A black pickup sits in front of a snow-capped mountain range in the background. It has a white camper shell with a sci-fi looking "01" emblazoned on the side in black text. An orange, wedge-shaped tent pops up above the campershell and truck roof.
A Pop-Up Truck Camper For Less
We live in a veritable Cambrian Explosion of camping options, ranging from a tarp on the ground to multi-million dollar RVs. Somewhere around the middle is the pop-up truck camper, but [Further Fabrication] wanted to build his own.
As is often the case, he saw the cool pop-up truck campers on the market, but balked at the cost. To make matters worse, the options out there weren’t really available in his country. After getting a solid set of measurements from the truck and some materials, he set to work.
The most interesting part of this build is probably the aluminum/plywood sandwich [Further Fabrication] chose for building the main structure of the camper shell. While many would’ve chosen a tubing space frame for the build, he decided to sandwich two layers of plywood around plywood beams and large rectangular aluminum tubing. These were affixed with a combination of construction adhesive and screws to create a lightweight yet sturdy enclosure.
The tent portion uses a 600-denier PVC-coated waterproof polyester fabric, sewn with nice YKK zippers, and features large windows with screens for excellent ventilation. The roof consists of two sections of aluminum composite sandwich, and the side panels were made from cutoffs of the roof material. Instead of the standard cam-lock used on most camper shells, [Further Fabrication] chose a solenoid-actuated system and more conventional grab handles.
We’ve covered campers several times, including a solar-powered RV, a truck camper that expands lengthwise rather than up, and several bike-based campers.
Continue reading “A Pop-Up Truck Camper For Less” →
A bright yellow crew cab pickup is on an unpaved area with snow-capped mountains in the distance. In its bed is a matching camper shell which is somewhat trapezoidal with a smaller semicircular section that can pull out to lengthen the sleeping space of the camper. At the top of the image it says, "Sleeps Two!" with an arrow pointing to the camper shell.
Want A Truck With A Short Bed And A Long Camper Shell?
Camper shells are a time-honored piece of truck gear, but with modern trucks having increasingly vestigial beds, the length of your overnight abode has increasingly shrunk as well. To combat this problem, [Ed’s Garage] built a camper shell that extends once you’ve arrived at your campsite.
[Ed] wanted to keep things relatively low profile while still tall enough to sit up in for convenience, leading to a small bit of the shell peeking over the truck’s roof. To keep the cold Canadian winter out, attention was paid to proper weather sealing around the sliding portion of the shell so that it stays warm and dry inside.
While this would work on any truck, the mains power plugs in the bed of some modern trucks mean that certain glamping conveniences like a heater and projector can be easily powered while you’re in camp. We get to see the camper shell in action at the end of the video where the pros and cons of having your sleeping space also being your storage while en route become apparent.
If you’re looking for something a little less conventional for your camping experience, how about this solar camper or this retro bike camper?
Continue reading “Want A Truck With A Short Bed And A Long Camper Shell?” →
