The ROG Ally with the second screen mod installed
Dual-Screen Mod For The ROG Ally Handheld
In our continuing coverage of the ROG Ally modding community, we would be amiss to not mention a seriously impressive mod — a dual screen project for the x86 gaming handheld by [YesItsKira]! Single screen devices can feel cramped, and this mod is a prime example of a dedicated hacker taking things into her own hands. In particular, the mechanics of this mod are done wonderfully, thanks to a custom-designed 3D printed Ally back cover.
The second screen connects through a USB-C port, held above the main screen by a sturdy printed hinge at whatever angle you want it. As a pleasant surprise, it’s also touch-enabled! The mod is fully open source and well documented — everything you need to print is published on Thingiverse, a detailed assembly guide with pictures is on GitHub, and the BOM is at the bottom of the guide.
Apart from printed parts, you only need a few things off Amazon, it’s that easy to source. Electronics-wise, this mod uses a Raspberry Pi-suited HDMI screen, wiring it up through an integrated USB-C dock; which means you can still charge your handheld while using the dual-screen solution!
Interested in modifications for your ROG Ally, but not quite ready to bolt on a second display? Check out this phenomenally documented battery upgrade from an iFixit staffer that we recently covered.
The mod as installed into the handheld, complete with the custom 3D-printed back, with a screwdriver being used to install one of the screws
A ROG Ally Battery Mod You Ought To Try
Today’s hack is an unexpected but appreciated contribution from members of the iFixit crew, published by [Shahram Mokhtari]. This is an ROG Ally Asus-produced handheld gaming console mod that has you upgrade the battery to an aftermarket battery from an Asus laptop to double your battery life (40 Wh to 88 Wh).
There are two main things you need to do: replace the back cover with a 3D printed version that accommodates the new battery, and move the battery wires into the shell of an old connector. No soldering or crimping needed — just take the wires out of the old connector, one by one, and put them into a new connector. Once that is done and you reassemble your handheld, everything just works; the battery is recognized by the OS, can be charged, runs the handheld wonderfully all the same, and the only downside is that your ROG Ally becomes a bit thicker.
Continue reading “A ROG Ally Battery Mod You Ought To Try”
LEDBOY Is A Retro-Modern Handheld Game
Back in the 1970s, there were a few LED-based games on the market that were quickly superseded by the rise of LCDs and other fancier technologies. However, [grossofabian] wanted to recreate that classic style of game but with more modern hardware. The result is the LEDBOY, a colorful handheld game built in tribute to that era.
The handheld is based around the ATtiny 1614 microcontroller, driving a 10×10 array of NeoPixel Nano 2427 LEDs, named for their small 2.4 mm x 2.7 mm form factor. They’re RGB, too, so there’s lots of wonderful colors to play with.
Wrapped up in a neat enclosure with a rechargeable 130 mAh lithium-ion battery and some simple tactile buttons, it’s a tidy little handheld game console. Add in the CH340C chip for USB to serial duties, and it’s easy to program with the Arduino IDE, too.
Code is available on Github for those keen to take a closer look. Amusingly, the project bears a striking resemblance to a similarly-named build we featured just under 12 years ago. Time is a flat circle, and the video, my friends, is after the break.
Continue reading “LEDBOY Is A Retro-Modern Handheld Game”
