Hackaday Links: July 19, 2015
Hackaday Links Column Banner
Everybody needs an external USB drive at some time or another. If you’re looking for something with the nerd cred you so desperately need, build a 5 1/4″ half height external drive. That’s a mod to an old Quantum Bigfoot drive, and also serves as a pretty good teardown video for this piece of old tech.
The Woxun KG-UV2D and KG-UV3D are pretty good radios, but a lot of amateur radio operators have found these little handheld radios eventually wear out. The faulty part is always a 24C64 Flash chip, and [Shane] is here to show you the repair.
Last year there was a hackathon to build a breast pump that doesn’t suck in both the literal and figurative sense. The winner of the hackathon created a compression-based pump that is completely different from the traditional suction-based mechanism. Now they’re ready for clinical trials, and that means money. A lot of money. For that, they’re turning to Kickstarter.
What you really need is head mounted controls for Battlefield 4. According to [outgoingbot] it’s a hacked Dualshock 4 controller taped to a bike helmet. The helmet-mounted controller has a few leads going to another Dualshock 4 controller with analog sticks. This video starts off by showing the setup.
[Jan] built a modeling MIDI synth around a tiny 8-pin ARM microcontroller.  Despite the low part count, it sounds pretty good. Now he’s turned his attention to the Arduino. This is a much harder programming problem, but it’s still possible to build a good synth with no DAC or PWM.
7 thoughts on “Hackaday Links: July 19, 2015
    1. “arduino, Battlefield, breast pump” would scare the hell out of me! Oh and as for the bigfoot/usb drive mod, he should have knotted the USB cable, if you swung that thing hard enough it could hurt like hell.
  1. I didn’t use an archaic 5 1/4″ bigfoot drive but I’ve done the same hack with a dead 3 1/2″ except that I used a usb hub and 4 flash drives.
    I mounted mine in an empty drive bay with a (not all that) hidden power switch for the hub. For v2 I was thinking of looking for a 12v hub so I could route the power through ths molex plug. Thought about running the usb data lines through the original IDE plug and a custom ribbon cable to an unused USB header on the motherboard for some ultra-covert storage.
    Briefly thought about making the flash drives a JBOD raid array to appear as one drive instead of 4 drives. Then I saw 8 and 10 port USB hubs and started to lose interest when I started thinking about the cost of doing it with 8 or 10 32/64 gig flash drives…
Leave a Reply to ShannonCancel reply
