A drawing of a battery cell with gunk on the labeled anode and cathode called the "thick and inactive interphase layer." An icon of a dead battery with two red bars within a pictograph of a battery is superimposed. An arrow points to the right to a cleaner looking cell with a full battery icon with green bars inside showing the cell after regeneration.
A Simple Solution For Streamlining Battery Recycling
Lithium batteries have become the backbone of many modern devices ranging from toothbrushes to semi trucks, so what are we going to do with them when these rechargeable cells finally die? Researchers at Cornell have identified a way to streamline the recycling process.
Most current lithium battery recycling involves grinding up the batteries and separating active material from other components like the casing, current collectors, etc. These materials are then processed and turned back into fresh material for a new batch of batteries. Taking everything all the way down to rebuild it is time and labor consuming, and therefore expensive, especially in light of increasingly lower prices for lithium.
The researchers found that by electrochemically dissolving the inactive electrode–electrolyte interphase layers that built up over time, they could rejuvenate the electrode without completely taking it apart. This direct electrode-to-electrode regeneration (DEER) uses 1,3-dimethyl-2-imidazolidinone (DMI) as a solvent for the process. Once reassembled, these regenerated cells have up to 95% of their original capacity while cutting the cost of recycling by over half.
If you’re looking to reuse a pack before sending it to the recycler, may we suggest a whole house battery from an old EV pack and how to integrate them safely.
Flash Joule Heating Recovers The Good Stuff
Rare earth materials are a hot button topic these days. They’re important for everything from electric vehicles to defence hardware, they’re valuable, and everyone wishes they had some to dig up in their backyard. Lithium, too, is a commodity nobody can get enough of, with the demand for high-performance batteries grows each year.
When a material is desirable, and strategically important, we often start thinking of ways to conserve or recycle it because we just can’t get enough. In that vein, researchers have been developing a new technique to recover rare earth metals and lithium from waste streams so that it can be put back to good use.
Continue reading “Flash Joule Heating Recovers The Good Stuff” →
