Looking At A Bike Built For The Apocalypse
So-called bug out cars are a rather silly venture that serve little purpose more than snagging your jumper. The odds of a car working well through a nuclear winter are rather minimal. But what about a bicycle? On paper it’s a better choice, with extreme efficiency, reliability, and runs off whatever sustenance you can find in the barren landscape of a collapsed society. But [Seth] over at Berm Peak proved an apocalypse bike is at least as silly as a bug out car.
While a utilitarian bike fit for a cross-country trek across a nuclear wasteland can certainly be a reasonable venture, this particular bicycle is not that. This three wheeled monstrosity of a bicycle (is it still a bicycle if it has three wheels?) was built by [TOMO] for the Bespoked bike show’s apocalypse buildoff. It placed second among a number of strange bikes with features ranging from pedal driven circular saws to beer keg grills. But this particular example of apocalypse bike is easily the strangest example of the lot.
Continue reading “Looking At A Bike Built For The Apocalypse”
Remotely Navigate The Apocalypse In Mid-Century Style
One of the few positives to come of this pandemic is that the restrictive nature of scarcity can be a boon to creativity. Plus, the doom and gloom of it all is causing people to loosen up and do things they never felt free enough to do before in the demanding world of the before times.
For example, [ossum] makes R/C vehicles on commission to exacting standards, but took a break from perfection to build this remote control hellscape-faring van by the seat of his pants. It’s quite a resourceful build that combines pieces from previous projects with a few standard R/C parts and a handful of clever hacks.
The body is a test print of a 1957 Chevy Suburban van that [ossum] made for someone a few years back. It’s mounted on a scrap metal chassis and moves on printed tank treads designed for a different vehicle.
Since glass is a liability in an apocalypse (and because [ossum] doesn’t have a resin printer yet), the windows have fortified coverings that are printed, patina’d, and detailed with tiny rivet heads.
As far as hacks go, our favorite has to be the clothespin steering. [ossum] only had one electronic speed controller, so he used a servo to actuate a pair of spring-loaded clips, alternating between the two to move the tank-van. There’s a short video after the break that shows the rack and clothes-pinion steering, and it’s loaded up right after a brief demo of the van.
We realize that everyone’s apocalyptic needs are different, but there’s more than enough here to get you started. Don’t have access to enough R/C parts? Gear boxes and drive shafts can be printed, too.
Continue reading “Remotely Navigate The Apocalypse In Mid-Century Style”
