[XVortex] pulled off a pretty incredible firmware hack. He managed to get a firmware upgrade for Synology running on a QNAP machine. These are both Network Attached Storage devices, but apparently the Synology firmware is better than what QNAP supplies with their offerings.
The nice thing is that this is not a one-off hack. You can download the raw image and give it a spin for yourself. A few words of warning though. It will only work on models which use theĀ Atom and ICH9R chipset, you’re out of luck if you have one sporting an ARM processor. You will also need to format the drives once the new firmware is flashed so do this before you fill them up.
This harkens back to the days when DD-WRT was first being run on Linksys routers. We don’t remember if that started with upgrade image hacks like this one uses, or if the source code was available (Linksys was compelled to release it once it was proven they were in violation of the GPL).
See a proof video of this hack after the break.
Continue reading “NAS Firmware Hack: Synology Running On QNAP Hardware”
