Size (and Units) Really Do Matter
We miss the slide rule. It isn’t so much that we liked getting an inexact answer using a physical moving object. But to successfully use a slide rule, you need to be able to roughly estimate the order of magnitude of your result. The slide rule’s computation of 2.2 divided by 8 is the same as it is for 22/8 or 220/0.08. You have to interpret the answer based on your sense of where the true answer lies. If you’ve ever had some kid at a fast food place enter the wrong numbers into a register and then hand you a ridiculous amount of change, you know what we mean.
Recent press reports highlighted a paper from Nvidia that claimed a data center consuming a gigawatt of power could require half a million tons of copper. If you aren’t an expert on datacenter power distribution and copper, you could take that number at face value. But as [Adam Button] reports, you should probably be suspicious of this number. It is almost certainly a typo. We wouldn’t be surprised if you click on the link and find it fixed, but it caused a big news splash before anyone noticed.
Thought Process
Best estimates of the total copper on the entire planet are about 6.3 billion metric tons. We’ve actually only found a fraction of that and mined even less. Of the 700 million metric tons of copper we actually have in circulation, there is a demand for about 28 million tons a year (some of which is met with recycling, so even less new copper is produced annually).
Simple math tells us that a single data center could, in a year, consume 1.7% of the global copper output. While that could be true, it seems suspicious on its face.
Digging further in, you’ll find the paper mentions 200kg per megawatt. So a gigawatt should be 200,000kg, which is, actually, only 200 metric tons. That’s a far cry from 500,000 tons. We suspect they were rounding up from the 440,000 pounds in 200 metric tons to “up to a half a million pounds,” and then flipped pounds to tons.
Glass Houses
We get it. We are infamous for making typos. It is inevitable with any sort of writing at scale and on a tight schedule. After all, the Lincoln Memorial has a typo set in stone, and Webster’s dictionary misprinted an editor’s note that “D or d” could stand for density, and coined a new word: dord.
So we aren’t here to shame Nvidia. People in glass houses, and all that. But it is amazing that so much of the press took the numbers without any critical thinking about whether they made sense.
Innumeracy
We’ve noticed many people glaze over numbers and take them at face value. The same goes for charts. We once saw a chart that was basically a straight line except for one point, which was way out of line. No one bothered to ask for a long time. Finally, someone spoke up and asked. Turns out it was a major issue, but no one wanted to be the one to ask “the dumb question.”
You don’t have to look far to find examples of innumeracy: a phrase coined by  [Douglas Hofstadter] and made famous by [John Allen Paulos]. One of our favorites is when a hamburger chain rolled out a “1/3 pound hamburger,” which flopped because customers thought that since three is less than four, they were getting more meat with a “1/4 pound hamburger” at the competitor’s restaurant.
This is all part of the same issue. If you are an electronics or computer person, you probably have a good command of math. You may just not realize how much better your math is than the average person’s.
Gimli Glider
Air Canada 143 after landing” from the FAA
Even so, people who should know better still make mistakes with units and scale. NASA has had at least one famous case of unit issues losing an unmanned probe. In another famous incident, an Air Canada flight ran out of fuel in 1983. Why?
The plane’s fuel sensors were inoperative, so the ground crew manually checked the fuel load with a dipstick. The dipstick read in centimeters. The navigation computer expected fuel to be in kg. Unfortunately, the fuel’s datasheet posted density in pounds/liter. This incorrect conversion happened twice.
Unsurprisingly, the plane was out of fuel and had to glide to an emergency landing on a racetrack that had once been a Royal Canadian Air Force training base. Luckily, Captain Pearson was an experienced glider pilot. With reduced control and few instruments, the Captain brought the 767 down as if it were a huge glider with 61 people onboard. Although the landing gear collapsed and caused some damage, no one on the plane or the ground were seriously hurt.
What’s the Answer?
Sadly, math answers are much easier to get than social answers. Kids routinely complain that they’ll never need math once they leave school. (OK, not kids like we were, but normal kids.) But we all know that is simply not true. Even if your job doesn’t directly involve math, understanding your own finances, making decisions about purchases, or even evaluating political positions often requires that you can see through math nonsense, both intentional and unintentional.
[Antoine de Saint-Exupéry] was a French author, and his 1948 book Citadelle has an interesting passage that may hold part of the answer. If you translate the French directly, it is a bit wordy, but the quote is commonly paraphrased: “If you want to build a ship, don’t herd people together to collect wood and don’t assign them tasks and work, but rather teach them to long for the endless immensity of the sea.”
We learned math because we understood it was the key to building radios, or rockets, or computer games, or whatever it was that you longed to build. We need to teach kids math in a way that makes them anxious to learn the math that will enable their dreams.
How do we do that? We don’t know. Great teachers help. Inspiring technology like moon landings helps. What do you think? Tell us in the comments. Now with 285% more comment goodness. Honest.
We still think slide rules made you better at math. Just like not having GPS made you better at navigation.
10 thoughts on “Size (and Units) Really Do Matter
  1. When I started my engineering degree in 1980, slide rules were already a curiosity. And curious I was. I eventually got my mitts on one and played with it. Understanding the fundamental logarithmic nature of it not only made me better at math, but also made me want to know more math.
    And how have I never before encountered that quote from Mr. Petit Prince?
  2. It’s amazing that this is still amazing to anyone who has spent multiple decades interacting with people on at least a semi-daily basis, though one of the common biases people have is the polite assumption that other people understand the conversation you’re having.
    What’s interesting is that parts of the problem are not as simple as “innumeracy”. For example, if you ask which is larger, 1/3 or 1/4, what you’re really doing in words is asking “Which is larger, a third or a quarter?” First you have to parse the words out to mean fractional numbers. If the person is not primed for a math quiz and you spring the question on them, they may simply trip over it and answer nonsense. It’s like the trick of suddenly saying “The idiot says what?”. Ha ha, gotcha. Fast thinking vs. slow thinking mode. Your brain gets a cache miss and has to wait for RAM.
    When people see an expression like “a quarter pounder”, that’s an arbitrary label. One doesn’t usually mind what it actually means. It’s a hamburger. If the usual choice is between a Big Mac and a Quarter Pounder, those words don’t mean numbers. It isn’t about math.
    If you were asking the question as “Which is larger, a third or a fourth?”, the answer might be different. Now the brain isn’t instantly jumping to food, or the physical sizes of coins.
    1. On a related note, people are generally not so much rational thinkers as they are associative and heuristic thinkers. That is the default mode. If that fails, then comes analytical thinking.
  3. So how much copper would a big datacenter require? I don’t even know where to begin. Are we talking 3.3, 5, 12 volts where currents are high (per watt), or 220 volts and higher where currents would be much lower? Are you including distribution lines, transformers, and generators to get the power to the data center? What percentage of those lines would actually be aluminum instead? This would take a lot of fuzzy math to calculate.
    1. Ok. How many blades of grass on a (US metaphor for global war football, not FIFA football) football field?
      Yes, a lot of fuzzy math. but easy to be within an order of magnitude.
      See Jon Bentley, Programming_Pearls, “The Back of the Envelope” (Column 7 in the second book edition. I don’t recall the CACM issue it was originally in)
  4. People ‘longing for the sea’ suddenly become competent ship builders and sailors?
    I don’t think so.
    Teach generally competent people to ‘long for the sea’ perhaps, but that’s maybe 1 in 5.
    Otherwise you’re just creating customers for GD cruise ships,
    Perhaps future Darwin award winners.
    The fact is the Innumerate are just stupid and/or lazy.
    You can’t fix stupid and to ‘fix’ lazy you’ve got to do it early.
    Idiocracy is a documentary.
  5. There was a nice SF novel, I just forgot the name:
    A guy wakes up in a locked room. He seems to have lost his long-term memory.
    After some time he finds out that he measures household distances/weights in inches/feet/ounces, but technical ones in ISO. He is also able to convert them on the fly, finding that he’s not using imperial but American Survey units.
    His conclusions: I must have grown up in the U.S., and I’m a technician or scientist.
    It would be so easy if we could just split at this line:
    Use cultural units for household or daily measures, but please use ISO when going technical or international. Tell me about your chocolate bars in ounces, I can convert that. But stop asking for 15/32 inch drilled holes (unless it’s archery).
    This message will self-destruct in 2345/13 kobo-Ticks.
Leave a Reply to DudeCancel reply
