There are two main applications for managing 3D prints and G-Code generation. Cura is a fantastic application that is seeing a lot of development from the heavy hitters in the industry. Initially developed by Ultimaker,  Lulzbot has their own edition of Cura, It’s the default software packaged with thousands of different printers. Slic3r, as well, has seen a lot of development over the years and some interesting hacks. Do you want to print non-planar surfaces? Slic3r can do that. Slic3r and Cura are two sides of the CAM part of the 3D printing coin, although Cura is decidedly the prettier side.
The ability to combine the extensibility of Slic3r with the user interface of Cura has been on our wish list for a while now. It’s finally time. [Josef Prusa] has released PrusaControl, a 3D printing CAM solution that combines the best of Slic3r into a fantastic, great looking package. What are the benefits? What’s it like? Check that out below.
The release of PrusaControl follows just a few months after the release of Slic3r Prusa Edition. The biggest change in this branch of the Slic3r family tree is the addition of variable layer thickness slicing. In short, variable layer slicing allows for very, very high-resolution prints that are only high-resolution where you want a lot of detail.
The variable layer thickness slicing in the Prusa Edition of Slic3r is fantastic. We took a look at one of the first releases, and it does exactly what it says on the tin. In this teardown, I printed a Pokemon that desperately needed low layer height on the top of its head. Using the standard slicer settings for a high-resolution print, I got a printed Pokemon in five hours. Using low-resolution settings, I got a Pokemon in one hour. With the variable layer height settings, I got a fantastic looking print in just over two hours. Variable layer height slicing is one of the killer features of 3D printing. It allows for high resolution while avoiding insanely long print times. The fact that it took so long for such a great feature to make it into one of the standard 3D printing software packages is puzzling.
However, something is rotten in the state of Slic3r. While this may come as a surprise to anyone who has been using it for half a decade, Slic3r is not easy to use. It’s confusing, befuddling, and ugly. No one would ever accuse the GUI of an Open Source program of looking good, but Slic3r is pretty bad.
There are exactly two recommended, free applications used to prepare STLs for 3D printers: Slic3r and Cura (Repetier and ReplicatorG are so 2012, and Simplify3D costs money). Newbies are buying 3D printers by the container load, and manufacturers need an application that is easy to use. Cura will be the default application shipped with all new printers. Its ease of use cuts down on customer support, allowing for a lower cost to the consumer. That’s why Ultimaker loves it, that’s why Lulzbot loves it, and that’s why it’s the slicer recommended by the famous $200 Monoprice printer.
So Why PrusaControl?
Despite [Prusa]’s position as one of the leading manufacturers of 3D printers, he’s been a Slic3r fan from the beginning. Slic3r is, after all, slightly more extensible with capabilities for modifier meshes, weirder infills, and weird bed shapes. Ease of use means lower support costs, though, so the best solution is a Cura frontend with the Slic3r backend. That’s exactly what PrusaControl is; it takes the slicing engine from Slic3r Prusa Edition and “distils the settings down for the user and put our knowledge to the backend to get the same results.”
Is it for everyone? No, if you’re reading Hackaday, you’re obviously in the 99th percentile of human ambition, capability, and ingenuity. If you’re complaining about a dumbed-down Slic3r, this isn’t for you. PrusaControl is training wheels, and that’s a good thing. We don’t need newcomers to 3D printing to fall on their face all the time.
So What’s in PrusaControl
Given that introduction, what can you do in PrusaControl? Not much, and that’s by design.
The interface is exactly what you would expect from a simplified, Cura-derived slicer. Drop an STL on the PrusaControl window, and the model shows up. You can edit printer settings such as material (various brands of PLA and ABS are included, as are some Taulman and E3D filaments), quality, infill, and if supports should be generated or not. There’s a toggle switch for a brim, and apart from position, rotation, and scale settings, that’s it. PrusaControl doesn’t have the fancy settings.
There are a few more options, available from the settings menu. These include the UI language, the model of printer, nozzle diameter, and a few radio buttons for debug. Want to add your printer to that list? You’ll have to edit a few json files. Do you have an enterprising spirit, and have you modified your Prusa i3 for a larger heat bed? You’ll have to edit STL files stored in the depths of your PrusaControl directory.
Is PrusaControl extremely limited? Yes, but that’s the point. You can give anyone a pre-assembled printer and a copy of PrusaControl, and they’ll be printing in fifteen minutes.
3D printing is hard. This may come as a surprise to anyone who has been using a printer since we were making hotends out of nichrome wire. If 3D printing is to grow any more than it already has, the printers and more importantly the software need to be easy to use. If we don’t want a 3D printer to become the 21st century equivalent of the clock on a VCR blinking 12:00, there needs to be an easy to use slicer.
PrusaControl is just that. Yes, it’s limited, but that’s the point.
This statement is so true:
I was there for the early PC days when you had to role your own and later had kits. Today’s 3D environment feels like the early days of PCs. It has a lot of growth to go.
Although it’s closed source and manufacturer specific (boo, hiss) FlashPrint seems to me like a good template for a what a basic user slicer should be. The simplified mode is almost as easy to use as that for a 2D printer but the ability to get advanced control over slicing is about 75% as comprehensive as S3D. My main bugbear is that it doesn’t allow a preview without saving which slows down tweaking.
This is just so elitist : “if you’re reading Hackaday, you’re obviously in the 99th percentile of human ambition, capability, and ingenuity. “
Pandering. The word you’re looking for is pandering.
Edit: Damnit. I screwed that up. My intention in writing that was to have someone comment on it, then reply, “Yet more evidence we’re ruled by the 1%”, or something to that effect.
Sorry about that. I’m really slippin’ here.
I took it as a joke, and a pretty funny one at that.
Pandering … you had me with pandering ……..
Darn it Brian, you’ve got to stop catering to your target audience.
Also, flattery will get you everywhere. :)
A double brown nose event in a single line. You sir are an Artiste to sling shit so brilliantly.
I Gave up on cura as it gave bad prints but Prusa’s slic3r (despite setting sometimes hard to find) proves much better.
As a newbie to this what were the issues with cura which I now use.
Lack of control over settings, lack of settings. (V1) printing produced poor finish and again lack of options. (V2)
Agreed,
I switched away from Cura also, I wasn’t happy with the lack of options regarding in fill and also that Slic3r gave better part finish than Cura for most of my parts
For me the best results came from trying both Slic3r and Cura for each different type of filament. I know some printers produce better results with only one or the other software package, but some filament types seem to work better with Slic3r than with Cura or vice versa. I can’t remember what worked better with Cura though, but I think I had one filament that did.
Slic3r, with tweaking, seemed to be more consistent in producing better parts, and maybe it was because I had to poke around and tweak more settings but it did make a difference.
“Cura … Initially developed by Ultimaker”, technically, this is wrong. I developed on Cura for about 6 months before I joined Ultimaker. But the engine didn’t see any real development till I joined Ultimaker. Which is when Cura really took off feature wise.
I do miss the fact why PrusaControl exists. In my eyes it does nothing a few other tools are already doing…
Cura is really lacking fine tunable settings, e.g. different infill geometries. Furthermore I have made the experience that you often get better prints out of Slic3r regarding the print quality but sometimes Slic3r just fails entirely and goofs up the print.
It exists because someone made it.
I’m curious as to which other tools exist in this same class. Can you elaborate?
I like the Slic3r PE. It has more improvements under the bonnet compared to the official stable release since a lot of changes has been made but never released, and not only by Prusa. I don’t use the GUI (yet), I use Repetier as GUI and the configuration part of slic3r. All in all prints seem to come out better, better sliced, thin walls better resolved etc. and slices a lot faster than the old version (I used 1.27 beta).
I may have a stupid question…is Slic3r PE only for prusa ? can it be used with other reprap such as smartcorexy or delta for example?
Its just a slicer and can be used with any printer. I’m not sure how people are installing it, I couldn’t find binaries and didn’t want to compile from source.
I ended up grabbing it from the Prusa downloads page: http://www.prusa3d.com/drivers/
Its included in their software package, just uncheck everything else during the install.
It’s also included with the latest Repetier host software, a free download.
Sucks that KISSlicer seems to be abandoned by the developer.
repetier bundles both and presents in UI quite well… (also has skeinforge IYC)
“Download Beta for Windows”, “MAC coming soon”.
No Linux Version? Meh.
My thoughts also
Funny how everybody forgets CraftWare as a free slicer option all the time. From what i’ve seen, it’s the only free slicer that offers manual support placement and it seems to be the fastest slicer out there (probably because it uses the GPU). And its available for Win, Mac and Linux…
Agreed. After trying a few I’ve chosen CraftWare as my favorite. The ability to manually insert supports, more options than Cura, a nice, easy interface. It’s certainly worthy of being mentioned in an article like this.
I’ve been using Repetier/Slic3r on my 2020 i3 since I got and it’s been great. We have a FF Creator Pro here at work which uses ReplicatorG and I LOATHE it.I tried slicing with Slic3r then opening with Replicator and it was all off. Simple things like adding more than one (different) item to the build space is nonexistent.
Don’t talk about hard-to-use slicers unless you’ve had to use Skeinforge: http://reprap.org/wiki/Skeinforge . Way back when, before Slic3r or Cura (or Repetier or even ReplicatorG) even existed, the only real options were to use the RepRap Java host software (it produced slightly usable g-code if the STL file was perfect) or Skeinforge. Skeinforge could produce pretty decent results, but it had about 1000 settings with seemingly-random names. ReplicatorG used Skeinforge as it’s slicer engine, but it at least tried to simplify the settings a bunch.
I’d like to know who decided to write real software in Perl. I don’t mean to be an elitist, but real software should be written in a real coding language– not a scripting language meant for processing strings are regular expressions. Rewriting the slic3r engine entirely in C++ should be the first and foremost effort. Shortly thereafter the UI should be rewritten using a real UI library.
agreed, to many people think perl or python are real programming languages instead of scripting languages.
