Giant working NERF gun runs on Arduino.
Giant Working NERF Gun Runs On Tiny Arduino
Well, here it is: a shoe-in for the new world’s largest NERF gun. (Video, embedded below.) The Guinness people haven’t shown up yet to award [Michael Pick], but at 12.5 feet, this baby is over twice as long as the current record holder, which belongs to former NASA mechanical engineer Mark Rober and his now-puny six-foot six-shooter.
We have to wonder if it is technically bigger than the six-shooter, because they seem to be roughly the same scale, except that [Michael] chose a much bigger model to start from. The main body is made from wood, and there are a ton of 3D-printed details that make it look fantastically accurate. The whole thing weighs over 200 pounds and takes at least two people to move it around. We especially love the DIY darts that [Michael] came up with, which are made from a PVC tube inside a section of pool noodle, topped off with a 3D printed piece for that distinctive orange cap.
Propelling those darts at around 50 MPH is a 3,000 PSI air tank connected to an Arduino Pro Mini that controls the trigger and the air valves. While [Michael] hasn’t run the thing quite that high, it does plenty of damage in the neighborhood of 40-80 PSI. As you’ll see in the video after the break, this is quite the ranged weapon. Watch it blow a hole clean through a sheet of drywall and much more.
Want to build something with a bit more stealth? Make it death from above with a NERF quadcopter.
Continue reading “Giant Working NERF Gun Runs On Tiny Arduino” →
Fidget Spinner Gigantor
Had enough of fidget spinners yet? If you haven’t heard, a toy that consists of a bearing in the center of a multi-lobed flat structure that’s designed to spin around the bearing’s axis with little force has taken the world by storm. Usually, these devices are about 10cm in diameter or less. But, everything is bigger in Texas. So, naturally, students from the University of Texas at Dallas got to work making the largest fidget spinner in the world.
Clocking in at 150 pounds and 45 inches in diameter, this thing is undeniably huge. The structure is made out of what looks to be veneered plywood glued together to make a ~2.5in thick structure to put their bearings in. And, after washing their bearings with soapy water, the students get to work press fitting their 2.2in by 10.5in ball bearings into their painted wooden structure. Their video embedded below is an entertaining watch, it starts with a gag, but moves on the project afterwards.
Haven’t gotten enough fidget spinner news? Fear not, we’ve got you. [MakerStorage] has a fidget spinner designed to teach STEAM. Just in case manually spinning a fidget spinner is above you, we’ve got robots on the job. Want to see something more vibrant? How about POV on a fidget spinner?And if you’ll never get tired of fidget spinners, we’ve got a fidget spinner for that too.
Continue reading “Fidget Spinner Gigantor” →
