We’re not sure exactly why [Justin Garrison] decided to make these awesome name badges for himself and his coworkers at Disney+ streaming, but it’s fun to imagine them all lighting up a team-building ride down Space Mountain, isn’t it? Whatever the reason, they sure do look good.
Each badge has an ATtiny85 that drives the ten individually-addressable RGB LEDs, and both the wire and the LEDs are powered by the EL power inverter. [Justin] bought the thinnest EL wire he could find, which is conveniently also the brightest and probably the easiest to manipulate.
Nevertheless, we can’t get over how good the names look, and wonder if [Justin] missed his calling as a neon artist. He cleverly stuck wires through the protoboard to help form the letters, and then used superglue to hold them in place. [Justin] has the code up on GitHub and an album full of build pictures if you want to give this a go.
If this has made you want to give EL bending another go, try using a 3D printed frame to help get it into shape.
