Hackaday Links: July 20, 2025
Hackaday Links Column Banner
In the relatively short time that the James Webb Space Telescope has been operational, there’s seemingly no end to its list of accomplishments. And if you’re like us, you were sure that Webb had already achieved the first direct imaging of a planet orbiting a star other than our own a long time ago. But as it turns out, Webb has only recently knocked that item off its bucket list, with the direct visualization of a Saturn-like planet orbiting a nearby star known somewhat antiseptically as TWA 7, about 111 light-years away in the constellation Antlia. The star has a significant disk of debris orbiting around it, and using the coronagraph on Webb’s MIRI instrument, astronomers were able to blot out the glare of the star and collect data from just the dust. This revealed a faint infrared source near the star that appeared to be clearing a path through the dust.
The planet, dubbed TWA 7b, orbits its star at about 50 times the distance from Earth to the Sun and is approximately the size of Saturn, but only a third of its mass. The star itself is only about 6.4 million years old, so the planet may still be accreting from the debris disk, which might present interesting insights into planetary formation, assuming that other astronomers confirm that TWA 7b is indeed a planet. But what’s really interesting about this discovery is that because the star system’s orbital plane appears to be more or less perpendicular to ours, the standard exoplanet detection method based on measuring the dimming of the star by planets passing between it and us wouldn’t have worked. This might open the doors to the discovery of many more exoplanets, and that’s pretty exciting.
Question: What’s worse than a big space rock that’s on a collision course with Earth? Answer: Honestly, it feels like a lot of things would be worse than that right now. But if your goal is planetary protection, one possible answer is doing something that turns the one big rock into a lot of little rocks. That seems to be just what NASA’s DART mission did when it smashed into a bit of space debris named Dimorphos back in 2022, ejecting over 100 boulders from the asteroid-orbiting moonlet. LICIAcube, an Italian cubesat that hitched a ride on DART, used optical cameras to observe the ejecta, and measured rocks from 0.2 m to 3.6 m in diameter as they yeeted off at up to 52 meters per second. Rather than spreading out randomly, the boulders clustered into two different groups, something that years of playing Asteroids has taught us isn’t what you’d expect. The whole thing just goes to show that planetary protection isn’t as simple as blasting into a killer asteroid and hoping for the best. And please, can somebody out there type “NASA DART” into Google and tell me what they see? Because if it’s not an animated spacecraft zipping across the screen and knocking the window out of kilter, then I need a vacation. K, thanks.
Do you even code? If you’re reading Hackaday, chances are good that you at least know enough coding to get yourself into trouble. But if you don’t, or you want to ruin somebody else’s life bring someone new into the wonderful world of bossing computers around, take a look at Micro Adventure, an online adventure game aimed at teaching you the basics — err, BASICs — of coding. The game walks you through a text-based RPG (“You’re in a dark room…”) and prompts you to code your way through to a solution. The game has an emulator window that appears to be based on MS/DOS 1.00, so you know it’s cutting-edge stuff. To be fair, it’s always been our experience that coding is mostly about concepts, and once you learn what a loop is or how to branch in one language, figuring it out in another language is just about syntax. There seem to be at least six different adventures planned, so perhaps other languages will make an appearance in the future.
And finally, while we’re talking about the gamification of nerd education, if you’ve been meaning to learn Morse code, you might want to check out Morse Code Defender. It’s an Android app that uses a Missile Command motif to help you learn Morse, with attacking missiles having a character attached to them, and you having to enter the correct Morse code to blow the missile up before it takes out your ham shack. We haven’t tried it yet, so there may be more to it, but it sure seems like a cute way to gamify the Morse learning process. Honestly, it’s got to be better than doomscrolling Instagram.
10 thoughts on “Hackaday Links: July 20, 2025
  1. This post is rather vague about it (read the actual article), but the intent of this portion of the DART mission was to transfer the satellite kinetic energy to a perturbation in the orbit of Dimorphos by a measurable amount, which it apparently did.
    1. And unless the size of the ejected boulders scales with the size of the asteroid being impacted, it doesn’t seem pieces a couple of meters across would even pass through the atmosphere.
  2. And please, can somebody out there type “NASA DART” into Google and tell me what they see? Because if it’s not an animated spacecraft zipping across the screen and knocking the window out of kilter, then I need a vacation. K, thanks.
    Yep, that’s exactly what I see, too. That’s an amusing animation.
      1. I like to think the TWA part was chosen on purpose for this very moment, can’t wait till they discover no.77!!
Leave a Reply to LookAtDaShinyShinyCancel reply
