Hackaday Links: Sunday, May 12th, 2013
hackaday-links-chain
[Johnathan Crawford] isn’t bashful about tearing the insides of his truck apart. He’s built his own remote starter using a Raspberry Pi.
We vaguely remember hearing about a startup that planned to deliver tacos using quadcopters instead of people. We assume that company was a bust but here’s the concept in action at the 2013 RoboGames [thanks Don].
On the topic of food: pizza and joysticks… do they go together? Perhaps. Here’s a joystick made out of an empty pizza box (note the remains of grease stains inside).
[Jonathan] brings to our attention the problem of running out of fingers to press all the buttons on your Monome at just the right moment. No worries, just add some solenoids to act as extra fingers.
Apparently some Samsung cameras (NX20, NX210 and NX1000) can use their USB port as a shutter release. The trick is finding the right resistor values for the ID pin [thanks Janne].
Plagued with a tablet dock that wasn’t weighty enough to prevent the device from tipping over [John] filled base with lead to keep the thing upright.
[Helmut’s] bathroom had no windows. He faked one using an Arduino and an RGB led.
And finally, as a reward for all the readers that made it to the bottom of the article, here’s a gem of a project. [Charlie] was inspired by the recent logic combo lock post to send in his own plans for a lock he made years ago. Unfortunately he can’t find the pictures from the build but the theory behind it is quite engaging.
Hobby Electronics Team Up With Augmented Reality
augemented-reality-hobby-electronics
Here’s an interesting take on using augmented reality alongside hobby electronics. The project, which comes from a group of researchers at the MIT Media Laboratory, starts off by making simple electronic devices like a radio with two knobs using network connected hardware. In other words, build something using an Arduino and include a way to get it on a network. With the radio example on knob is for tuning, the other adjusts the volume. But pick up an iPad and aim its camera at the device — which is what the image above is showing — and those knobs will get a lot more functionality. This opens up a whole set of virtual controls that can be assigned to different segments of the knob controllers.
This is certainly a better use of augmented reality than using it in advertisements which is where it usually shows up. We also think that the proliferation of personal electronics that include high-quality camera modules makes wide adoption a lot more plausible than some of the projector-based augmented reality we’ve seen. Check out a full demo in the video after the break and if that leaves you hungry for details you can get your hands on the whitepaper (PDF).
Continue reading “Hobby Electronics Team Up With Augmented Reality” →
External Pinball Controls For An Android Tablet
android-pinball-controls
This hack, which adds external flipper controls to Android pinball, is a great way to cut your teeth at Android hardware hacking.
[Ruben] decided to go with the TI Launchpad for this project. The MSP430 dev board offers serial communications via a USB connection, but it’s not quite as easy as just finding the right cable. His tablet does support USB On the Go (OTG), but the board identifies itself as an ACM device which needs to be handled differently. In order to get the tablet talking to the Launchpad he compiled a CDC_ACM module for the Linux underpinnings that make up every Android OS. In this case the module is tailored for the Allwinner A10 chip inside his model of tablet, but it shouldn’t be too hard to adapt his guide for other processors.
Of course you could go a different route and use Bluetooth for connectivity. We’ve seen several gaming peripherals that use this technique with Android devices.
Continue reading “External Pinball Controls For An Android Tablet” →
