[MS3FGX] has done an interesting study about using Bluetooth adapters as a source for Pseudorandom Number Generation (PRNG). As it turns out, the Bluez package has a function that calls a remote Bluetooth adapter to return a random number. He picked up 10 compatible adapters for about $30 from DealExtreme and set about assembling some numbers to see how this compares to an OS-based PRNG.
Because millions of samples are needed for an accurate comparison, time became a problem. The adapters are a little bit slow responding to a request, sending just 4800 numbers in the first 30-second test. This can be overcome with multiple adapters being accessed by multiple computers for hours at a time. What can this be used for? Your guess is as good as ours, but [MS3FGX] has done a great job of writing up his tests. He’s also made a set of 20.7 million randomly generated values available if you want to generate your own statistical analysis.
