Hackaday Links: May 23, 2021
Hackaday Links Column Banner
The epicenter of the Chinese electronics scene drew a lot of attention this week as a 70-story skyscraper started wobbling in exactly the way skyscrapers shouldn’t. The 1,000-ft (305-m) SEG Plaza tower in Shenzhen began its unexpected movements on Tuesday morning, causing a bit of a panic as people ran for their lives. With no earthquakes or severe weather events in the area, there’s no clear cause for the shaking, which was clearly visible from the outside of the building in some of the videos shot by brave souls on the sidewalks below. The preliminary investigation declared the building safe and blamed the shaking on a combination of wind, vibration from a subway line under the building, and a rapid change in outside temperature, all of which we’d suspect would have occurred at some point in the 21-year history of the building. Others are speculating that a Kármán vortex Street, an aerodynamic phenomenon that has been known to catastrophically impact structures before, could be to blame; this seems a bit more likely to us. Regardless, since the first ten floors of SEG Plaza are home to one of the larger electronics markets in Shenzhen, we hope this is resolved quickly and that all our friends there remain safe.
In other architectural news, perched atop Building 54 at the Massachusetts Institute of Technology campus in Cambridge for the last 55 years has been a large, fiberglass geodesic sphere, known simply as The Radome. It’s visible from all over campus, and beyond; we used to work in Kendall Square, and the golf-ball-like structure was an important landmark for navigating the complex streets of Cambridge. The Radome was originally used for experiments with weather radar, but fell out of use as the technology it helped invent moved on. That led to plans to remove the iconic structure, which consequently kicked off a “Save the Radome” campaign. The effort is being led by the students and faculty members of the MIT Radio Society, who have put the radome to good use over the years — it currently houses an amateur radio repeater, and the Radio Society uses the dish within it to conduct Earth-Moon-Earth (EME) microwave communications experiments. The students are serious — they applied for and received a $1.6-million grant from Amateur Radio Digital Communications (ARDC) to finance their efforts. The funds will be used to renovate the deteriorating structure.
Well, this looks like fun: Python on a graphing calculator. Texas Instruments has announced that their TI-84 Plus CE Python graphing calculator uses a modified version of CircuitPython. They’ve included seven modules, mostly related to math and time, but also a suite of TI-specific modules that interact with the calculator hardware. The Python version of the calculator doesn’t seem to be for sale in the US yet, although the UK site does have a few “where to buy” entries listed. It’ll be interesting to see the hacks that come from this when these are readily available.
Did you know that PCBWay, the prolific producer of cheap PCBs, also offers 3D-printing services too? We admit that we did not know that, and were therefore doubly surprised to learn that they also offer SLA resin printing. But what’s really surprising is the quality of their clear resin prints, at least the ones shown on this Twitter thread. As one commenter noted, these look more like machined acrylic than resin prints. Digging deeper into PCBWay’s offerings, which not only includes all kinds of 3D printing but CNC machining, sheet metal fabrication, and even injection molding services, it’s becoming harder and harder to justify keeping those capabilities in-house, even for the home gamer. Although with what we’ve learned about supply chain fragility over the last year, we don’t want to give up the ability to make parts locally just yet.
And finally, how well-calibrated are your fingers? If they’re just right, perhaps you can put them to use for quick and dirty RF power measurements. And this is really quick and really dirty, as well as potentially really painful. It comes by way of amateur radio operator VK3YE, who simply uses a resistive dummy load connected to a transmitter and his fingers to monitor the heat generated while keying up the radio. He times how long it takes to not be able to tolerate the pain anymore, plots that against the power used, and comes up with a rough calibration curve that lets him measure the output of an unknown signal. It’s brilliantly janky, but given some of the burns we’ve suffered accidentally while pursuing this hobby, we’d just as soon find another way to measure RF power.
10 thoughts on “Hackaday Links: May 23, 2021
  1. Such an interesting target for Tesla’s device. It’s good to see it’s been tuned for higher resolution
  2. The first ten floors is mostly surplus – like every kind of LED matrix-, over-run, trinkets, and basic components like caps on reels. Aliexpress + Banggood when you are in an even bigger hurry. In old Silicon Valley it would be Haltek + Halted + Fry’s. If you need a lot of something maybe the booth holder will start calling their favorite suppliers to see if any has them. Maybe not. In other words, closing it down won’t affect production.
    IIRC Shenzhen is basically built on river flats/tidal marsh and there isn’t mush history to look back on.
  3. Casio, which also makes really nice calculators, has been selling calculators in the US with Python on them for a while now. Check out the Prizm if you want a color screen or the fx-9750giii which is just as fast but has a monochrome screen and costs less than half as much as a TI-84+ CE.
    1. The experiment would still work fine, but you’d need to put some thought into which 10 power levels you’d want to plot “volume of finger tip ablated” against RF power used… or 12 power levels, if you have polydactyly.
    2. I once had to do something similar on a 10 kW UHF transmitter horn. The transmitter was turned off for a short period while I did so! There was a table supplied that related sensation to approximate temperature. The company was too tight to supply a calibrated thermometer.
  4. The Python TI84 has been for sale in France for years. I have one and it’s pretty neat. I’m surprised to learn it’s not globally available …
  5. I guessing nobody here besides me was ever in the top floor main building @Hughes Space & Comm on a warm windy day. You would get motion sickness because it was moving as much as a 1/8 inch and was similar to walking on a moving Amtrak car
    1. The 44-story Plaza Tower was the first skyscraper in New Orleans, and like many older tall buildings it’s built to deliberately flex to keep tension distributed throughout its structure. I did a job near the top floor back in the 1980’s (it’s still there today, but abandoned) and it would sway 6 to 8 feet and yep, bring Dramamine.
Leave a Reply to Redhatter (VK4MSL)Cancel reply
