LED Mortar Board Battles Suns Brightness With 21W Of Power
[Jeremy Blum] aimed to be the brightest student at his Master’s graduation ceremony this spring. He designed an LED rig for his mortar board which should battle the sun’s intensity by using up to 21 watts of power. But he didn’t stop with eye-catching intensity. while he was at it he also included some interactive features so the guy behind him has a way to keep from going blind.
One thing that really caught our eye is the 3D printed parts he generated for the project. There’s a nice mounting plate for the LED side of things, and a wrist-mounted enclosure for the Raspberry Pi board. Wait, why does he need an RPi to drive some LEDs? We already mention interactivity which is facilitated by the Pi acting as a WiFi hotspot. Connect to the access point and choose a color. If you’re in the seat behind [Jeremy] you’ll want to choose black! All of this and is explained in his video presentation.
Continue reading “LED Mortar Board Battles Suns Brightness With 21W Of Power”
Already Impressive Wolverine Claws Now Energized With High Voltage
wolverine-claw-high-voltage
A few years back [James] built an utterly amazing set of Wolverine replica claws. They are held together by a bar that laces between his fingers so that when he’s gripping it you don’t see anything but the claws. Add to that the tail design which makes it look like they’re actually coming out of his skin and he’s made an amazing replica. But they’re also rather utilitarian as you can see in the demo/how-it-was-done video where he spears hay bails as they’re thrown at him from off camera. Machine shop fans are going to love learning how these were made.
More recently he decided to update the project after seeing our own Thor’s Hammer offering. He got down to business by salvaging a huge transformer from an old oil furnace. He has no idea what kind of voltage this thing puts out, but that doesn’t stop him from wiring it up to the pair of claws and letting the sparks fly. He even creates a Jacob’s Ladder effect by placing the claws at a narrow angle to each other.
Continue reading “Already Impressive Wolverine Claws Now Energized With High Voltage”
High Speed Photography With Friggin’ Lasers
[Bruce] built his own high-speed photography equipment for a fraction of the price it would have cost him to purchase it. He was inspired by a friend who showed him some example images. He headed into his shop and built an Arduino-based high-speed flash controller.
To capture an image like this one the camera is placed in a dark room and set for a long exposure. At just the right instant the flash is activating, capturing the image. In this case [Bruce] used an infrared laser diode pointed at a phototransistor to trigger the flash. When the droplet breaks the laser beam the Arduino triggers the flash after a calculated delay. It’s not specifically covered in his guide, but [Bruce] also mentions that this can be modified to use sound as a trigger. Here’s another sound-activated flash controller if you need inspiration.
The image at the top was made by dropping dye from a pipette into a pool of water. If you don’t have a pipette on hand you can head over to our LIFE blog to make one out of heat shrink tubing.
[Jeri] Spills The Beans On Her AR Glasses
AR
In the last year, [Jeri Ellsworth] has been very busy. She was hired by Valve, started development of an augmented reality system, fired by Valve, and started a new company with [Rick Johnson] to bring her augmented reality glasses to the market. On the last Amp Hour podcast she spilled the beans on what went down at Valve, how her glasses work, and what her plans for the future are.
[Jeri] and [Rick]’s castAR glasses aren’t virtual reality glasses like the Oculus Rift or other virtual reality glasses that cut you off from the real world. The castAR glasses preserve your peripheral vision by projecting images and objects onto a gray retro-reflective mat and allows you to interact with a virtual environment with an electronic wand. So far, there are a few demos for the castAR system; a Jenga clone, and a game of battle chess called Team For Chess, a wonderful reference to Valve’s hat simulator.
The electronics inside the castAR glasses are fairly impressive; new frames are drawn on the retro-reflective surface at 100 Hz, positioning accuracy is in the sub-millimeter range, and thanks to [Jeri]’s clever engineering the entire system should be priced at about $200. Not too bad for an awesome device that can be used not only for D&D and Warhammer, but also for some very cool practical applications like visualizing engineering models of 3D prints before they’re printed.
