Old IPad Keyboard Makes For A Modern Netbook
Netbooks were a class of tiny laptops which hit their peak over a decade ago, with the idea being that you could use the Internet and do your computing on the move with ease. Unfortunately manufacturers were scared of them eating their profits from bigger computers, and they were invariably built to a very disappointing spec. That doesn’t lessen the appeal of small form factor laptops though, and [bob-foss] is here with a simple hack to make one.
He’s taken a hinged keyboard case made for one of the previous generations of iPad Mini, and paired it with a high-end Lenovo gaming tablet by way of a 3D printed replacement for the original Apple-grabber. We said it was a simple hack and it is, but it’s no less elegant for that as the detail is what matters. This isn’t a mess-of-wires cyberdeck, instead it’s a machine you could pull out on a train and get some work done.
Meanwhile, if you’d like to take a wallow in what that netbook thing was all about, we took a look at the phenomenon back in 2020.
Make A Capacitive Clothespin Keyboard For Your IPad
Even with all the optimization and style of new technology, the keyboard is a difficult thing to replace. Touch screens just don’t deliver the tactile feedback that connects us to the medium. [Adam Kumpf] remedies this by building his own keyboard interface to work with an iPad piano app, all from craft materials you’d likely find lying around in the kitchen.
To make your own, you’d first need a bunch of clothespins which will ultimately act as your keys. [Adam] shows how to stitch the separated halves of the clothespins onto a piece of cardboard with some basic rubber bands. These tension the keys so that they can rock back and forth over a pen or pencil placed beneath them. When you press down on one end, the other lifts causing an opposing pin to press the corresponding key of the iPad, just like a hammer inside a piano. With a little aluminum foil for conductivity wrapped around the side making contact, you’ve got yourself a quick solution for your itch to rock some Chopin.
You can see how well the project works in action below in his video:
Continue reading “Make A Capacitive Clothespin Keyboard For Your IPad”
