An analog telephone adapter (ATA), or FXS gateway, is a device that allows traditional analog phones to be connected to a digital voice-over-IP (VoIP) network. In addition to this, you can even create a local phone exchange using just analog phones without connecting to a network as [Playful Technology] demonstrates in a recent video.
The ATA used in the video is the Grandstream HT802, which features one 10/100 Mbps Ethernet port and two RJ11 FXS ports for two POTS phones, allowing for two phones to be directly connected and configured using their own profiles.
By using a multi-FXS port ATA in this manner, you essentially can set up your own mini telephone exchange, with a long run of Cat-3 possible between an individual phone and the ATA. Use of the Ethernet port is necessary just once to configure the ATA, as demonstrated in the video. The IP address of the ATA is amusingly obtained by dialing *** on a connected phone and picking 02 as menu option after which a synthetic voice reads out the number. This IP address gets you into the administration interface.
Continue reading “Create A Tiny Telephone Exchange With An Analog Telephone Adapter”
