The Sanskrit Square Root Algorithm
Years ago, no math education was complete without understanding how to compute a square root. Today, you are probably just reaching for a calculator, or if you are writing a program, you’ll probably just guess and iterate. [MindYourDecisions] was curious how people did square roots before they had such aids. Don’t remember? Never learned? Watch the video below and learn a new skill.
The process is straightforward, but if you are a product of a traditional math education, you might find his terminology a bit confusing. He will refer to something like 18b meaning “a three-digit number where the last digit is b,” not “18 times b,” as you might expect.
Continue reading “The Sanskrit Square Root Algorithm”
Math On A Checkerboard
The word “algorithm” can sometimes seem like a word designed to scare people away from math classes, much like the words “calculus”, “Fourier transform”, or “engineering exam”. But in reality it’s just a method for solving a specific problem, and we use them all the time whether or not we realize it. Taking a deep dive into some of the ways we solve problems, especially math problems, often leads to some surprising consequences as well like this set of algorithms for performing various calculations using nothing but a checkerboard.
This is actually a demonstration of a method called location arithmetic first described by [John Napier] in 1617. It breaks numbers into their binary equivalent and then uses those representations to perform multiplication, division, or to take the square root. Each operation is performed by sliding markers around the board to form certain shapes as required by the algorithms; with the shapes created the result can be viewed directly. This method solves a number of problems with other methods of performing math by hand, eliminating other methods like trial-and-error. The video’s creator [Wrath of Math] demonstrates all of these capabilities and the proper method of performing the algorithms in the video linked below as well.
While not a “hack” in the traditional sense, it’s important to be aware of algorithms like this as they can inform a lot of the way the world works on a fundamental level. Taking that knowledge into another arena like computer programming can often yield some interesting results. One famous example is the magic number found in the code for the video game Quake, but we’ve also seen algorithms like this used to create art as well.
Continue reading “Math On A Checkerboard”
Square Roots 1800s Style — No, The Other 1800s
[MindYourDecisions] presents a Babylonian tablet dating back to around 1800 BC that shows that the hypotenuse of a unit square is the square root of two or 1.41421. How did they know that? We don’t know for sure how they computed it, but experts think it is the same as the ancient Greek method written down by Hero. It is a specialized form of the Newton method. You can follow along and learn how it works in the video below.
The method is simple. You guess the answer first, then you compute the difference and use that to adjust your estimate. You keep repeating the process until the error becomes small enough for your purposes.
Continue reading “Square Roots 1800s Style — No, The Other 1800s”
Ask Hackaday: Computing Square Roots On FPGA?
Hackaday reader [nats.fr] wrote in with some code from a project that resizes a video stream on the fly using an FPGA. Doing this right means undoing whatever gamma correction has been applied to the original stream, resizing, and then re-applying the gamma. Making life simpler, [nats.fr] settled on a gamma of two, which means taking a bunch of square roots, which isn’t fast on an FPGA.
[nats]’s algorithm is pretty neat: it uses a first-stage lookup to figure out in which broad range the value lies, and then one step of Hero’s algorithm to refine from there. (We think this is equivalent to saying he does a piecewise linear interpolation, but we’re not 100% sure.) Anyway, it works decently.
Of course, when you start looking into the abyss that is special function calculation, you risk falling in. Wikipedia lists more methods of calculating square roots than we have fingers. One of them, CORDIC, avoids even using multiplication by resorting to clever bitshifts and a lookup table. Our go-to in these type of situations, Chebyshev polynomial approximation, didn’t even make the cut. (Although we suspect it would be a contender in the gamma=1.8 or gamma=2.2 cases, especially if combined with range-reduction in a first stage like [nats.fr] does.)
So what’s the best/fastest approximation for sqrt(x) for 16-bit integers on an FPGA? [nats.fr] is using a Spartan 6, so you can use a multiplier, but division is probably best avoided. What about arbitrary, possibly fractional, roots?
Relays Calculate Square Roots
After seeing an exhibit of an old relay-based computer as a kid, [Simon] was inspired to build a simple two-relay latching circuit. Since then, he’s been fascinated by how relays can function to do computation. He’s come quite a long way from that first latching circuit, however, and recently finished a huge five-year project which uses electromechanical relays to calculate square roots.
DSC_0240-e1394580570356
The frame of the square root calculator can hold up to 30 identical relay modules, each of which hold 16 relays on PCBs, for a total of 480 relays. The module-based setup makes repair and maintenance a breeze. Numbers are entered into the computer by a rotary dial from an old phone and stored in the calculator’s relay memory. A nixie tube display completes the bygone era-theme of the device and shows either the current number that’s being entered, or the square root of that number as it’s being calculated.
The real magic of this project is that each relay has an LED which illuminates whenever the relay is energized, which shows the user exactly where all of the bits of the machine are going. [Simon] worked on this project from 2009 and recently completed it in 2014, and it has been featured at the San Mateo Maker Faire and at Microsoft Research in Redmond, WA. We’ve seen smaller versions of this before, but never on this scale and never for one specific operation like square roots.
Video below. Thanks to [Bonsaichop] for the tip!
Continue reading “Relays Calculate Square Roots”
