Various cybernetic limb and organ replacements were recently featured in IEEE’s flash demo called The Bionic Body Shop, but we were most interested by the bionic eye and the cochlear implant (we already discussed the featured powered exoskeleton). These are notable for the fact that they are not merely high-tech prosthetic replacements strapped to or worn on the body, but implants that are housed within the body and work with flesh-and-blood sense organs on a much closer level than any preceding technology.
Day: June 5, 2008
Obsolete Technology Band
Radiohead held a contest for fans to remix the single Nude from their album In Rainbows. Frontman Thom Yorke mentioned on NPR that the contest was essentially a joke, since the Nude track is recorded at 6/8 timing and 63bpm, much slower than traditionally mixed music. The above video from [James Houston] is one of the most creative entries. Using old computer hardware he has recreated the track in a very unique way. He uses a Sinclair ZX Spectrum for the guitar track, a dot matrix printer for the drums, a scanner for bass, and a hard drive array for vocals.
Want to make your own band with obsolete technology? Click through for a few pointers to get you started.
HP Color LaserJet 2600n Teardown
In the ongoing quest to find parts for new projects by scavenging old devices, the curiously sane and benevolent team at Evil Mad Scientist Laboratories took apart an HP Color LaserJet 2600n. They wanted to see what makes it tick and what parts can be culled from it for later use.
One Handed Controller Available For Pre-order
You are probably familiar with the work of [Ben Heckendorn]. His latest commercial project, the one handed Access Controller, is now available for pre-order. A well known modder, he has created several unique video game console adaptations including a scratch built one handed Xbox 360 controller.
A unique feature of this controller is that it allows you to change the location of the buttons/joysticks. This modular design can be swapped and customized depending on your needs. Ben is including a guide for creating your own modules, should you be so inclined. The device uses 2.4Ghz wireless to communicate and is available for $129.99.
Since we know you are more interested in hacks than gadgets, be sure to checkout Heckendorn’s nice collection of how-tos on Engadget.
[via Engadget]
Building A MIDIbox SID
We’ve discussed MIDIboxes before (and once before that), but we’ve never really told you what goes into them or how to build one. We’ll take you through the process after the break.
Soft Start Your Flashlight For Longer Bulb Life
[Reinhard] has a great collection of DIY SCUBA projects. One interesting hack he put together is a soft start circuit to improve the life of the bulb in a flashlight. Despite LEDs getting cheaper, MR16 halogens are dirt cheap and put out some serious lumens.
