Teardown: How Many Teddy Ruxpins Does It Take To Start A Coven?
Well, I did it. I conquered my childhood fear of talking bears and brought a vintage Teddy Ruxpin animatronic stuffed bear into my home. There were and still are plenty of his brethren both young and old to choose from on the auction sites, and when I saw this particularly carefree barefoot Teddy in his Hawaiian shirt and no pants, I was almost totally disarmed. Plus, the description promised a semi-working unit with a distorted voice, and who among us could resist a specimen in such condition? Maybe the tape deck motor is going out, or it just needs a new belt. Maybe the tape itself messed up, and Teddy is fine. I had to find out.
But let me back up a bit. If you don’t know what I’m talking about, Teddy Ruxpin was a revolutionary toy that dropped in 1985. It’s a talking teddy bear that reads stories aloud, all the while moving his eyes and mouth to the sounds. Along with Teddy came special cassette tapes, corresponding story books, and outfits. I wanted one when I was a kid, but was also kind of scared of them. Since they were so expensive — about $250 inflation-adjusted for the bear and a single tape / book / outfit, plus another $15 for four D cells — I never did get one in my youth.
Continue reading “Teardown: How Many Teddy Ruxpins Does It Take To Start A Coven?” →
Nokia 5110 Gets Android Stowaway And A Keyboard
Even though Nokia is largely an afterthought in the phone market now, there was a time when their products represented the state-of-the-art in mobile devices. Some of the their handsets even featured slide-out keyboards and the ability to sent emails; largely unheard of for a device from the late 90s. [befinitiv] was a kid back then and couldn’t afford one of these revolutionary devices, so he built his own modern version that still looks and feels like the original.
To do this he borrowed the case and structure of a Nokia 5110 phone, but modified it to hold a small Android device in the old battery compartment along with a tiny Bluetooth keyboard (which was also built from scratch by [befinitiv]) that connects to the Android phone to mimic the old slide-out style. This isn’t just a case mod, though. He also reverse-engineered the original PCB of the phone and included a Bluetooth module there as well, which allows the phone’s screen and keypad to work mostly as originally intended.
This project goes pretty far to scratch the 90s phone nostalgia itch while still being largely usable as a real phone in the modern world. Assuming you aren’t too hung up on the literal phone aspect, the Notkia project is also an impressive effort to bring new life to these old handsets.
Continue reading “Nokia 5110 Gets Android Stowaway And A Keyboard” →
3D Printing A Check Valve In Metal
[SunShine] has been working on 3D printed pumps and similar parts with an aim towards building smaller and more compact hydraulic systems. His latest effort involves printing working hydraulic check valves that can be integrated seamlessly into his designs.
Unlike many 3D printing enthusiasts, [SunShine] works with metal printers of the laser powder bed type. His expectations for his parts are thus very high, and he aimed to create check valves that could withstand high hydraulic pressures.
After much work, [SunShine] came up with two designs for 3D-printed check valves that would work. However, they both needed internal removal of support structures that couldn’t be achieved without cutting them open. He then figured out that he could use a special process using nitric acid to carefully eat away a very precise amount of metal inside the valves, which would remove the support material without destroying the whole valve itself.
While the valves couldn’t be tested beyond 400 bar due to the available equipment, they did work as intended. As a bonus, they actually sealed better as they were used more, as the sealing surfaces bedded in and deformed to match each other.
The video is then rounded out with a simple plastic check valve design you can print at home. It reminds us of other valves we’ve seen created with 3D printing before. Video after the break.
Continue reading “3D Printing A Check Valve In Metal” →
