Bubble Displays Are Increasing In Resolution
PipeDreams 3 bubble display
[Bruce] has created a pretty cool bubble display that is capable of showing recognizable photographs of people. This entire art installation is no slouch at 3-stories tall! This one resides at the Ontario Science Centre in Toronto, Canada. If you are unfamiliar with bubble displays, they consist of several clear vertical tubes filled with a liquid. A pneumatic solenoid valve mounted at the bottom of each tube allows a controlled amount of air to enter the tube at a very specific time. Since the air weighs less than the liquid, the air bubble travels up the tube of liquid. Interesting patterns can be made if these bubbles are timed correctly. This setup uses a Linux-based computer with custom control software to manipulate the valves.
[Bruce] didn’t start off making super-complex bubble displays. This is actually his 3rd go-around and with 96 individual tubes and capable of displaying raster images, it is the most complicated so far. His first creation consisted of 16 tubes, each larger in diameter than the most recent creation. With the larger diameter and less number of tubes came less resolution and the ability to only display simple shapes. Version 2 had twice as many tubes, 32 this time. In addition to doubling the tube quantity [Bruce] also colored the fluid in the tubes, not all the same color but all the colors of the rainbow, from red to violet. Still, this version could not show raster images. It appears to us that the third time’s the charm! Video after the break….
Pipe Dreams 3 bubble Display
If you’re interested in more DIY-friendly bubble displays, check out this 60-tube build with RGB’s or this 3 dimensional bubble display.
https://www.youtube.com/watch?v=MhhnBgFOtg0
14 thoughts on “Bubble Displays Are Increasing In Resolution
  1. Ah, I’ve seen his original one at the MN Science museum. I didn’t realize they had mineral oil in them, I remembered the bubbles moving much faster. Now that makes me want to try something similar in the style of those old ‘rain’ lanterns with the mineral oil dripping down nylon strings..
  2. Good idea above; the tubes actually would seem to disappear submersed in water!
    I wonder if the majority of the light comes from the walls of the cylinders or if it comes from the top and/or bottom. If most of the light comes from the walls, then one could implement some sort of nozzle that could proportionally mix CYMKW gasses so the images could reproduce the full color spectrum!
  3. I wonder if you made a 2D grid of these tubes what would that look like.
    Of course rendering 3D images with Marilyn Monroe or Albert Einstein becomes a bit harder because there are no 3D scans of them (yet). I’m trying to picture how you could easily generate static 3D models of them from the archived 2D video that exist of them.
      1. But that used a human to see images of the man and create it in modelling clay and then it was scanned. I was thinking more along the lines of some image processing that took the human interpretation out of the equation a bit more, if you know what I mean.
  4. Thanks for the kind words. This is the prototype and proof of concept for the one Alan Kilian helped me install 8 years ago in Toronto. It’s definitely still running. The most recent (2010) was installed in Warsaw, at the (then) new Copernicus Science Centre.
    And that’s my beloved (now gone) Ajax, looking at marilyn.
Leave a Reply to Hitek146Cancel reply
