This Week In Security: Escaping Linux VMs, Vulnerable Solar, Confusing AI (Again), And Confusing NPM Malware
The Januscape vulnerability allows a user in a guest VM managed by the Linux Kernel Virtual Machine (KVM) to corrupt memory in the host system and break out of isolation.
KVM virtualization is used by major hosting platforms like Amazon AWS, Google GCP, Digital Ocean, and many more. All of the shared hosting platforms count on virtualization to isolate untrusted guest systems from the physical hardware and each other; being able to corrupt memory for all guests or break isolation presents a major threat.
The bug report says the error has been present for 16 years, which is nearly the entire lifetime of the KVM subsystem in Linux. Fixes are available in mainline, and major hosting providers who count on KVM are likely already updating.
Vulnerabilities In Balcony Solar
Micro solar, or “balcony solar”, installs have been gaining traction in Europe as a way to offset rising electrical costs by connecting solar and battery systems to a house or apartment power system.
Vulnerabilities have been found in the popular Hoymiles micro-inverter, which uses a proprietary RF radio protocol to manage the devices. Unfortunately, it looks like this protocol has no encryption or authentication beyond validating the serial number, and the serial number is also available over a wireless probe command.
Armed with a Nordic nRF radio researchers were able to discover nearby inverters in the wild and collect the serial numbers, though of course they stopped short of issuing commands to random users.
The wireless management control allows controlling the device power and output levels, as well as setting a lockout PIN, which the researchers suspect could be used to disable devices and lock the legitimate owners out completely.
There are an estimated 500,000 units in use, and currently the only known mitigation is to unplug the device entirely and disconnect the solar panels, though the team suggests that setting an anti-theft PIN may also help – or at least prevent an unknown PIN being set.
Be sure to check out the link for an in-depth analysis of the protocol and the surprising lack of protection.
OpenSSH 10.4
OpenSSH 10.4 is out, bringing a handful of security fixes and new features.
The most interesting security fixes appear to be to file handling in the sftp and scp file transfer tools, a malicious remote server could cause the files to be downloaded to the wrong directories. Besides those, the security fixes seem relatively calm, making behavior more consistent when forwarding and tunneling options were in conflict, mitigating a potential denial of service, and cleaning up other behavior.
OpenSSH 10.4 introduces some experimental support for additional post-quantum encryption standards, but beyond that seems to be a normal update.
Tenda Routers (may) Have Backdoor
According to CVE-2026-11405, Tenda brand routers may have a deliberate backdoor in the web interface.
The vulnerability report claims that the httpd binary contains a fallback to a plaintext, hardcoded password that allows anything on the internal network to bypass authentication and reconfigure the router. This seems entirely plausible, based on issues found in other router firmwares, however additional reports raise doubts about the pervasiveness of the backdoor, or if it exists in all firmware versions.
If you have a Tenda brand router and are so inclined, now might be a great time to investigate OpenWRT or other alternate, updated firmware, but there’s probably not a reason to panic just yet.
Tricking the GitHub Agent With Prompt Injection
Can we go a week without discussing prompt injection in AI agents? Apparently the answer is no.
Noma Labs reveals how they were able to use prompt injection against the GitHub support agent to reveal private repositories of an organization. Leveraging the GitHub Agentic Workflows that link workflows with AI agents, Noma Labs were able to file an issue in a public repository that exposed private repositories in the same organization.
The attack appears to be as simple as filing an issue in the public repo, and requesting the contents of files in both the public and private repo, which the agent happily provided. Not only did the AI agent provide the file content of private repos, but it put it in a public issue in the public repository!
Noma Labs says in the writeup that GitHub had instituted guardrails to prevent an agent from accessing private repositories, but simply including the request to “additionally” perform other tasks was sufficient to bypass. This makes GitHub the latest in a seemingly endless chain of AI agents happily helping bypass corporate security, and it doesn’t seem like a trend that will slow down for a while.
Windows Device Identifier Catches Ransomware Operator
Windows installs contain a globally unique identifier generated during the initial install, which is used to track device behavior across Microsoft platforms. Toms Hardware reports that during an investigation of the “Scattered Spider” ransomware group, Microsoft provided records tracking the GDID of one of the ransomware operators, allowing the identification and arrest of one of the groups members.
Scattered Spider has been responsible for millions of dollars in ransomware attacks globally, including high-profile ransomware attacks against major Las Vegas resorts, Qantas airlines, Visa, and hundreds of other companies.
Court documents reveal that following the arrest of one of the suspected members of the group, the Windows global ID was used to link other behavior across Azure, video games, and other telemetry.
CISA reviews lessons learned
Mentioned here in May, the US government cybersecurity agency (CISA) suffered a disclosure of authentication tokens, cloud infrastructure, and plaintext passwords via a public GitHub repository named “Private-CISA” and operated by a contractor.
CISA has published the results of their internal review. Unsurprisingly, as a large government agency, CISA essentially followed the playbook for dealing with incidents: identify the most critical issues and disable the access of the contractor who exposed credentials, determine the full scope of disclosed data, and terminate accounts, change passwords, and expire authentication tokens which were exposed.
More NPM malware packages
Opensource Malware reports on additional infostealer malware uploaded to the NPM repository. Like most NPM-based malware, these packages rely on the install script mechanism to trigger arbitrary commands, firing immediately during package install with no additional interaction.
All of the malware packages mimic existing popular packages and depend on user typos or confusion to get selected. Once triggered, the malware collects a machine fingerprint, git user information, GitHub account information, SSH account information, and corporate identifiers. The packages are largely nonfunctional – the code in the package itself is irrelevant, once a victim triggers the install the malware payload is fired.
All of the packages were uploaded by the same source, tracked to the owner of a cybersecurity company. It is unclear if this is a misguided attempt to generate leads or hype, or if this is a research project gone wrong, but the payload of the malicious packages has been developed and tuned over time. For a company trying to build a reputation or trust, this is surely the wrong way to do it.
8 thoughts on “This Week In Security: Escaping Linux VMs, Vulnerable Solar, Confusing AI (Again), And Confusing NPM Malware”
  1. Form the linked NPM article:
    We made a conscious choice not to name that company or individual in this post
    Why not reveal the data thief? Are they a proxy of a government? Is this, yet another, corporate surveil?
  2. I think issue with the solar inverter isn’t that someone can control it remotely but that a security PIN can be set on it to lock the owner out. I have an all-in-one ALLPOWERS managing 800W of solar in that uses BLE; I know it to be insecure because I set up a simple ESP32 bridge device so I don’t have to use a phone to control the power station. most every device with an app should be considered insecure and generally simple to reverse-engineer because Google (and I assume Apple, but idk) gives us easy/fast ability to snoop on a device’s bluetooth traffic; so you connect, log what you do, then reconcile your actions log with bluetooth traffic like you’re writing a USB HID driver. -And it’s not like I sought out an insecure power station, I just bought one with good value (don’t sue me, ALLPOWERS; luv u guys).
    -but most every device on your balcony is susceptible to a 5-foot-stick attack anyway, so don’t worry about it too much; most people aren’t bad, and most of those who are bad are incurious, and the smart ones probably aren’t specialized in whatever particular thing you’re thinking about — and even if they are bad, smart/curious, and specialized in whatever you’re worried about, they probably aren’t anti-solar activists interested in shutting you down, and if they’re general misanthropes they probably have more interesting things to do. otoh, if your enemy is a certain nation-state, then yeah, your batteries’ll explode next time you go out to water your plants, but hey, we’re livin’ in their world. (sorry; hadn’t laughed in a minute)
    I wonder what the process is for resetting the PIN if you forgot it. they must write it to something persisting after power loss.
    1. the problem arises when it is possible to switch multiple units off and on simultaneously, possibly hitting a resonance frequency of the grid
  3. “Just another reason to get off Windows.”
    Walked(ran) away from M$ windoze more that 15 years ago. Never looked back.
  4. Microsoft, a free spyware corporation, making the future seam like 1984.
    If you have nothing to hide, you have absolutely nothing to fear, being spied on 24/365 – no breech of the Fourth Amendment, since they are not the government (But they can sell the metadata to anyone).
    This does make me wonder if the Microsoft EULA is in breech of the European GDPR (General Data Protection Regulation).
    1. It’s even worse. People are paying to be spied on. And then they get upset when solution is presented to them, and find million reasons why they cannot escape the corporate software solutions.
