Building The Second Tiniest Tetris
A few years ago, [Richard] pulled a crushed camcorder out of a junk box at a hamfest. After pulling the half-inch CRT out of the viewfinder, he needed to find a project. [Richard] ended up building the second tiniest game of Tetris we’ve ever seen.
After futzing around with the CRT, [Richard] discovered that one of the pins would accept an NTSC input. He also found a similar project that used a dime-sized CRT to play Tetris. With ready to go code, [Richard] started assembling his project into a handsome wooden box.
There are two PCBs for the build – a CRT driver circuit, and a small custom board that handles the game and controller code. The circuit for the game board was found on this site, but the featured boards there were too large for the project. A stripped-down board was fabricated by BatchPCB and put into the box.
There aren’t any controls on the console itself, for that a standard DB-9 connector was installed so a vintage Atari joystick could be used. For a more ergonomic Tetris experience, a Sega Genesis controller could be used. For something that looks like it comes out a steampunk laboratory, playing Tetris is a bit unexpected. Check out the demo video of the screen at 20x magnification after the break.
[youtube=www.youtube.com/watch?v=fMYwlN9wpcQ&w=470]
10 thoughts on “Building The Second Tiniest Tetris
  1. I built this tetris app a couple years ago. runs on a pic16f84 chip. built mine into a tictac box. and built a small controller that plugs directly into it. i have a couple viewfinders floating around maybe ill add one to mine.
Leave a Reply to HirudineaCancel reply
