with a speaker with terrible bass response, he has a pretty good-sounding setup as far as Youtube videos go. You can check that out below.
Continue reading “Parametric Spherical Speakers Are Not A Moon” →
