Repairing And Adding Bluetooth Control To An Induction Cooker
When his 6 years old induction cooker recently broke, [Johannes] decided to open it in an attempt to give it another life. Not only did he succeed, but he also added Bluetooth connectivity to the cooker. The repair part was actually pretty straight forward, as in most cases the IGBTs and rectifiers are the first components to break due to stress imposed on them. Following advice from a Swedish forum, [Johannes] just had to measure the resistance of these components to discover that the broken ones were behaving like open circuits.
He then started to reverse engineer the boards present in the cooker, more particularly the link between the ‘keyboards’ and the main microcontroller (an ATMEGA32L) in charge of commanding the power boards. With a Bus Pirate, [Johannes] had a look at the UART protocol that was used but it seems it was a bit too complex. He then opted for an IOIO and a few transistors to emulate key presses, allowing him to use his phone to control the cooker (via USB or BT). While he was at it, he even added a temperature sensor.
Energy Harvesting Peltier Ring
[Sean] is by no means an electrical engineer, but when he discovered the magic of Peltier plates he knew he had to make a project with them. This is his Energy Harvesting Peltier Ring.
The effect he is harnessing is called the Seebeck Effect — the process of generating electricity through temperature differentials. He has shown how peltier plates work to many people, and, as you can guess, most people think they are amazing (free energy wow!). Unfortunately, most peltier plates are rather large and bulky, so [Sean] decided he wanted to try to design something small enough that could fit on a ring. Just a proof of concept, to light a tiny SMD LED.
The tiny Peltier plate he found generates about 0.3V with a temperature differential of about 20C — not bad, but it won’t light up any standard LEDs at that voltage! He started looking into voltage steppers and discovered Linear Technology’s 3108 Ultralow Voltage Step-up converter and Power Manager — a surface mount chip capable of scaling 0.3V to 5V. The only problem? [Sean’s] never done surface mount soldering.
His first circuit was built on a prototyping board, and after it worked successfully, he designed a PCB using Fritzing. Another success! Prototyping complete, it was now time to try to downsize the PCB even more to fit on a ring. Realizing there was no way he was going to fit it on a single ring, he decided to make a double ring out of CNC machined aluminum. He made use of his school’s CNC shop and the ring came out great. It works too! The room has to be fairly cool for the LED to light, but [Sean] definitely proved his concept. Now to make it even smaller!
Adding A SIM Card To The Photon Q 4G LTE
[Charles] is a big fan of phones that have physical keyboards. He thinks they are better suited for writing lengthy emails, but unfortunately his HTC Desire Z was getting old so he had to replace it. [Charles] therefore decided to import the Motorola Photon Q from the USA which exposed one major problem. The Verizon phone uses CDMA so there is nowhere to put a GSM SIM. But a bit of hacking allowed him to add a SIM card slot to it. Even though he’s not the one who originally found this hack (XDA thread here), his write-up is definitely an interesting read. To perform this modification, he needed a hot air reflow station, a soldering iron, a Dremel with the appropriate cutting wheel and several SIM card slot assemblies from the Galaxy S3 (as the first ones usually get burned during the disassembly process).
Obviously the first steps involved opening the phone, which may have taken a while. Using hot air, [Charles] removed the EMI shield covering the SIM card IC . He then extracted the latter using the same technique. Finally, he removed another EMI shield covering the contacts to which the SIM card slot should be connected. A few minutes/hours of delicate soldering and case modding later, [Charles] could use his SIM card on his brand new phone.
Hacking And Philosophy: Crackdown Part IV
h&pcrackdown4
This week we conclude our discussion of The Hacker Crackdown with the final chapter, which covers the rise of the EFF. In early 1990, the idea of civil liberties online was little more than a notion in [John Barlow’s] head, but by the end of the same year, the EFF had formed to not only keep Phrack editor [Knight Lightning] out of prison, but to also successfully challenge the Secret Service on behalf on Steve Jackson Games.
[Sterling] details [Knight Lightning’s] trial in this chapter and it’s worth reading. Had the EFF lost the case, online publications would have suffered serious setbacks in terms of freedom of speech, and sites like ours would likely be considered illegal. Read on, dear reader.
Continue reading “Hacking And Philosophy: Crackdown Part IV”
Pokemon Blue Becomes An IDE
With WiFi, Wonder Trade, and new Pokemon that are freakin’ keys, you’d think the latest generation of everyone’s reason to own a Nintendo portable is where all the action is, right? Apparently not, because Pokemon Blue just became a development tool for the Game Boy.
Despite all notions of sanity, this isn’t the first time we’ve seen someone program a Game Boy from inside a first generation Pokemon game. Around this time last year, [bortreb] posted a tool assisted run that deposited and threw away in-game items to write to the Game Boy’s RAM. Using this method, [bortreb] was able to craft a chiptune version of the My Little Pony theme inside Pokemon Yellow.
A year later, [TheZZAZZGlitch] has gone above and beyond what [bortreb] did. Instead of a tool assisted run, [ZZAZZ]’s hack can be done manually on a real Game Boy. This trick works by using an underflow glitch to obtain item ‘8F’ in the player’s inventory. Here’s a great tutorial for doing that. With this 8F item, a few items can be tossed and a ‘programming’ mode is activated where code can be written to RAM by walking to an X Y position on the map, using the 8F item, and writing a program byte by byte.
The maximum amount of code that can be written to the Game Boy RAM is 254 bytes, just large enough for [TheZZAZZGlitch] to write a very, very simple version of Akranoid, Breakout, or one-player Pong. Not much, but very, very impressive.
Video of [ZZAZZ] ‘jailbreaking’ his copy of Pokemon Blue available below.
Continue reading “Pokemon Blue Becomes An IDE”
An Engineer’s Emergency Business Card
breakout_3
We’ve seen lots of circuit board business cards before, but none quite like this. [Saar] calls it the Engineer’s Emergency Business Card.
Since he actually makes a living from making circuit boards, it made sense for him to make a truly functional card. But unlike some of the fancier cards we’ve seen, you can’t plug it into your computer, or even open a beer with it! In fact, all it does is light up when a voltage is applied across the main pins.
But wait — why are all the components in through holes? Well, according to [Saar], that’s because it’s designed to be the electrical engineers emergency kit!
When all hope is lost, the MacGuyver engineer could snap out one of the components and save the day. Recall the countless times you desperately needed a 1 KOhm resistor to fix an amplifier at a party, only to see the girl you were trying to impress slip away with an OCaml programmer? Never again with this little kit. You even have 2 cm of solder in there to make sure the connection’s electrically solid!
We love it. Whether or not anyone will ever successfully use it in an emergency situation such as [Saar’s] hypothetical one is another question altogether. But we do have to give him creativity points for it, the artistic traces look awesome!
Crafting A Liquid Crystal Display
Throughout the 1960s, the management at RCA thought LCD displays were too difficult to commercialize and sent their engineers and researchers involved in LCDs off into the hinterlands. After watching [Ben Krasnow]’s efforts to build a liquid crystal display, we can easily see why the suits thought what they did. It’s an amazing engineering feat.
Before building his own version of an LCD (seen above in action), he goes through the mechanics of how LCDs operate. Light enters the display, goes through a polarizer, and is twisted by a liquid crystal material. The first successful LCDs used two types of liquid crystals – chiral and nematic. By combining these two types of molecules in the right proportion, the display can ‘twist’ the polarized light exactly 90 degrees so it is blocked by the second piece of polarizing film in the display.
Besides getting the right crystals and engineering processes, another major hurdle for the development of LCDs displays is transparent electrically conductive traces. [Ben], along with every other LCD manufacturer, uses a thin layer of indium tin oxide, or ITO. By embedding these clear electrodes in the display, segments can be built up, like the seven segment displays of a calculator or a bunch of tiny dots as found in a TV or computer monitor.
In the end, [Ben] was able to build an extremely simple single-segment LCD display out of a pair of microscope slides. It does modulate light, just barely. With a lot of work it could be made in to a calculator type display but for now it’s an awesome demonstration of how LCDs actually work. Continue reading “Crafting A Liquid Crystal Display”
