Winning The Console Wars – An In-Depth Architectural Study
From time to time, we at Hackaday like to publish a few engineering war stories – the tales of bravery and intrigue in getting a product to market, getting a product cancelled, and why one technology won out over another. Today’s war story is from the most brutal and savage conflicts of our time, the console wars.
The thing most people don’t realize about the console wars is that it was never really about the consoles at all. While the war was divided along the Genesis / Mega Drive and the Super Nintendo fronts, the battles were between games. Mortal Kombat was a bloody battle, but in the end, Sega won that one. The 3D graphics campaign was hard, and the Starfox offensive would be compared to the Desert Fox’s success at the Kasserine Pass. In either case, only Sega’s 32X and the British 7th Armoured Division entering Tunis would bring hostilities to an end.
In any event, these pitched battles are consigned to be interpreted and reinterpreted by historians evermore. I can only offer my war story of the console wars, and that means a deconstruction of the hardware.
An Architectural Study of the Sega Genesis and Super Nintendo
The traditional comparison between two consoles is usually presented as a series of specs, a bunch of numbers, and tick marks indicating which system wins in each category. While this does illustrate the strengths and weaknesses of each console, it is a rhetorical technique that is grossly imprecise, given the different architectures. The usual benchmark comparison is as follows:
Specs
Conventional wisdom – and people arguing on the Internet – tells you that faster is better, and with the Sega console having a higher clock speed it’s capable of doing more calculations per second. Sure, it may not be able to draw as many sprites on the screen as the SNES, but the faster processor is what allowed the Genesis / Mega Drive to have ‘faster’ games – the Sonic series, for example, and the incredible library of sports games. It’s an argument wrapped up in specs so neatly this conventional wisdom has been largely unquestioned for nearly thirty years. Even the Internet’s best console experts fall victim to the trap of comparing specs between different architectures, and it’s complete and utter baloney.
Let’s take a look at one of these numbers – the CPU speed of the SNES and the Genesis/Mega Drive. The SNES CPU, a Ricoh 5A22 is based on the 65C816 core, an oft-forgotten 16-bit offshoot of the 6502 and related chips found in everything from the Apple II, Commodore 64, and even the original Nintendo NES. The 5A22 inside the SNES is clocked at around 2.68 MHz for most games. The Sega used a 68000 CPU clocked at 7.67 MHz. By comparing just these two numbers, the SNES wins, but this isn’t necessarily the truth.
In comparing the clock speed of two different CPUs, we’re merely looking at how frequently the bus is accessed, and not the number of instructions per second.
In the 68000, each instruction requires at least eight clock cycles to complete, whereas the 65C816 – like it’s younger 6502 brother – could execute an instruction every two or three clock cycles. This means the Sega could handle around 900,000 instructions per second, maximum. The SNES could compute around 1.7 Million instructions per second, despite it’s lower clock speed.
Even though the Sega console has a faster clock, it performs fewer instructions per second.
And so we come to the crux of the argument; the statistics of the great console wars, while not wrong, are frequently misinterpreted. How then do we decide an outcome?
The Architecture of the Sega Genesis / Mega Drive
genesis_block_diagram
While the Sega Genesis/Mega Drive is usually cited as having a 68000 CPU, this isn’t a complete picture of what’s going on inside the Sega console. In effect, the Genesis is a dual-processor computer with two CPUs dedicated to different tasks. The 68000 handles game logic and graphics, but surprisingly not much else. A Z80 — a CPU introduced a decade before the Genesis/Mega Drive — is used for reading the state of the game pads, and playing audio.
Interestingly, the Sega Genesis / Mega Drive contains most of the components of Sega’s earlier console, the Sega Master System. With the addition of a Power Base Converter, Master System games can be played while the 68000 CPU is in idle.
The  Architecture of the Super Nintendo
SNES-BLOCK-DIAGRAM
The SNES is a different beast entirely. Everything is controlled through the 5A22 / 65816 CPU. The controllers are fed right into the data lines of the 5A22, and DMA instructions are able to shuttle data between the two slightly different Picture Processing Units.
An interesting difference between the two consoles are the connections between the cartridge slot and various peripheral chips. Nearly the entire cartridge connector of the Sega machine is dedicated to the address and data lines for the 68000 CPU. While there are a few control signals thrown in, it’s not enough to allow the cartridge direct access to the video display unit or the FM synthesis chip.
The cartridge connector for the SNES, on the other hand, has direct access to one picture processing unit and the audio processor. The exploitation of this capability was seen in games ranging from Star Fox with it’s SuperFX chip, to Mega Man X games with its math coprocessor, to Super Mario RPG: Legend of the Seven Stars and its Super Accelerator 1 chip that is basically an upgraded version of the main SNES CPU, the 5A22.
Comparative designs, and who won the console wars
Time to make a holistic analysis of each competing platform. By far, the SNES is a more capable console; its cartridges are able to send data directly to the PPUs and audio processors, it’s faster, and there’s more work RAM, vRAM, and audio RAM.
The Sega 'Tower of Power'. Image credit /u/bluenfee
The Sega ‘Tower of Power’. Image credit /u/bluenfee
The Genesis / Mega Drive may be seen as more expandable thanks to the Sega CD (the first CD-ROM based game console, the Sega 32X), an upgraded coprocessor for the Genesis, backwards compatibility with a Master System Power Base converter, and a number of strange cartridges like Sonic and Knuckles with ‘lock-on’ technology. However, it’s actually the SNES that is more expandable. This is most certainly not the conventional wisdom, and the difference is due to how expandability was implemented in each console.
To add additional capabilities to the SNES, game designers would add new chips to the game cartridge. Star Fox famously exploited this with the SuperFX chip, and the list of SNES enhancement chips is deserving of its own entry in Wikipedia.
In comparison, the Genesis / Mega Drive could only be expanded through kludges – either through abusing the ASIC chip between the 68000 and Z80 CPUs, or in the case of the 32X add-on, bypassing the video display unit entirely.
In any event, this is purely an academic exercise. Games sell consoles, and Nintendo’s IP portfolio – even in the early 90s – included characters that had their own cartoons, live action movies, and cereals.
While this academic exercise is completely unimportant today – there probably won’t be a game console that ships with cartridges any more – it is an interesting case study on extendable computer design.
100 thoughts on “Winning The Console Wars – An In-Depth Architectural Study
    1. It’s often forgotten that “Blast Processing” was a real thing. It was a technique the programmers could use for a short term boost in processing speed. To be honest I don’t quite remember how it worked exactly, but that’s more than the marketing guys understood.
    1. Back then (1991), PCs really really sucked when it came to graphics (no sprites except for the mouse cursor) and audio (one channel square wave). The Commodore 64 could still beat the PC in ’91 when it comes to games. And don’t make me mention the Amiga.
      Commodore does what Nintendon’t.
        1. Much more appealing to me, amiga cd32. Fairly well understood architecture, easy to code for, no crappy drm or copy protection on the discs to spoil you being able to make your own and nice little tidy package to sit under the tv.
          I used to write demos and game software on the a500, and later on went to make the jump to x86 and it was just a fragmented mess after the relative hardware stability of the amiga. Still my favourite console in my collection.
          Its just a damn shame that commodore’s management couldnt organize a pish up in a brewery around that period or we could have seen a fairly open machine on the market to tinker with a lot longer, it shifted 100,000 units in europe alone, then mis management managed that whole stuck in a warehouse leading to bankrupcy debacle and it never even made the US market.
          Never really got into the whole having to have a game cartridge thing on the snes, and sega sort of passed me by then too as didn’t see that much of a homebrew scene in comparison to the amiga etc. I dont remember having any real enthusiasm for consoles until the 3d0 launched with need for speed and Zarch (aka virus) on the jaguar was pretty interesting as I had been rather addicted to elite on the c64 also by david braben, and then the ps1 arrived with its easy to defeat disc protection schema around the time of cheap scsi cdrecorders which lead to the homebrew scene lighting up once more and into the original xbox which was basically a rather bespoke minimal pc inside once you got in. I still have a free mcboot’d ps2 + wii that can run homebrew.
          My collection starts with a radeon tele-sports bat n ball machine and some pre jamma arcade machines and stops at the ps3 and 360 era, wife asked me if I want a ps4 or xbox one for xmas and the answers no. Not interested in consumer devices without much modding possibilities and I can’t imagine being able to get hold of a dev kit and hit the hardware on anything as locked down as a modern console so for me there it ends. Pity as a modern cel processor appeals after having had a play with ppc’s (genesi not mac…) after the amiga too.
          1. How wasn’t the Amiga a clusterfuck when it came to upgrades and expansions?
            You had ten different types of RAM, slow, fast, and different chips doing half the job of the other chip in a criss-cross fashion, and when you added some expansion you’d have to turn off another…
          2. Actually every Xbox after the 360 is a development machine.
            You reboot in dev mode, what you write won’t run in retail mode without signed binaries, but it’s a real dev machine, you can hook it up to VS and away you go
      1. “Commodore does what Nintendon’t.”
        As a Commodore girl and a Sega chick, this makes me happy. I was an extremely happy kid (having gotten my C64C when I was five, and my Genesis Model 1 when I was 10), what with my glory days of Sonic and Vectorman and MicroMachines Racing. And of course, I never stopped playing Jumpman and Ultimate Wizard.
        1. That is amazingly dependent on what you mean by “then” and the assertion that “PCs didn’t suck”.
          The fastest PC in 1991 (for a consumer at least), would like have had an Intel 486DX running at 50 MHz. You’d have been lucky to have 4-8 MB of ram and a graphics card with 2 MB at most of VRAM (1 MB or 512 KB more likely).
          And the odds are decent that you’d be relying on ISA expansion cards for video and audio, unless you were fortunate enough to be rocking a VLB graphics card.
          Most likely you’d still be running MS-DOS.
          The Nintendo SNES would have toasted the /average/ PC for actual gaming.
  1. We have to consider development costs. Nintendo had 90% of the console market with Nes/famicom, and money to develop a huge project. Sega made genesis with non-sold parts of sms and some arcade machines. Its simpler, and direct.
    1. Actually, Sega was way more willing to take risks in hardware design. Yamauchi blocked any attempt to do new things (hardware-wise), “old, cheap, well tested components used in new creative ways” was their trademark. Historically, Nintendo almost never spent that much money creating their new consoles, GameCube being probably the only exception and the crappy “red-only not-that-portable” VirtualBoy the clearest example of the bad consequences.
  2. Super Mario kart on the SNES, the best multiplayer driving game ever.
    Drifting before drifting was cool.
    We played that to death and perfection. One single slip up would cost you the race.
    No “catch up” mode or other player helpers. Pure seat of the pants skill and weaponry bonus.
  3. I should note that the Sega CD and 32x were different devices (I think you were trying to say that above, but it’s garbled).
    Also, I find it interesting how both the Genesis/MD and the Playstation2 handle backward compatibility. They’re both essentially the previous gen’s console with a more powerful computer tacked on. But the older hardware is still needed for stuff like reading the controllers and audio.
    1. Genesis is not similar to the SMS. It contains the same cpu for sound control and the vdp was a redesign but that’s where the similarities end.
      Same for PS1 to PS2. They are both completely different. But the PS2 is basically two consoles in the same box.
      I think it was a waste of money to do that. Nobody ever used PS2 for PS1 gaming.
  4. Nice reference to the Gear Wars from Rick & Morty.
    …oh wait, was the R&M ref a callback to something else? Oh no… hipster cred failing… too much parent time…
    I really enjoyed reading this. I’d love to see more comparative breakdowns of common media appliances.
  5. I love it when “historians” reinterpret history!
    It happens in every field of endeavor, whether it be “the north could have won at Gettysburg with bows and arrows and had nothing to do with the greater range of rifled versus smooth bores” or the Apollo program was just a “west versus east” pissing contest.
    Nintendo “won” because of Mario and those dumb “fighting” games, nothing else and they are still flogging that deceased equine.
    A console platform lives or dies on its fanbase, little twats don’t give a rats ass what is “under the hood”.
    I’ve been “gaming” since the very beginning, I’m talking “Pong” here, the original one done in 7400 TTL, not the AY-xxxx chip.
    Those first consoles that HAD the AY-xxxx chip, switch selectable to play a couple of bat and ball games, maybe with a light pen style “pistol” to “shoot” shit with, sold like hot cakes, then died out.
    Then we had Space Invaders (shudders) that folks would play for hours.
    Things progressed, sorta, my first job out of high school was in a 1980’s video game arcade, I still had to maintain Pong and Space Invader machines well into the 1990’s!!!
    Sheeple like what is familiar, it doesn’t matter if it’s any good (this is why ford can sorta still sell cars).
    The Nintendo arcade machines were popular, they managed to translate that commercial success into the console market in a way that Sega or Atari (remember them??) never did.
    Anyone remember Exidy? The Exidy Sorcerer???
    The couple of arcade games Exidy had were kinda ok, the console was kinda ok,
    Anyone remember the Fairchild F8 console??
    Same deal, the only reason game arcades “worked” was the hardware was better than what most of us could afford at home, when a console is about as good as what you could play in an arcade, why bother?
    Atari tried to make a (terrible) home computer system, then tried to sell it as a console without a keyboard.
    The number of times I’ve had arguments with idiots over “Sega is lame, Nintendo is better” is staggering, it’s like the whole iThing crap, almost like a religion, “it’s better because it is”, no logic, just “passion”.
    1. yawn, crazy old man that with excellent points, but invalidates own point with bad analogy that is objectively false. “this is why ford can sorta still sell cars.” Ford can sorta still sell cars because of excellent timing with respect to organizational changes and extremely prudent manufacturing investments. yea yea your gut tells you only immune he-mans of yore can see through the drivel that dominates the “sheeple” decision making process.
    2. I love it when “literates” reinterpret a post.
      “Nintendo “won” because of Mario and those dumb ‘fighting’ games, nothing else and they are still flogging that deceased equine.
      A console platform lives or dies on its fanbase, little twats don’t give a rats ass what is ‘under the hood’.”
      FTA:
      “In any event, this is purely an academic exercise. Games sell consoles, and Nintendo’s IP portfolio – even in the early 90s – included characters that had their own cartoons, live action movies, and cereals.”
      You’re shitting on him for saying the exact same thing as you. Except he has eloquence, you have misplaced anger.
      Sheeple: Following the herd while believing that you’re pretty a special snowflake.
      1. This. Besides, Nintendo “won” because of the controller. We liked the blood in MK on the Genesis, but it wasn’t enough to counter only having 3 buttons (forget the 6 button thing they tried… the layout works great in an arcade machine (ala Street Fighter), but didn’t translate well to a handheld controller, IMHO).
        The shoulder buttons on the SNES controller are what did it for me. Easy blocking in MK and we got so good with SFII that we regularly had one-handed “tournaments” where you held the controller against your cheek and just used the d-pad and left shoulder.
      1. the Atari ST was a great machine!
        I’m talking about the 400 with the membrane keyboard and the 800, both of which had a 6502.
        The ST was a 68000 machine and much under rated, if I bothered I could dust off the couple I have in storage.
        ps
        I’d love you to try stamping anything on my neck, I could use a good laugh…
    1. Correct. The PC-Engine CD-ROM drive was released in late 1988 in Japan. The Sega-CD was released in late 1991 in Japan. In fact the TurboDuo which was the intergrated version of the main console and CD-ROM drive came out before the Sega-CD attachment.
          1. Set guns to ban mode – But captain they they will never oscillate with all this feed back. I’ it’s true captain, the ‘Q’ factor – she can’t take any more feedback.
    1. I imagine these days it’d actually be pretty easy – though getting quality graphics out may not be. But essentially riffing off things like the Arduboy with the games being stored on cart format external cards.
      On the other hand, maybe people have done enough of the work for you to start down the path of quality output with FPGAs by emulating other chips on them directly.
  6. The photo of the “Tower of Power” is nonsense.
    Besides plugging in the Master System power base into the 32X (never met anyone that felt the need to do this), the Cleaning System is plugged in above it. Do I need to state what is wrong with that? Then the two Sonic & Knuckles games above the Game Genie.
    As a humorous chide against the Genesis design choices, I get it. But as a reference image in a tech article? C’mon….
    Yeah, this is about the fanboy crap. This is about presenting an article on a t3ch oriented site with respect to either side. If you can’t do that, regardless of which side is deemed “better”, then the article is worthless.
  7. Hey Brian, I hate to point it out, but the Sega Nomad wins this argument for Sega. :P A decent quality handheld worth having (even if the screens did ghost a bit too much). Oh, and the prices weren’t kept at artificially insane rates. ;)
    1. Nomad also wins points for being the only portable made (homebrew portabalized consoles don’t count here) that used the same cartridges as the console version. Even better was its capability to be used like a console by connecting it to a TV and second controller.
      The only others that come close are the GameBoy addons for the SNES and GameCube. But those went the opposite way from Nomad, plugging portable games into a console.
      Did any Cube games other than Pac Man exploit the ability to use a GB Advance for a fifth player?
  8. One minor correction. It is stated that:
    “In the 68000, each instruction requires at least eight clock cycles to complete, whereas the 65C816 – like it’s younger 6502 brother – could execute an instruction every two or three clock cycles.”.
    This isn’t quite correct. The 68000 had many 4 cycle instructions also. For example 32-bit register move “MOVE.L D0,D1” (I don’t believe 65816 could do 32-bits in one instruction) or 16-bit register addition “ADDQ.W #1,D0” are 4 cycles (see http://oldwww.nvg.ntnu.no/amiga/MC680x0_Sections/mc68000timing.HTML ).
    I suspect which is faster between an ~8 Mhz 68000 or a ~4 Mhz 65816 CPU depends on the task at hand (on a level playing field – not SNES vs Genesis systems).
    1. There is a lot of errors, I reported some of them on twitter in reply to the article post.
      This is the kind of bad article that made people believe that the NeoGeo have an hardward zoom. It has no source so it can’t be trusted.
      And unfortunately this article will say on the internet and people will cite it as source elsewhere.
    2. Yes, I noticed that. Clock for clock, the 68000 can compete with a 65816 for several reasons:
      1. The basic instruction cycle requires 4 clocks, not 8; and this includes all word-length register to register arithmetic and logic; frequent immediate cases (such as moveq #n,d0) and 32-bit moves. Even with shifts the 68K has the edge, since it manages multi-bit shifts at 2 cycles per bit (so a 7.3MHz 68K is twice as fast as a 3.6 MHz 65816).
      2. The 68000 has 16 x 32-bit registers and it’s instruction set is double-operand which makes it very versatile. It’s the bandwidth of data that can be pumped through the 68K that makes a huge difference to its performance. For example, the 68K as enough registers for subroutines to be entirely register based whereas the 65816 would need lots of LDA/Operate/STA sequences.
      3. The 68000 can move data around much faster than a 65816 using its movem.l instruction. Movem.l can move up to 12 x 32-bits from source to destination using just (8 cycles * 12 + 8)*2 = 216c for 48 bytes, or roughly 4.5 cycles per byte. A 65816 can only manage 7 cycles per byte.
      4. The 68000 can handle 32-bit arithmetic several times faster than a 65816.
      5. The 68000 is far easier to program than a 65816, it’s easier to squeeze performance from it.
      1. This articles are what some old youtube collectors use to compare both consoles. its so sad when they try to trow shade on each others while forget to talk about the bus and related stuff.
        plus as far i know the 6800 coud accept instructions in C instead assembly only.
  9. The Genesis / Megadrive block diagram has some glaring errors in it that the 68k address bus is 23 bits wide (word access, so really 24 bit or 16MB) and the z80 address bus is 16-bits wide and was mapped into the 68k’s address space.
  10. “…but the faster processor is what allowed the Genesis / Mega Drive to have ‘faster’ games – the Sonic series, for example, and the incredible library of sports games. It’s an argument wrapped up in specs so neatly this conventional wisdom has been largely unquestioned for nearly thirty years. Even the Internet’s best console experts fall victim to the trap of comparing specs between different architectures, and it’s complete and utter baloney.
    If SNES was indeed way more powerful than Mega Drive, and this statement above is utter baloney like you stated, then how come there weren’t fast sports games on SNES. People from the hacking/homebrew scene still didn’t manage to port Sonic to SNES without occasional stutters.”
    1. If the SNES was as slow as some people seem to think, how come it could pull off a game like Rendering Ranger R2 running at full screen, 60fps, with all that action going on with no slowdown or stutter at all, and all while running in its slower 2.68 MHz SlowROM mode no less, so at barely 75% of its full speed/capability?
      If you’ve not seen it, you should check out some YouTube footage, and pay particular attention to the shmup levels. . . .
      1. RR2 doesn’t really do anything the console couldn’t already handle. Slowdowns mainly come from recalculating CPU logic for variables, transferring data (mostly graphics), AI behavior based on the player’s distance, and physics.
        As a spaceship game, there is no gravity simulation, which avoids certain behaviors and calculations like parabolic trajectories with variability or deceleration.
        RR2 also barely performs dynamic data transfers to VRAM; it works in sections. For example, in a level, the first section loads into VRAM all the animations for up to three enemies that will appear during that segment, including all their animation frames. When enemies appear, you rarely see more than two or three different types on screen, since everything is preloaded into the CPU’s graphics memory, including animations and effects. These enemies show minimal animation, their patterns never change, their appearance is always the same, and their disappearance follows a set sequence, preventing them from staying on screen longer than calculated so they don’t overlap with subsequent enemies.
        Bosses are essentially blind. Although some have articulated sprites, their movements follow passive, repetitive patterns regardless of the player’s position. The position tables for these patterns are precomputed, so the CPU simply makes the boss follow the pattern without adjusting for the player’s location or actively pursuing them. This makes bosses much easier to process than an enemy like Seven Force in Alien Soldier, where the enemy not only moves toward the player but also switches patterns based on distance and position while aiming at the player no matter where they are.
        For this reason, the gameplay feels so poor. Obstacles always repeat, entering and exiting at the same time intervals regardless of what the player does.
        Sure, there are moments when lots of projectiles are fired and many explosions occur, although the animations are quite basic. But collisions only need to be calculated when they actually happen. There’s no complex physics for the enemies or the player’s ship, and no dynamic AI patterns.
        Moreover, using a Fast-ROM doesn’t provide a “25%” improvement or anything close. Due to the lack of general-purpose registers, the CPU has to access WRAM more than it would like. Combined with cycle loss caused by its segmented memory, which constantly switches between 8-bit and 16-bit modes, the actual performance boost is only around 12-14% in the best-case scenario.
        1. Very few games from this era required anything resembling “real physics,” so that point is a red herring from the start. Most 2D titles didn’t rely on physics systems at all, and the SNES—like its contemporaries—was never designed with that in mind. The same goes for dynamic VRAM transfers: they weren’t needed constantly throughout a game. In reality, most titles—including RR2—only performed occasional swaps, usually for main characters or specific segments. Presenting this as an inherent shortcoming of the SNES is misleading at best.
          That’s the recurring issue with your selective framing: you’re treating standard hardware capabilities and design choices of the era as if they expose weaknesses unique to the SNES. They don’t. Nearly every point you raise applies just as much to the PC Engine, Genesis, and even Neo Geo, all of which relied heavily on preloaded animations, simple AI routines, and rigid, pattern-based enemy behaviors. The truth is that 99% of games from this generation were designed to run comfortably within the technical limits of their hardware, and with reasonable tweaks could have been built on the others as well—excluding major hardware differences such as total colors, the maximum number of real background layers, very specific special effects, or particular audio capabilities. Suggesting otherwise isn’t careful analysis—it’s selective argumentation dressed up as technical critique.
          The FastROM debate is another distraction. No, it’s not a flat “25% boost,” but that’s irrelevant—the fact remains that it measurably improves performance depending on implementation. What matters, as RR2 itself demonstrates, is that even a stock SNES running SlowROM at 2.68 MHz—barely over 70% CPU throughput—could still deliver technically stunning results: hundreds of colors, true multi-colored transparency effects, three fully overlapping background layers, row and line scrolling, palette cycling, animated tiles, large numbers of sprites, and relentless fast-paced action at a rock-solid 60fps. Titles like Super Aleste, Super Smash TV, F-Zero, Wild Guns, and Super Turrican similarly showcase exactly what the base hardware could achieve—also on SlowROM, with no “tricks,” just smart design within the SNES spec. And plenty of FastROM games do the same.
          So when people try to undermine or dismiss that, it usually comes from one of two places: either an agenda to inflate other systems and their particular capabilities by downplaying the SNES and its own, or a kind of obsessive technophile nitpicking that completely misses the forest for the trees. The bottom line is simple: the SNES could, and did, deliver some of the most technically and visually impressive games of its era, even on plain SlowROM hardware. And it was—and still is—capable of feats that other systems simply could not replicate to the same quality, not even to this day. Pretending otherwise isn’t insightful analysis—it’s sophistry.
          Note: None of this is meant to diminish other systems or deny that they all had their own strengths. It’s simply a response and counterbalance to the distorted narratives circulating today about classic consoles—especially the persistent attempts to downplay the SNES—often driven by bitter, disingenuous voices with, I believe, very misguided agendas.
          1. I am going to reply point by point because I see too much theory, very little practice, and quite a lot to correct:
            No. You are wrong when you say that “few games simulated physics.” In fact, every single platformer needs at least to simulate it with the jump action. A jump implies calculating in real time algorithms for vertical velocity, acceleration, deceleration, inertia, and collisions. This is considerably more costly than what we see in a space shooter, where the ship only moves along two axes (X,Y) with constant speeds. Less variable CPU load helps maintain performance in this type of game.
            When I speak about on-the-fly graphic transfers, that is when you can really see if the system is being pushed to the limit. A dynamic VRAM exponentially increases the amount of data beyond the limited 64KB of VRAM in these consoles, which helps display more animations and therefore smoother ones. This depends both on the maximum transfer capacity of the 8-bit bus that the SNES has and on the programmer’s skill in carrying it out as efficiently as possible. Keeping a series of tiles preloaded in VRAM and showing, as the game does, very poorly animated enemies and explosions where the player can literally count the frames just by looking, is not pushing the machine to its limits, it is simply doing what the machine is designed to do. There are SNES games much more technical in this respect, such as KI, that push those on-the-fly transfers to the limit in order to show smoother animations and a more efficient transfer routine.
            No. I have not exposed weaknesses as such, but the reality as shown in the game. And no, neither SNES, nor MD, nor PCE, nor Neo Geo worked the same in this regard, since each one is limited by a physical bus and by its own communication capabilities with the rest of the components. The one with the greater bandwidth can transfer more data in the same frame of time, which therefore leads to substantial differences in the animation capabilities of these consoles.
            Also, yes, there are shooters or action games that pre-calculate the appearance of enemies. The technical difficulty is not there, but rather in the fact that those enemies’ actions vary in pattern, speed, or movement when calculating variability based on the player’s distance (enemies that chase, homing projectiles, actions depending on distance). And whether you like it or not, we very rarely see that in RR2, whereas there are games both on the same console and on others where you see that much more often. I am not disguising anything, anyone can see it for themselves by playing the game, and due to these very pre-calculated routines it becomes something boring because of the little or no variability in what it shows.
            I already mentioned the subject of FastROM. Now you mention that the difference is 30 percent when it is 25.14 percent. Please keep these basic calculations precise so as not to mislead people: the difference between 3.58 MHz and 2.68 MHz is 25.14 percent.
            I also mentioned that the benefit of FastROM is for access to the ROM, while other components (such as WRAM @ 2.68 MHz, DMA @ 2.68 MHz and SRAM @ 2.68 MHz) remain at the same speed. Giving an explanation that does not mention this and says “running at 70 percent of its capacity” is not only misleading but also ignores that the improvement will depend on the specific game or instruction at a given moment, depending for example on how many times RAM has to be accessed. An argument as poorly detailed as the one you propose is like someone saying “SNES has 128 sprites.” Yes, but at what cost: being limited to a maximum of 2 sprite cell sizes, and when trying to optimize a metasprite you waste many, but if you do it with fewer you waste VRAM and sacrifice many pixels per line, etc.
            And yes, there are SlowROM games that run very well and are efficient, nobody here said otherwise, but each game has its own engine and specific requirements. Saying “this game runs well at 2.68 MHz so all games at that speed will run well” is simply a fallacy. It depends on the needs, moments, and scenes. Comparisons with that type of argument tend to be vague and do not give a real verdict on what may be happening in another game, even if at first glance they may seem similar, as happens with Smash TV and Xeno Crisis. One handles a static VRAM with very few animations and the other is constantly transferring tiles each VBlank showing much more animated characters and effects.
            No, I am not disparaging RR2. What happens is that there can be a narrative that later, at the technical level, is not comparable with the myth that is created. Yes, it shows prerendered spaceship scenes. Yes, it shows many objects in specific spots with lots of explosions. But at the code level, preloading tiles, precalculating positions, not having elaborate physics and having a set of pre-established nametables is not something that makes me say “it is making the machine do the impossible.” It is doing what the machine is supposed to do, with a good result in terms of performance. You mention again a title for comparison, but take a look at F-Zero:
            F-Zero shows a maximum of 4 ships on screen, that is all the CPU has to focus on: their distance and physics. Only 4 objects. Why would it need to run at 3.58 MHz if at 2.68 it already works fine? The calculations of displacement matrices and map angles are handled by the PPU, so it does not need more. That is why, as happens with Mode 7 demos on MD, those arithmetic calculations fall on the CPU since the VDP does not have the capabilities to perform them. So although it achieves a similar effect, it will not do it with the smoothness and performance that the SNES does in that aspect.
          2. I’m not sure why there’s no option to reply directly to your other comment timestamped August 17, 2025 at 5:47 pm, so I’ll post this here. I thought I had already responded to that comment, but it doesn’t seem to have gone through—so here’s the next try:
            I’m not even going to address that last post point by point: https://hackaday.com/2015/11/06/winning-the-console-wars-an-in-depth-architectural-study/#comment-8164711. There’s a lot of selective framing, misdirection, sophistry, and even some outright falsehoods in it. Go ahead—keep pushing whatever narratives you like. You’re really talking to, what, ten people here if you’re lucky?
            Go ahead and waste your breath trying to convince the world that “Genesis Does” because of “Blast Processing.” You can’t change history. The SNES outsold the Genesis by around 15 million units, had a total library roughly twice as large, boasted more than double the number of million-selling games, and its top titles outsold the Genesis’ best by millions. Even today, more of its games appear on “best of all time” lists.
            The reality is that everyone outside a tiny circle of hardcore nerds has moved on to far newer and more powerful consoles than these systems, which are literally over three decades old. That’s because most people aren’t stuck in the past and actually have the choice. A few, however, are stuck living on the fumes of old systems from a company long since dead in the console hardware business, desperately clinging to tired and childish console wars and trying to rewrite history to soothe their bruised egos after their company of choice lost literally every single battle between these two giants, in both home consoles and handhelds.
            But hey, the Genesis is seeing more new games these days, so fans still stuck there can feel a bit better about that. For everyone else, life goes on with the likes of modern Switch 2 consoles, enjoying titles like Donkey Kong Country Bonanza and the rest—including most of the great Genesis and SNES games, old and new. The past is what it is, and some things—like history—can’t be rewritten. But hey, keep fighting that good fight if it helps you cope.
            From now on, every reply you make to me will be met only with a reminder of why you feel compelled to do so—because it’s all about Blast Coping with something that happened over three decades ago. Nothing more.
        2. PS. The answer to my original (pretty obviously rhetorical) comment wasn’t complicated at all, and it certainly didn’t require the wall of text you spewed out.
          The simple answer should have been no answer at all—or something short and to the point, like:
          “The reason is because the SNES isn’t as slow as some people think.”
          Done. That’s it.
          But for some reason, you couldn’t leave it at that. And unlike my reply—where I never once tried to diminish the Genesis or any of its games—you couldn’t resist taking shots at the SNES. Same with the other guy.
          Notice again: my comment didn’t drag the Genesis down in any way. I simply defended the SNES.
          Do you see the difference?
          That’s the textbook definition of Blast Coping.
          1. Once again, zero arguments to what I said, just a diversion to “random” topics, with no refutations, data, or evidence. Yet again, a tantrum in the face of facts and data. Another medal for a debate you don’t know how to continue.
          2. Your arguments selectively frame technical details to inflate the Genesis and downplay the SNES, cloaking revisionism and sophistry as objective analysis. It’s not about facts—it’s Blast Coping masquerading as discourse.
          3. And, in connection with your other comment, the same applies here too:
            By bringing up things I’ve said on other sites—twisting and reframing them as needed—you’ve shown yourself to be part of the group that’s been cyberstalking, harassing, doxxing, trolling, and trying to deplatform me for years. The same mob that got a YouTuber’s channel removed before monetization—and even bullied a well-known SNES developer to suicide.
            Your arguments here aren’t genuine. They’re part of a long-standing pattern: obsessively tracking me across platforms and attacking everything I say under the guise of “debate.” This isn’t normal discourse—it’s a disturbing pattern of deranged behavior.
            As I said, at the end of the day, it all comes back to Blast Coping.
          4. Stop playing the victim and lying. If it were really so easy to “disprove my arguments that aren’t real,” you would have already found a way to do it. The fact that you haven’t means you can’t, because I haven’t lied in them, and now you’re just playing the victim.
            I came across this article by chance, and then you showed up with a thousand and one pieces of misinformation that you can’t handle, data that confuses people, and numbers you can’t even calculate yourself. Is stating that a CPU has higher performance, demonstrated with calculations and facts, lying?
            Please, the victim tears only reinforce my arguments. Thank you very much for confirming, through these kinds of tantrums you put on, that my points are even more valid.
            Now, keep crying as much as you want.
          5. Your bitter and disingenuous attempts to undermine the SNES, driven by long-standing hostility toward me and the endless axe you insist on grinding, are nothing more than another outburst of your unresolved rage over a years-old dispute and your perpetual Blast Coping.
  11. SNES was obviously more powerful, but so it should have been. It was two clear years newer. It wasn’t night and day though and so much relied on what the developers could get out of the machine. The fact Genesis got to market two years before was a bigger advantage than launching later to have better specs, but having to fight the hype of the SNES.
    1. Genesis sales didn’t really pick up until 1991 when Sonic came out. As for ease of programming, Konami’s first game was Bloodlines and I think they hit the ground running without to much effort.
  12. The SNES does not run at 1.79 MHz (and just straight listing it the way you have here will be misleading for a lot of people). You don’t count the miniscule amount of time it drops to 1.79 MHz while it polls a controller, which is about 0.1% of the time, as the speed of the system when stating numbers like this. The SNES is a 3.58 MHz console be default, with the one meaningful caveat being that it would be gimped to run at 2.68 MHz if the developer/publisher cheaped out and went with a SlowROM cart rather than a FastROM cart. But that’s a case of the cart artificially slowing down the system below its default speed than a speed limitation of the system itself. Again, the SNES’ CPU speed is 3.58 MHz (ignoring the artificial gimping by cheap developers). That’s the correct figure that should be stated in this comparisons.
  13. I was going to list all the errors you made but what’s the point.
    If you’re interested ‘blast processing’ means you can modify the video ram during ‘active display’ as opposed to ‘h-blank’ and ‘v-blank’ which has little practical application.
    But the reason the Mega Drive is far more powerful than the SNES is due to the integrated nature of the system, namely the location of the DMA (memory management unit) being inside the VDP, which gives the sound and video ram direct cartridge access – bypassing the cpu bus. This allows graphic and sound information to be transferred without interrupting the cpu operation or work ram bus. In addition to this, the bus is 16bits wide (for graphics), runs at a faster transfer rate, with a faster cartridge rom data transfer speed.
    The SNES architecture is not integrated, so transfer of graphics and sound data will require the cpu to halt operation until the dma transfer has completed.
    So what you said was the opposite of correct. It’s the other way round.
    When it comes to sprites, the Mega Drive handles about 20% more on screen (also much more unique) and it’s 13Mhz vdp is much more capable than the SNES 5Mhz PPU sprite pusher.
    The SNES has 15bit colour and 8, 4bit pallets to the Mega Drive’s 9bit colour and 4, 4bit pallets. So SNES tops out at 128 colours on screen to 64 for the SMD. Is that a measure of power? Arguably. But the overall system works around 20-30% more slowly than the Mega Drive and I’m being conservative.
    1. Look, I know the Genesis is more capable under the hood in many ways that the SNES, but you should at least get the most basic stuff about SNES right.
      For example: The SNES can display anywhere between 128-256 colours for the backgrounds depending on the background mode used. And it has 128 colours always dedicated to sprites, which are shared with the backgrounds when the background is using one of the 256-colour modes, but otherwise are completely independent and on top of the background colours. And that’s before any colour math and the like is applied.
      SNES typically has twice as many colours available for backgrounds alone than the Genesis has for backgrounds and sprites combined, and it had twice as many colours available for sprites alone than the Genesis has for backgrounds and sprites combined, which can make a huge difference in the right hands. But, generally speaking, the SNES tops out at 256 colours total onscreen vs the Genesis’ 64 in standard/typical use for both consoles, which is four times as many colours onscreen for SNES.
      And that’s just one thing many of these SNES vs Genesis bullet point lists usually written by Genesis fans tend to get wrong half of the time.
      1. The SNES has 8 colour pallets as far as I can tell, which are generally 4bit/16 colours. But depending on the mode, those pallets might also be 2bit/4 colour or 8bit/256 colours. Modes 3 and 4 have the 8bit pallets, which I’m thinking is just 1 pallet, which applies only to the first background layer (of two) and not the sprite layer. The second background layer is either 4 or 2bit respectively. I don’t actually know how many pallets are available here for each respective layer. But given that 8bpp is 256 colours and the low bit second background layers must use different pallets I can only assume that the 4 and 2bpp pallets must choose from colours already selected in the 8bpp pallet/s. Otherwise the colour count would exceed 256.
        In a way, the SNES modes are a bit of a mess. You can have more of something like layers but less bits per pixel in the background pallets and a loss of things like column scrolling.
        I’m assuming the SNES has 8 pallets but there’s no information on how many are available for the respective modes. I think this number may vary.
        But if there is only 1 pallet available in 256 colour mode (which as 8bpp is 256 colours this must be the case, because two 8bit pallets would be 512 concurrent colours), this is allowing greater colour depth, but then you have to choose all your colours from that pool of 256 colours (without swapping the pallet) every time you want a new colour, rather than choosing from the full 15bit/32k colour space.
        It is saying that mode 0 has 4 layers of 2bit/4 colour pallets with 32 colours available per layer, which is 8 pallets per layer. But it’s not saying if each layer has access to an additional 8 pallets, making for a total of 128 colours. I’m assuming it is.
        Mode 7 is also using a 256 colour pallet for the background transform layer but it looks to be direct colour. The foreground sprite layer appears to have access to 8, 4bit pallets, but this might actually be less.
        So yeah. 256 on screen colours is theoretically possible. But only on one background layer. Then you are unable to select from the master pallets as 256 colours is the limit of it’s capabilities and as it’s just 1 pallet, your other sprites or tiles are unable to choose new colours from the wider 15bit colour space. I doubt any games ever used the 256 colour pallet modes 3 and 4 honestly.
        In fact I think 90% of games ran in mode 1, which is three background layers; the sprite layer at 4bpp (bits per pixel) and bg layers at 4 bpp, 4bpp and 2bpp/4 colours.
        Again, I’m not sure what’s happening with the available number of pallets here, it’s possible that layer 3 is taking say, 2, 4bit pallets and dividing them into 4, 2bit pallets. I have no idea. But 8, 4bit pallets is 128 pallet entries. Even though a background layer in mode 0 (4 bg layers) is only 2bpp per layer, I’m guessing that layers 1 and 2 (mode 0), at 4bpp are sharing 6 pallets and layer three has split 2 pallets into 4. The table I’m reading just has question marks.
        The table has colour count at 121 though, and not 128. I guess because the first pallet entry is always transparent, except for the pallet for the bottom layer of background tiles.
        The Mega Drive has 61 colours available, with 2 background layers, compared to mode 1’s 121 colours over 3 background layers.
        It’s also notable that the Genesis has the ability to swap it’s pallet much more easily and speedily than the SNES. This doesn’t represent additional concurrent colours, but does offer more potential for animations and effects such as pallet cycling.
        Then the SMD also has shadow and highlight. A pallet entry can be selected as a shadow or highlight and tiles or sprites with a lower display priority will be darkened or lightened when the pixel with that setting passes above them.
        Then the SNES has transparency. This isn’t something I have a deep understanding of but you can’t use it willy nilly. You will still see a mesh pattern used in games to simulate transparency. This increases on screen colour count though, above the standard 121. As does colour overlay shapes, dubbed ‘window’ mode which allows colour math of additive or subtractive for the layer, ‘window’ (shapes using hdma) or the whole screen. This significantly increases on-screen colours. Pallets 4-7 only are affected by colour math.
        So the SNES can output a lot of colour from an impressive 15bit pallet. It can actually display alot more than 256 colours at once.
        There is the option for direct colour, bypassing the pallets completely, giving you over 2000 colours to select from. I don’t know if any games used it.
        But when it comes to directly selecting colours from pallets, in practice, it is, for the vast majority, if not literally every game, 121 colours maximum (not allowing for blending effects).
        The standard pc 8bit vga card is frankly superior. With a pallet space of just 256 total colours, without the burden of pallets, the pc gamer enjoyed clock speeds over 33Mhz, making sprites and pallets unnecessary, allowing no limit to what pixel could display what colour where and when.
        1. Again, some good stuff, but there’s a lot of people clearly not fully understanding what the SNES is actually capable of, so, what I’ll do is just post a couple links to articles I wrote myself that go over all the background stuff I’ve learned over the last couple of years, including how all the colours work around that, and even one listing some of the things the SNES objectively does better than Genesis:
          https://inceptionalnews.wordpress.com/2022/08/26/snes-background-modes/
          https://inceptionalnews.wordpress.com/2022/11/04/nintendoes/
          And I’ll post this video just to show how much something ilke Mode 3’s 8bpp 256-colour capability is largely ignored and/or misunderstood by both SNES fans and haters alike.
          And I’ll also post this in response to one of your previous VDP comments too:
          https://youtu.be/r7Jh_izIc8Q
          Because we all know the Genesis has the fast CPU, but that’s not the complete picture, and most people never get to hear much of anything else around this stuff, which isn’t a fair and equal discussion with all the facts present.
          Note: I’m not trying to knock the Genesis, which is a powerful little system and very capable under the hood, but more just stop this basically false narrative and re-writing of history that’s happening in modern times, where a bunch of hardcore Genesis fans try to manipulate everything to basically say “Genesis does everything better than SNES and/or can just fake it with it’s godly CPU and whatever else”. Not that you’re doing that here, but I’ve just seen it enough now that I feel compelled to point it out any time I read anything posted by some hardcore Genesis guy.
          I think the SNES is a lot more capable than the current narrative around the Internet is leading and allowing people to understand.
  14. “This means the Sega could handle around 900,000 instructions per second, maximum. The SNES could compute around 1.7 Million instructions per second, despite it’s lower clock speed. Even though the Sega console has a faster clock, it performs fewer instructions per second.”
    Is there some concrete way you can describe how this actually benefits the SNES over the Genesis, maybe using an example or two of how it would actually work in practice in a game or whatever, that even a layman can understand?
    Because, on the segaretro site comparing all the Genesis specs and numbers with SNES, there’s no real mention of this that I can see, and it just makes it seem like the Genesis is basically faster/better than the SNES across the board (other than the typical stuff like colours), so anyone reading that would obviously assume it actually is a clear-cut win for Genesis and the SNES doesn’t even come close in any related spec around speed and such, which seems a little misleading if the number you mention is actually important.
    So, I’d just like to get an idea of how being able to calculate all those extra instructions per second practically benefits the SNES and maybe at least compensates for all the other under-the-hood and very low-level figures that seem to be in Genesis’ favour.
    1. Numbers can be misleading. For instance, SNES has 128KB of work ram, of which only half is accessible at any one point. But tables don’t mention that.
      It suggests the SNES has 256 sprites at 64x64px. But it actually only has 17 sprites at 64×64 and 128 sprites at 8x8px maximum. The Genesis has 80 sprites at 32x32px to the SNES’s 32 sprites at 32x32px.
      The SNES audio DSP runs at 2Mhz, but the chip is capable of 22Mhz, but only the later number is mentioned on the SNES wiki page.
      The SNES cpu is also capable of 21Mhz, but must operate at a speed within the capabilities of the data bus to w(work)ram. Which is a nominal 3.6mhz if a fastROM cart is used when accessing the bus (nearly always).
      Old consoles slow down to the speed of the slowest component. In the case of the SNES, this is the bus. Data transfers use clock cycles. You have transfers from rom to w(work)ram, a(audio)ram and v(video) ram, wram to vram and aram. Then, to animate the sprites you need a constant stream of updates to their co-ordinates (sprite attribute table). The SNES cpu has no free time.
      Transfers to aram and vram take a relatively long time due to the speed of the data bus and can cause pauses when loading.
      You can queue 8 dma requests. But they don’t transfer in parallel.
      Even at low clock speeds, the SNES cpu might outperform the 68K in certain operations. But that’s not indicative of a real world scenario when running a game requires the cpu to perform numerous tasks at once.
      Then if you have 16bit instructions, the 8bit external pipeline requires two cycles to perform the transfer.
      The above article is riddled with mistakes. The diagrams he made are quite wrong.
      Theoretical benchmarks offer no real indication of performance in practise. You can write a 10 line program to demonstrate how quickly a chip handles that one thing, but it’s not useful in gauging overall performance in practise.
      More important than clock speeds or Kbps bus speeds is architecture. How easy is it to program? Old consoles aren’t like modern computers. There’s no operating system. Just a simple program to initialise the various chips and establish a connection with the cart rom. The rest is up to you. The snes is fiddly. You have to manage it’s memory in small chunks, there are a lot of rules. The 65C816 cpu in the SNES has fewer ‘registers’ and ‘addresses’ at smaller bit width than the 68K cpu (I can’t find out how many), making programming complex things more convoluted and the ‘instruction set’ (which is basic cpu commands), is also more limited. You have to work a lot harder to get similar results. So in the end, the games run slower and are less complex.
      I would say that if you want an indication of the superiority of the Mega Drive, to consider Westwood’s Dune 2. The SMD can keep track of a full map of units and bases, handle ai and all those variables and put out a killer soundtrack.
      There’s nothing on the SNES that compares to that level of complexity. I’m not saying the SMD is straight up better, but there’s nothing on the SNES that compares to that feat of engineering.
      I should mention that in an earlier post I stated the SMD could access the rom without interrupting the cpu. Not the case. Both systems must consume cpu cycles for dma transfers apparently. I’m still not entirely clear on this point.
      1. I think one problem here is this automatic assumption among Genesis hardcore types that more technical complexity in a game is better than more visually beautiful art, nicer sounding audio and better controls for example, which might be true from some programmer mentality point of view or to help with some online fanboy arguments, but it really isn’t from say an artists or typical gamers point of view.
        And the “slower” thing would be as important to both consoles, but, your assertion that SNES games run slower is a false correlation to causation statement certainly largely based on a bunch of games running in SlowROM and with badly optimized code, because, as long as a SNES game is designed and programmed properly, it will run at the max 60fps that both these consoles are capable of. You can’t make the Genesis run any better than that, no matter how hard you try.
        Now, again, you could argue the Genesis can throw around more stuff calculating more complex physics and so on, but, once again that assumes some technical achievement is more paramount that the art, audio, gameplay and control achievements. That’s not an objective truth. I mean, you might have chosen the Genesis over the SNES back in the day because it had more explosions in Contra: Hard Corps or whatever, but literally multiple millions more people chose the SNES specifically because it had nicer looking visuals in general, prettier explosions, better audio, and better controls in Contra III or whatever. So, have the win in CPU speed and some random other technically stuff under the hood (although definitely not all of it for sure). But I’m taking the win in terms of most of the stuff that comes out the other end in the ways that most people actually care about. You can have Dune II’s many units, and I’ll take Donkey Kong Country 3’s near Pixar level of visuals and similarly brilliant audio plus top tier controls and gameplay: https://youtu.be/I7kJCfuHSwY?t=3570
        I guess it comes down to what you actually think you’re winning at the end of the day, because, by almost every single meaningful metric that I can see, the SNES simply won the console war: It sold more consoles total, by around 15 million units, it has more million+ selling games (49 vs 18), it’s biggest selling games sold more than Genesis’ biggest selling games (20.6 millions for the top seller on SNES vs 15 million for the top seller on Genesis), it objectively has a better controller (demonstrably so), more of its games still appear in almost every Top 100 list than Genesis, It has prettier looking visuals for the most part, it [arguably] has nicer sounding audio for the most part, it has 1757 game vs Genesis’ at roughly 878, the SNES most beloved games and characters (Super Mario World, Super Metroid, Super Mario Kart, A Link to the Past, Donkey Kong Country, etc) are still having far more influence and impact on the industry even today than the Genesis most beloved games (Sonic the Hedgehog, Streets of Rage 2, Gunstar Heroes, Thunder Force IV, Phantasy Star IV), even the recent SNES Classic Mini sold 5.28 million units to the Genesis Mini’s roughly 300,000, and, just like the Genesis does a bunch of stuff under the hood better than SNES, SNES still also does a whole bunch of stuff under the hood better than Genesis, etc.
        So, you know what, I guess I can understand why all these random tech-specs are so important to the most hardcore Genesis fans in modern times.
        1. At least you understand, unlike the writer of this article, that the SNES is not more powerful than the Genesis. It has more colour. You even said it’s sound was “arguably” better. Which is more than most SNES proponents would concede. Genesis sound is never considered even arguably, on par with SNES sound.
          If you prefer the sound of the SNES and consider colour more important than other factors the Genesis is better at, that’s fine,
          But you’re not claiming, like the article writer is, that the SNES is more powerful.
          1. Well, let’s not get carried away, as there are many things I consider better about the SNES other than just the colours. Yes, it can display 4x as many colours on-screen, chosen and divided into smaller palettes from a master palette that’s a whopping 64x larger, but it also has up to twice as many backgrounds, proper colour math or transparency, a more cycle-efficient CPU, a more efficient VDP, can process more total sprites on-screen, more [8×8] sprites per scanline, has a higher max resolution (512×224 vs 320×448), has superior column scrolling (down to every 8 pixels vs every 16 on Genesis), has built-in mosaicing, has built-in window/shape masking, has larger max size in-built sprites (64×64 vs 32×32), has HDMA that allows for a range of easy effects such as display smooth background colour gradients, updating background line/row scrolls, and updating both Mode 7 backgrounds and window/shape masks per scanline, indeed has built-in background scaling/rotation/shearing for some stunning pseudo 3D effects, can have more unique background tiles and larger tilemaps than Genesis when using certain background modes, has superior audio capabilities when it comes to PCM specifically (which the Genesis can also do, but just not as well), can do surround sound (Genesis can’t), has 8x as much audio RAM, has twice as much work RAM (128 KB vs 64 KB). And, beyond tech-specs, it has a superior controller (which comes as standard for all SNES owners in the box), has a library of games that’s over twice as big (around 1700 vs 800), and I and most other critics consider its best games to be superior to those of the Genesis, hence why so many SNES titles still appear in every Top 100 Games of All Time list and usually almost none or indeed no Genesis games do, etc.
            The Genesis has many of its own strengths and advantages too, like a faster CPU speed, higher standard resolution, more versatility with how it uses the VRAM between sprite tiles and background tiles, can show more sprites [above 8×8] per scanline before flicker, etc.
            But, to just say “SNES has more colours” and leave it at that is totally disingenuous, and I think you know that fine well.
            If what you care about is pure tech-specs, you can well argue in favour of the Genesis in many ways, and equally in favour of the SNES in many ways too. If you actually care about what comes out the other end though, from the visuals and audio to the controls and gameplay, and indeed the library of games on each console, you’d be hard-pressed to convince the 49.1 million original SNES owners [and most other people for that matter] that the roughly 35 million original Genesis owners picked the better console of the two.
            So, make of that what you will.
          2. Also, just to add something else into this discussion that I only truly understood recently about the so-called “Blast Processing” of the Genesis:
            https://inceptionalnews.wordpress.com/2022/12/12/blast-processing-the-reality/
            Both Sega and indeed many Genesis fans have been using basically lies for decades at this point to convince SNES fans of things that simply aren’t true. They’re designed to oversell the capabilities of the Genesis and undersell the capabilities of the SNES. And this goes beyond just “Blast Processing” too.
            Well, given the chance, I’m here to correct some of those lies and spread a little bit more of the actual truth.
            The funny thing is that, when you learn about “Blast Processing” and see it for what it actually is, it turns out the SNES is just superior there in most use-cases, because, not only does its 8bpp 256-colour Mode 3 [and Mode 4] produce nicer looking higher-colour images overall than the Genesis’ infamous “Blast Processing” method, but it can do so with background tiles to spare, with indeed a whole extra background layer too, where it can still scroll both backgrounds for added parallax, can use all the normal sprites at the same time as well, the CPU isn’t stalled in the slightest, the sound processor isn’t stalled in the slightest, etc. SNES’ standard Mode 3, it turns out, is, in a typical use case, just plain superior to “Blast Processing” basically across the board. Go figure.
            It’s much like how most Genesis fans says “The Genesis CPU is much faster than the SNES slooow CPU, at 7.68 MHz vs 3.58 MHz”, yet conveniently forget to mention that:
            “While the Genesis has a faster clock rate, it take multiple cycles to do instructions. The quickest instructions take four cycles, and you can quickly run over a dozen cycles by working on longs and using certain addressing modes. In contrast, the 6502/65816 tends to do most instructions in one or two cycles.” – http://gendev.spritesmind.net/forum/viewtopic.php?f=22&t=3339#p37767
            That’s an important factor to just leave out of the discussion.
            Now, how many times do you wanna bet that similar claims about Genesis being “superior” in some area, which most people haven’t really bothered to either learn about in depth or indeed directly test and compare themselves, will actually turn out somewhat similar. . . .
    2. I am not surprised to have read so many absurdities if, to begin with, you do not know how to calculate MIPS or the cycles that one processor or another can handle in the same time frame. Let’s clarify this because anyone who comes in and reads several of the things mentioned could have a heart attack.
      The calculation made by the author of the article overlooks many things and assumes too much without doing the math:
      The MIPS of each CPU depend on the average instruction length and the processor clock speed.
      Since there are some 8-bit instructions (important to emphasize this) that require 2 cycles on the SNES, he took that average and placed 1.7 MIPS as if that were the norm. What kind of madness is this? And why not take the 4 cycles that several 16-bit instructions of the M68K require and do the same? That would give 1.9 MIPS.
      No. Instructions vary depending on each instruction. The 65C816 executes most instructions in 2 to 7 cycles (mostly 8-bit, or hundreds of cycles if it has to perform 16-bit multiplication or division with variables). Being very generous, this results in 0.4 to 0.6 MIPS in practice.
      The Motorola instructions of the MD vary between 4 and 20 cycles for the longest ones (all 16-bit) and performing a realistic average, the result would be a total of 0.8 to 1.2 MIPS, that is, 1 MIPS on average.
      Then we must consider not only the number of instructions. What about the cycle speed of each processor? Exactly. MD cycles execute in 130 ns while SNES cycles vary: FastROM 279 ns per cycle, SlowROM 372 ns per cycle.
      Let’s take an example:
      1 8-bit instruction on the 65C816 that requires 2 cycles executes in 558 ns.
      1 16-bit instruction on the M68000 that requires 4 cycles executes in 520 ns.
      Here it is clear that the Motorola 68000, despite using more cycles, is transferring more data (up to 16 bits) in less time even though it uses more cycles.
      A practical example to understand this: We have two bakers, both baking bread. One of them has to go to the oven 2 times to bake a loaf, the other baker goes up to 4 times. The baker who goes to the oven 2 times completes his task in 15 minutes, while the baker who goes 4 times takes 10 minutes and the bread he bakes is larger.
      Which of these two bakers is more efficient? The one who takes 10 minutes regardless of the number of trips to the oven, because within an hour he can make up to 6 loaves. While the other makes 4 loaves in the same hour and they are not as large.
      So the important thing is not MIPS, nor MHz, nor cycles, but the whole system: the sooner you finish a task, the sooner you can perform another.
      The SNES CPU has several elements that prevent it from being as efficient as the Motorola:
      1.- Due to the lack of general-purpose registers, it constantly has to access RAM. It has only one 16-bit accumulator and two indexed accumulators (X and Y), while the Motorola 68000 has 16 general-purpose 32-bit registers (D0–D7, A0–A7) capable of performing calculations, which avoids frequent RAM access and reduces the cycles needed for each task.
      2.- Segmented memory. The 65C816 cannot address all 24-bit linear memory at once. Instead, it divides memory into 64 KB segments and uses a bank register to select which segment you are working on. Bank changes require extra cycles every time you switch. This is far less efficient than the M68000, which can address its full 16 MB linear space directly without changing bank registers. This allows faster data movement, keeping more variables in registers, and writing more compact loops.
      3.- The 65C816 constantly has to switch between 8-bit and 16-bit modes depending on the instruction or code. Each change is done with REP #$20 or SEP #$20 and consumes 3 cycles. These modes allow flexibility and compatibility with old 6502 code, but they add cycle overhead, slowing down tasks and reducing the number of tasks completed in the same time frame as the M68000.
      4.- The 65C816 lacks instructions like MULU or DIVU (multiplication and division) that the 68000 has. This means you can multiply or divide two registers directly in a single instruction without building manual algorithms. On the SNES, complex calculations such as multiplying two 16-bit numbers require a software routine iterating additions and shifts, which involves many instructions and cycles just for one operation.
      Where is this reflected? In physics, AI, and game logic tasks that require complex multiplication or division. This is much more costly on the SNES, even if the CPU had a similar or higher frequency. These calculations are often used for articulated sprite bosses where the AI constantly calculates the player’s variable position. That is why many bosses in Alien Soldier interact in such spectacular ways.
      For this reason, when you ask:
      “Is there some concrete way you can describe how this actually benefits the SNES over the Genesis, maybe using an example or two of how it would actually work in practice in a game or whatever, that even a layman can understand?”
      You are already implying what you are looking for from a feature. In fact, asking for an explanation for those who do not understand this well makes me wonder if I am wasting too much time explaining clearly. But just as the Mega Drive cannot approach the SNES master palette in color, in terms of performance and low-level CPU, you will hardly find anything real or concrete where the SNES CPU can outperform the M68000.
      1. Genesis Trivia:
        How does the Genesis show 256 colors from a palette of 32,768 on-screen?
        How does it display over 2,000 colors on BG1 alone, plus 128 15-bit colors on BG2, and another 128 15-bit colors for sprites?
        How does it manage full multi-colored transparency on both backgrounds and sprites?
        How does it display four real, full-screen, fully overlapping background layers without trickery or using sprites?
        How does it implement two color window masks for some lovely visual effects?
        How does it achieve column scrolling with 8-pixel precision?
        How does it perform full-screen mosaicing?
        How does it display 32 sprites per scanline?
        How does it run in 512×448i resolution at 60fps?
        How does it rotate and scale a full-color, full-screen, full-resolution background layer at a solid 60fps?
        How does it support Dolby Surround sound?
        All of this is achieved on Genesis via Blast Coping.
        1. At this point, it’s beyond clear that these discussions always circle back to obsessing over random tech specs on one side of the aisle. It’s how certain people cope with what went down more than three decades ago.
          Not only do they rarely acknowledge the many ways the SNES outclassed the Genesis—a number of which I listed in my previous comment—but they also conveniently and consistently ignore aspects that almost no one talks about. For example, using the SNES’s 2bpp layers multiplies its capabilities in several ways: increasing the number of true background layers to double that of the Genesis, doubling the amount of unique background tiles it can store in VRAM compared to the SNES’s regular 4bpp modes, and even doubling the number of new background tiles it can stream in per frame. That’s just one example.
          Meanwhile, they bury their heads in “operations this” and “instructions that” as a form of Blast Coping. But the fact remains: the SNES outsold the Genesis by around 15 million units, had a total game library roughly twice the size, and boasted nearly three times as many million-sellers. Its biggest hits outsold the Genesis’s biggest hits by millions. Beyond that, the SNES left a far greater mark on the industry—creating entire genres like kart racing, defining the “Metroidvania” genre, and setting the controller standard that still exists today with its diamond-shaped four-face buttons, shoulder buttons, iconic D-pad, and Start/Select layout. Decades later, more SNES games still appear on “Greatest Games of All Time” lists than Genesis titles.
          And this is why they try to distract everyone with misrepresented numbers on paper—like claiming “the Genesis CPU is twice as fast as the SNES’s, at 7.68 MHz vs. 3.58 MHz”—even though the raw numerical difference doesn’t remotely reflect how the CPUs actually compare in real use. But that’s not what matters to them. What matters is pushing their narratives to make themselves feel better. It’s also why they focus so heavily on aftermarket releases—because that conveniently lets them ignore the literally hundreds of SNES ROM hacks (far more than on any other console of that era), the dozens of direct NES-to-SNES ports, major new hacks like Super Metroid X-Fusion, and the many other ongoing developments in the SNES scene. That includes not only brand-new aftermarket games, but also major upcoming releases like the enhanced edition of Doom—complete with rumble support and an all-new dedicated SNES rumble controller.
          What they want you to focus on is a very selective set of numbers on paper, plus the Genesis getting more aftermarket releases thirty years later—because that’s the easiest way to make you forget history and push their revisionism.
          In the end, it all comes down to Blast Coping.
          1. No. This is not about what happened three decades ago, nor about any argument you want to use to divert attention from my comment:
            In your first comment, you took for granted a difference in MIPS between both processors where you saw a specific CPU advantage for the 65C618 over the M68000, and you explicitly asked for a “for dummies” example of how that supposed higher MIPS difference on SNES, which you believed to be true, would actually affect a game.
            The first thing here is that you are projecting what you yourself argued when you said “it’s beyond clear that these discussions always circle back to obsessing over random tech specs on one side of the aisle.” In this case, you are the one obsessed with that aspect, and it shows in your arguments. But in this case, since you don’t know how to measure MIPS, count cycles, or understand what really matters in terms of performance to evaluate processor efficiency, you revealed the kind of narrative you are trying to spread—but you made the mistake of looking for that weakness exactly in the area that is Mega Drive’s clearest strength.
            You talk about Mode 0, its advantages, and its “incredible” virtues, when, out of an approximate total of 1800 games, only 2 actually used that mode in gameplay. In other words: only 0.11% of the official library used that mode in gameplay. Something that can be done through priority control of the layers in Mode 0, while preserving the amount of color and detail lost with Mode 0, will always be more appealing artistically. Your obsession with that display mode is based on speculation and real impossibilities, such as trying to use it in a fighting game with two layers as fighters instead of sprites. As you already confirm with those statements, you don’t understand how restrictive those BGs can be for animation. And I’m not saying Mode 0 has no use—of course, for an effect at a given moment, you can always find a utility—but it’s no coincidence that programmers preferred to work in the console’s far more interesting graphic modes.
            Then you start talking about commercial sales (as if that changed the facts I’ve provided or the technical capabilities of these consoles) or about “greatest games of all time” lists, which are purely subjective opinions that you use as support for an argument that simply tries to divert attention from the main debate.
            You finish with a paragraph mentioning lies, etc., but you don’t provide a single valid argument to disprove anything that, according to you, is supposedly easy to refute. You simply don’t even know the most basic calculations, and instead lash out with tantrums filled with subjectivity, without real data, while accusing those of us who provide real (verified and tested) data of lying. You talk about modified ROMs, etc.—enjoy them! I’m glad there’s so much hacking in those games! If you enjoy 200 versions of Mario, what’s stopping you from continuing to enjoy them? A DOOM with a Raspberry Pi inside? Great! Enjoy the advantages that a coprocessor like that can offer, far beyond the console’s native capabilities! Or is it that… you don’t actually like what the base console offers with its limitations?
            In the end, what we see is an empty text, like a tantrum from a grade-school child, where there is no real intent to debate, where when you read something you don’t like it turns into a string of arguments that deflect instead of learning from them, facing them, and ultimately accepting them.
          2. Your claims rely on cherry-picking technical specs to prop up the Genesis while sidelining the SNES, disguising biased revisionism as neutral analysis. It’s not about honest discussion—it’s just Blast Coping veiled as debate.
          3. Also, by bringing up things I’ve said on other sites—twisting and reframing them as needed—you’ve shown yourself to be part of the group that’s been cyberstalking, harassing, doxxing, trolling, and trying to deplatform me for years. The same mob that got a YouTuber’s channel removed before monetization—and even bullied a well-known SNES developer to suicide.
          5. Your disingenuous and bitter attempts to diminish the SNES, fueled by deep-seated hostility toward me and the perpetual axe you’re grinding, are just another manifestation of your unresolved rage over a years-old disagreement and your endless Blast Coping.
Leave a Reply to thesearethedaysmyfriendsCancel reply
