2025 Hackaday Component Abuse Challenge: Let The Games Begin!
In theory, all parts are ideal and do just exactly what they say on the box. In practice, everything has its limits, most components have non-ideal characteristics, and you can even turn most parts’ functionality upside down.
The Component Abuse Challenge celebrates the use of LEDs as photosensors, capacitors as microphones, and resistors as heat sources. If you’re using parts for purposes that simply aren’t on the label, or getting away with pushing them to their absolute maximum ratings or beyond, this is the contest for you.
If you committed these sins against engineering out of need, DigiKey wants to help you out. They’ve probably got the right part, and they’re providing us with three $150 gift certificates to give out to the top projects. (If you’re hacking just for fun, well, you’re still in the running.)
This is the contest where the number one rule is that you must break the rules, and the project has to work anyway. You’ve got eight weeks, until Nov 11th. Open up a project over at Hackaday.io, pull down the menu to enter in the contest, and let the parts know no mercy!
Honorable Mention Categories:
We’ve come up with a few honorable mention categories to get your ideas flowing. You don’t have to fit into one of these boxes to enter, but we’ll be picking our favorites in these four categories for a shout-out when we reveal the winners.
  • Bizarro World: There is a duality in almost every component out there. Speakers are microphones, LEDs are light sensors, and peltier coolers generate electricity. Turn the parts upside down and show us what they can do.
  • Side Effects: Most of the time, you’re sad when a part’s spec varies with temperature. Turn those lemons into lemonade, or better yet, thermometers.
  • Out of Spec: How hard can you push that MOSFET before it lets go of the magic smoke? Show us your project dancing on the edge of the abyss and surviving.
  • Junk Box Substitutions: What you really needed was an igniter coil. You used an eighth-watt resistor, and got it hot enough to catch the rocket motor on fire. Share your parts-swapping exploits with us.
Inspiration
Diodes can do nearly anything.  Their forward voltage varies with temperature, making them excellent thermometers. Even the humble LED can both glow and tell you how hot it is. And don’t get us started on the photo-diode. They are not just photocells, but radiation detectors.
Here’s a trick to double the current that a 555 timer can sink. We’d love to see other cases of 555 abuse, of course, but any other IC is fair game.
Resistors get hot. Thermochromic paint changes color with temperature. Every five years or so, we see an awesome new design. This ancient clock of [Sprite_tm]’s lays the foundation, [Daniel Valuch] takes it into the matrix, and [anneosaur] uses the effect to brighten our days.
Of course, thin traces can also be resistors, and resistors can get really hot. Check out [Carl Bujega]’s self-soldering four-layer PCB. And while magnetism is nearly magic, a broken inductor can still be put to good use as a bike chain sensor.
Or maybe you have a new twist on the absolutely classic LEDs-as-light-sensors? Just because it’s been done since the early says of [Forrest Mims] doesn’t mean we don’t want to see your take.
Get out there and show us how you can do it wrong too.
87 thoughts on “2025 Hackaday Component Abuse Challenge: Let The Games Begin!
  1. Is Digikey still doing the obnoxious thing of blocking any browser running an adblocker? I’m not turning off my adblocker, and I’m absolutely not turning off my adblocker for anyone who demands that I do so in order to give them money. Something’s gone badly wrong over there and it makes me more sad than angry.
    1. I also have this problem — I think that something in their “are you a robot” algorithm detects less common browsers / user-agent strings as being illegit.
      I have to fire up a second browser to access their site.
    2. I have moved over to using rs-online due to the “robot” detection of Digikey. I use many blocking type features, so will appear abnormal to the website. Another good example of how automated tasks are ruining the internet. Hopefully the Really Simple Licensing standard fixes this back in our (the humans) favour.
    3. I actually attempted to visit digikey’s website but accidentally typed in ‘digikey.co’ instead of ‘digikey.com’. Multiple redirects, and a bunch of fake Windows defender popups in the browser lol.
  2. I once made a CATV data transceiver wherein the transmitter was comprised of a 74HCU04 hex unbuffered inverter. One section was an LC oscillator stabilized with N750 ceramic caps and modulated via a varactor diode. The remaining five sections were paralleled and configure as a linear amplifier via a large-value feedback resistor.
    It’s not eligible for the contest for two reasons. First, it was done more than twenty years ago and was a commercial design which actually saw (limited) production. Second, linear operation of the HCU04 is one of its advertised features and appears in the app notes. I just thought I’d mention it here because using a hex inverter as an analog RF oscillator and amplifier is ‘abuse adjacent’, and because someone might find the idea helpful.
  3. My “favorite” abuse isn’t in the spirit of the contest and takes almost zero creativity, but it’s technically (okay, very much literally) abuse: Using a part as a shim, weight, or other “thing that sits there and takes up space.” Need something to hold something down temporarily? That bag of resistors might do the job. Need a door-stop? That old broken circuit board just might work.
    1. +1 ….. I’ve got a large surplus PCB with lots of through component hole in it that works great as a fly swat. Particularly effective on blue bottles and wasps. I’m not going to enter it as i think it has no chance of winning.
      1. I saw a PCB acting as an antenna (e.g. for WiFi).
        I saw a PCB acting as touch panel.
        I saw PCBs soldered together as enclosure.
        I saw PCB etched to present a picture.
        I saw PCB acting as a fuse.
        I see PCB as a 3D print.
        I print conductive filament on PCBs
  4. i’m slightly off topic but i made a charge status display using a couple BJTs and an FET that would momentarily light an LED each time i turned tho device on. if the battery was fully charged (4V+), the indicator would be on for 5+ seconds. and if the battery was flat (less than 3.7V) then it would be lit for less than a second. it worked great on the bench but i was trickling microamps out of a ceramic capacitor over a period of seconds and you shouldn’t be surprised at the punchline: i made a thermometer. many times more sensitive to temperature than to voltage
  5. A long time ago I determined experimentally that an SCR would explode like a firecracker if you accidentally put the switched voltage onto the gate.
    I’m seriously thinking of making a remote control detonator or noisemaker or something, if I can reproduce the effect…
    1. A long time ago my associates and I determined pragmatically that a low-valued resistor would explode like a firecracker when connected across the two active prongs of a power cord (a simple twist works just fine).
      No one ever checks the prongs of a power cord before plugging the cord in…
        1. When I was at school I used to use electrolytic capacitors as small pyrotechnic devices. Made a satisfying bang when you turned the mains on, but you needed to watch out for the flying almuinium can.
          1. Lol. You reminded me of my exploits at primary school. I used to get the small electric motors out of battery toys and plug them into mains 😁 they would actually spin up (momentarily) before spectacular failure. I tried “recharging” AA cells as well, I don’t recall the results… I think just blown mains fuse?
            Another favorite pastime was getting several kids to hold hands in a circle and I’d zap them all at the same time with my hand wind generator salvaged from an old phone… That did get confiscated 🙁 I don’t think I was ever caught/reprimanded re: plugging stuff into mains. 240v here, so I guess I’m lucky to have survived primary school!!
      1. Back in the 60’s, my friend from next door wired some 12 gauge copper wire across the prongs of a Nema 5-15 plug. Back then, motorists plugged their cars in overnight (-40f in North Dakota USA.). The circuit’s fuse would blow, rendering the block heater useless. Pure vandalism.
      2. We did the same with 10-volt electrolytic caps. We had benches with a master power, and some outlets under the bench for equipment. Always good for a laugh! Even when done to you…
    2. Selenium Rectifiers and Speakers (especially Woofers) directly across the mains were great fun back in my school days. (If you’ve never done a Speaker across the mains, you gotta try it!)
      1. Oh yea, I almost forgot; Graphite is conductive, so a Pencil across 120VAC is great fun too! Sharpen both ends, carefully attach Alligator Clips (carefully since Graphite is brittle and breaks easily,) then plug directly it in to the wall outlet.
        Interesting Note: Graphite is one of the few materials that has a Negative Temperature Coefficient, so the hotter it gets the lower the resistance (and therefore the more current it draws from the wall outlet, making it still hotter.)
        I do recommend doing this outside since it makes lots of smoke, smells somewhat unpleasant, and the wood in the pencil often catches fire; so have an Extinguisher handy (and if your underage please have parental supervision for all this type stuff.)
      1. That is the built-in “installed backwards” warning light.
        Most LEDs pop their top to considerable distance when connected to 24V without series resistor. Maybe that could be used for some kind of target shooting game?
        1. One needs to be VERY careful…
          this almost destroyed an associate’s eye.
          Wear safety glasses if you fancy trying this as it is very dangerous.
      1. A long time ago, when I was a kid, I discovered that by applying high voltage (but low current) to a germanium diode, it would emit a good amount of UV. (It may need to be pulsed for that to work, I don’t remember.) Not enough to tan or burn skin, but plenty to make fluorescent items glow in the dark. Lots of fun back when UV LEDs were simply not commonly available.
        1. I forgot to mention that the diode did make a “click” sound when the high voltage supply (involved using a transistor and audio transformer) was turned on. The diode lasted a surprisingly long time with that abuse.
        2. If true, this is one of those very rare hidden gems that is really ‘neat’ to know about…which, quite possibly, almost know one knows.
          Unfortunately, it uses a device—a germanium diode—which is, due to no longer being in production, simultaneously in very short supply and in very high demand by those who absolutely need the characteristics of a germanium diode (crystal-radio-design purists, for example).
          This would, hands down, get my vote for either the very best, or the very worst, abuse of a component.
          It’s very hard to decide which.
          1. Thankfully, there’s no point doing that hack nowadays, UV LEDs are far superior as UV sources.
            From what I have read, Schottky signal diodes (not to be confused with the more common Schottky power diodes which have a lot more capacitance) are a drop in replacement for germanium diodes in RF applications. For guitar effects, some series resistance is needed to emulate the high series resistance of a germanium diode.
          2. From [NiHaoMike]
            From what I have read, Schottky signal diodes (not to be confused with the more common Schottky power diodes which have a lot more capacitance) are a drop in replacement for germanium diodes in RF applications.”
            Careful…only an extremely small few are ‘drop-in replacements’. You need to do your homework.
            The very few tend to be high-frequency mixer diodes.
            Do not go anywhere near any Schottky whose description contains the words “rectifier”; “power supply”, or anything such as that.
            AND…be extremely careful and cautious about buying anything, in this category, from eBay (a lot of the supposed ‘1N34As’ on eBay have the forward-voltage-drop characteristics of a silicon diode).
            BIG hint: here’s a good example of what to not waste your money on:
            https://www.amazon.com/BlueStars-Germanium-Schottky-Rectifier-Blocking/dp/B0C4T9TNTY
  6. “a broken inductor can still be put to good use as a bike chain sensor”
    Kinda reminds me of the old but not that old mechanics trick of using a discarded but still functional variable reluctance sensor.
    Those are often found on crankshafts or camshafts somewhere on older EFI engines or at the wheels of older cars with ABS systems.
    Basically by hooking the two signal wires which are going straight to the VR coil up to a oscilloscope set to AC mode, you can play doctor with a stethoscope on ignition coils with integrated igniter, since said stage makes it impossible to do the classic test of measuring the resistance of the input, low voltage side of the coil.
    And if you jig the VR sensor up in the right place and your oscilloscope got a logging feature, you can even capture those pesky intermittent faults. Even better if you are using two identical VR sensors, where one of them are positioned on another ignition coil as reference.
    But man hours are expensive, so often the parts cannon are loaded instead and set to “fire at will”
  7. The Badge culture has popularized many new uses for PCB materials other than “be backplane, hold traces, hold components”. Be an actual packaging, be a lightguide, be a heater, be a manual, be a piece of art, to name a few.
    1. My wife gave me a lampshade made from 4 upcycled fibreglass pcbs. I looked at the silk screen layer and it seemed to be from some sort of power supply. They glow a nice green when the light is on.
  8. You know how old Dewars were made a lot like Thermos bottles: The bright aluminum deposited on glass makes an excellent reflector for LEDs. And liquid nitrogen makes a great heatsink. Back when I have ready access to a plentiful supply of the stuff…
    You can put 2 amps into a normal T1-3/4 “high intensity red” LED when it’s immersed in a 77 Kelvin liquid, and it gets really really bright. It will do that indefinitely, until the nitrogen boils off. That’s 100x its normal rated current. With the added voltage drop it’s more like 2-300x its rated power dissipation.
    I doubt a modern 10 W COB LED would survive that treatment, but it would be fun to try to push 100x normal current into one.
    1. i have drowned some blue leds in LN2, and they basically stop working (dim to nothing and cease conducting). I don’t know why, but it could be due to carriers being recaptured into their doping sites, and being unable to liberate due to temperature being too low. The fact that it works with red leds is very interesting, maybe it also works with infrareds then, which might be useful for me.
      1. Do you say, blue LED not working, e.g. with MCU running at 1V8? But red works.
        Have you realized, that different color LEDs need a different voltage?
        Red LED works with 1V2, but a blue LED might need above 3V.
        No wonder. Even a green LED (requiring 2.1V) does not work on my MCU with 1V8.
        1. Yes, but you forgot to mention, the increase of the LED formward voltage at low temperature. A lue LED in a 3V3 circuit really has some problems even at -40°C
    1. Hmmm, but not for visible light. For infrared light for sure (everything can emit infrared, but not mandatory visible light).
      You cannot convert a regular diode (0.7V) or even Schottky diode (0.3V) into a visible light emitter.
      A red LED uses material inside requiring 1.2V. And the higher the light spectrum – the higher required voltage (green 2.1V, blue 3.xV, UV 4.xV).
      A regular LED with 0.7V would be visible, still inside deep infrared (but it would emit such ‘light’ radiation)
    2. I once had a color changing LED: At normal current it was green, with higehr current it become yellow or even red-orange. Nicely, this was not destructive, the effect was reverrsible when it cooled down. Obviously some thermal change of the band gap.
  9. As a kid I used to put electrolytic capacitors across a welder, awesome firecracker.
    But seriously, would reusing recycled parts count in this challenge? I’m reusing an old kettle PCB for its +5v PSU and relay by adding an ESP32, for tank water monitor.
    1. Inverse the polarization (plus and minus inverted) and it will do the same. Watch with voltmeter and it will tell you, when it would explode.
      The “abuse case” would be: use it as single shot timer. Let the electrolyte cap explode. The time constant (duration) depends on voltage and capacity.
  10. Just an inspiration for somebody – transistors in TO-220 are good heating elements for small amount of heat as they have ready made easy to use heat transfer interface. Saw that multiple times in configuration, where 2 transistors was bolted on single heatsink, one acting as heater, for measuring temperature response of the second one.
  11. I was once in a band where we used a microphone made out of a broken pair of headphones and half a guitar cable. I taped it to the side of my amp because I didn’t have a mic stand. It sounded terrible, but that was actually the point of that band.
    1. Vacuum tube could be better. Nowadays, even MEMS sensors (used as gyro or accelerometers) could act as a MIC (for low frequencies).
      There are MEMS microphones right now (so, using a MEMS sensor as MIC does not count anymore for this challenge).
      An “abuse case” would be: use a metal pot with coal. Place a diaphragm on top of it, dipping with a cone shaped needle into the coal. Apply a DC and speak. See the difference in current (resistance).
      An old style telephone microphone.
  12. 50 years ago when I was in my first steps of electronics doing some experiments at home. I used a Germanium PNP transistor as a light detector. The OC71 and also the OC81, scrapping the black paint on the glass package and exposing the germanium element to light. Making it act as a phototransistor.
    1. I once built a battery charger (100mA constant current source) this way. It was even quite stable over input voltage variations
  13. Sorry, I do not understand the challenge. Any electronic component (diodes, transistors, diodes…) have characteristics. You can use a circuit or component outside the spec. region or for an unintended use. But it will not be “strange”: we would use a circuit still with well defined properties and physics.
    Example: I could use an MCU input pin and apply a voltage, e.g. 3V3, via a shunt resistor. I sense this signal with external circuit.
    Now I power off the MUC, connect VDD with GND. What will happen? (The pin is still powered with 3V3).
    The voltage drops now to 0.3…0.7V. I could realize on external circuit, “MCU was powered off”.
    Not magic! Now the ESD protection diodes kicks in. And all works like a regular diode: they shorten the applied voltage to their voltage. The MCU works now as a regular diode.
    A “strange use”? Not really, just an “abuse” of ESD protection diodes.
  14. My component abuse case:
    Take an MCU board using external DRAM memory.
    Use paper sand, a drill, a tool… to remove a bit from the housing (package). Make the housing thin without to destroy the die inside.
    So, the chip becomes now a light sensor.
    Run the FW, using the DRAM. Use a flash light, e.g. a photo flash, and: your FW will crash, or FW will see altered memory content. It acts as a photo sensor.
    “A memory chip as photo sensor”.
    Does it count as abuse?
    1. Or, other abuse case (already using it):
      Use a positive LDO in order to regulate the negative rail (e.g. for opamps).
      Connect the positive LDO input to common ground and the GND of LDO to MINUS 15V.
      The same on output: now LDO GND provides the MINUS VDD and the positive LDO becomes common ground.
      The positive LDO hangs now on the negative rail in a “reversed order”. It would look like regulating the negative voltage drop amount. It should “kill” 5V in order to get -10V on opamp negative rail.
      It works! I use it for my audio DACs.
      Just: because it works in “reverse”, it is not specified in datasheets how good the regulation is.
      It might act just like a Zener diode, e.g. “killing” the 5V difference to get the -10V out of -15V.
      Is it an abuse use?
      For sure it is (a positive LDO for negative rail), but is it mystic? Not really. Just not sure about how good the regulation would work.
  15. “Abuse case”: a vacuum tube microphone, or a vacuum tube magnetic field sensor
    Use a vacuum tube amplifier, e.g. my headphone amp, as a microphone or sensor for a magnet fields.
    Works best, if tube is exposed outside enclosure.
    If you put a loudspeaker now close to the vacuum tube, their internal ‘mechanics’ (esp. the grid) will now start to pickup the sound and modulate the current flow through it. You will hear “again” what you play. Extrem: it can start to oscillate, as a feedback loop.
    “Abuse case”?
    No!!!! Musicians use it since decades to create sound effects. Vacuum tube amplifiers are loved by guitar players, also in particular for such “abused” effect.
    Or use a magnet. Move it close to the tube, move it around, shake the magnet,… you will hear the effect.
    “Abuse case”?
    No!!!! You old TV was working this way.
  16. “Abuse case”: two carbon resistors creating light.
    Get two resistors made of carbon (even two pencils using a carbon filament might work).
    Remove the coating (or the would on pencils) so that each has an exposed carbon area.
    Best: both “resistors” should have a sharp edge each.
    Now, use a DC power supply, 12V is ok, but with high current able to provide and a short circuit protection (with auto-release).
    Connect one resistor (or pencil) with plus, the other with minus.
    Bring both together, at best trying to touch both on the sharpest edge. You need to bring both together, to let it touch. But slightly, short, be prepared to hear/see your DC supply “complaining” about the short or drawing high current.
    Now you separate smoothly both again, a tiny bit, a fraction of millimeter. Try the best distance.
    It creates now an arc, creating a VERY BRIGHT LIGHT.
    WARNING: PLEASE WEAR SUNGLASSES, a protection for your eyes!! (especially against very bright light)
    An abuse?
    No!!!!
    These types of “lamps” were used a century ago.
  17. An abuse case?
    Use a Zener diode, e.g. with 10V. Rectify AC, below 10V peak-peak, into a DC. Works!
    The “abuse” is to use a Zener diode as a regular diode. But a Zener diode is already an “abuse” of a “normal” diode (anti-parallel connected and using the feature of the blocking voltage).
    If the “abuse challenge” is about using a component or circuit outside spec. range…
    I can create even a fuse with a light bulb, LED… just apply voltage/current above rating and it will act like a fuse.
    Does it count?
    A very interesting approach would be this:
    An LED can also work as photo sensor (sure).
    But could you use a photo diode or photo resistor to create light?
    (Sure, for a millisecond by frying it, but permanently without damage?)
    Potentially, it is possible, e.g. to let a photo resistor generate infrared light.
    Does it count?
    You can use a capacitor like a battery (“super cap”). But can you use a battery like a capacitor (no).
    Or can you use a wire like a diode? (no)
    A semiconductor like a wire (no)
    What is this challenge about????
    To use circuits, elements, outside the spec. range? (Sure, you can, I do it with my DAC, PCM1794A, 6V instead of 5V)
    To use it in the opposite way? (most often you can, the physics has often alse the reverse effects, e.g. Sebeck vs. Peltier, LEDs as light detector).
    To use an element for “unintended” purposes?
    Sure! Think about capacity diodes: diodes used like tunable capacitors, used in radio receivers.
    Or using a wire as resistor (wire wound).
    I do not see really any real “abuse case”. All is physics, features of an element, circuits and making use of one or the other feature, intentionally. We do it so often, e.g. Zener diodes.
    In the very old days we had radio receivers, working with “stimulated oscillators” on receiving (to amplify weak signal). A wrong trim could convert this receiver into a transmitter (reduce the damping on input oscillator and it would start to transmit).
    An abuse?
    No!!!! You could start to transmit, intentionally.
    Nowadays, a “real abuse” could be: to use WiFi to receive Bluetooth. Even both work in the same RF spectrum – not possible (because of SW protocol).
    Or using an eMMC as RAM. Sure, SW can use it like a RAM, but powering off eMMC does not result in losing content (non-volatile memory still, not like a RAM).
    But you cannot use RAM like eMMC (except FRAM). This would be a real challenge (to convert a RAM into a ROM).
    Is this the intention of the challenge, to make “something impossible” to work now?
    Just using the possible invertion of an effect, to use something outside the spec is not really a challenge: it is done regularly.
    A fuse is just a wire outside the rated current.
    But using a regular resistor in order to cool down something – this would be a challenge. LOL
    Or use an oxygen sensor to generate oxygen – how cool would it be? LOL
    1. That (ZD as rectifier) is done in most modern car alternators and called “load dump protection”. When there is a sudden drop of the load (bad connection) the alternator can create a nasty high energy spike up to 70V. This can destroy unprotected electronics. To avoid this, the rectifier diodes are “zeners” with a breakdown voltage somewhere betwwen 20 and 30V to absorb this energy
  18. Use a lemon as battery or voltage reference
    Take a lemon (even apples work), one rod as copper, one a zinc.
    Stick the rods into lemon (not touching each other, but not too far away from each other). You get a battery.
    Measure the voltage.
    You can put three of this lemon battery in series an you could bring an LED on *eleven not needing a current limiting resistor).
    Changing from lemon to apple changes the current you can drain, not really the voltage.
    It will be a pretty good voltage reference (if you do not draw high current).
    A lemon voltage reference.
    Does it count for the challenge?
    Or creating light with fruits?
  19. “Abuse case”: PCB as voltage reference or noise generator.
    If you need a voltage reference in micro-volt, create a PCB with copper traces. Solder two iron wires with solder to it (tin).
    Even a copper wire soldered with tin might work (just a lower voltage reference).
    Every junction between different materials create a different voltage difference (copper and tin, copper and iron, iron and tin).
    You can use it also as an analog noise generator. It will be real random noise.
  20. Wireless energy harvesting:
    If you live close by at a broadcast transmitter station, e.g. a powerfull AM sound transmitter,
    create an antenna via a long wire, connect an old-style fluorescent light tube to it and you get light.
    ‘Energy Harvesting” should not count anymore here.
    When I was young, we lived close by the tall transmitter antenna of the AM station of AFN (American Forces Network, in West-Berlin, Germany).
    It was easy to create light with an antenna and light bulb or even listening to music via picking up just the telephone handle without making a call.
    When I did my army service: I was stationed on a 1KW short wave transmitter. We transmitted morse code, as CB. When we pressed the key – the light in the truck came on.
  21. Sorry, for all my comments. Just curious what this challenge is about.
    I could also “abuse” a solar panel as a receiver for optical sound transmission:
    I could modulate a lamp (LEDs) and receive it with a solar panel.
    Is this the challenge?
    Or I could use electric DC current in order to split water into hydrogen and oxygen (as gas). I put an oxygen sensor on top, just to measure how much current I use for the electrolysis.
    Or: I could use a wire as resistor, let it glow and measure the amount of infrared emission as indication for the current through the wire.
    Or: I can use these leaf blowers in order to create a jet engine and let fly “my airplane”.
    Or: I could play sound, or sine wave signals via an amp, but instead of a speaker I connect it to electrodes mounted on my body skin (stimulating nerves and muscles). My HiFi-System as body stimulator.
    Might work with ultrasonic frequency, but with 8 Hz??? It can kill me!!!
    Or: I design an antenna placed in my microwave. I “harvest” the energy created by the microwave oven for other purposes, e.g.to charge a phone battery.
    HOW RISKY DO YOU WANT US TO GO?
    Or: use barbecue igniter for transmitting Morse data:
    I could also create a (mechanical) device to activate these piezo-electric ingitors ( creating sparks). Or even battery powered piezo-spark creators via controlling the power switch.
    I could send now wirelesly pulsed signals, receive it with a very simple device…
    It is for sure an “abuse” of an electrical device, but HIGHLY ILLEGAL (transmitting on all frequencies, polluting the air with illegal content, transmitting without a license…!)
    HOW CRAZY AND ILLEGAL CAN WE GO???
    If “your” challenge would motivate people to solve an issue, to find a solution for a REAL problem – great. If it challenges people to do risky things, to violate legal issues, to risk their health or even life – very bad.
    How do “you” cover “your” liability for people doing things in this challenge?
    Create a “reasonable” challenge, e.g. how to reduce noise in a system, e.g. an audio system? How to make use of >90 dB SNR (actually DNR) in an audio system? How to improve (lower) the THD in an audio system?
    Do not challenge people to use nice working components for unintended use, outside (legal) specifications and to do crazy, illegal or even life-threatening things.
    Blowing up electrolyte caps by wrong polarization is “fun”, already an “abuse”, but very life threatening (I’ve lost quite an eye by doing it, accidently, motivating us to do it intentionally is hopefully not “your” idea).
    Risking my life for a challenge without knowing what the award would be, the coverage if I get hurt by taking part …
    What have “you” setup as a challenge?
    “A crazy idea to motivate people to do crazy things, without the intention to contribute to solving real issues”?
    1. Why should hackaday cover or have any liability? You are responsible yourself for your experiments. So use PPE if approriate
  22. I once built a fan controller for my linear lab PSU because this had only a very unsatisfying control: A thermal switch and a resistor, doing two steps: loud and very loud.
    So I used two TO126 transistors. One as temparature sensor with a fixed base voltage and thus thermally changing collector current and the other as emitter follower output stage. It works perfectly. In no load condition the fan is stopped, but every now and then it makes a few slowrotations to push out the no-load heat of the transformer. With load it slowly and gradually ramps up as needed.
Leave a Reply to Im Human, please be kindCancel reply
