Medium Machine Mediates Microcontroller Messages
Connecting computers to human brains is currently limited to the scope of science fiction and a few cutting-edge laboratories. Tapping into some nerves farther from our central wetware is possible and [Peter Buczkowski] shows us his stylish machine for implanting a pattern into our brains without actively having to memorize anything.
His Medium Machine leverages a TENS unit to activate forearm muscles in a pattern programmed into an Arduino. Users place their forearm across two aluminum electrodes mounted on a tasteful wooden platform and extend a single finger over a button. Electrical impulses trigger the muscles which press the button. That’s all. After repeating the pattern a few times, the users should be able to recite it back on command even if they aren’t aware of what it means. If this sounds like some [Johnny Mnemonic] memory cache, you are absolutely correct. This project draws inspiration from the [William Gibson] novel which became a [Keanu Reeves] movie.
Users can be programmed with a Morse code message or the secret knock to open an attic library or play a little tune. How about learning a piano song?
12 thoughts on “Medium Machine Mediates Microcontroller Messages
  1. “Connecting computers to human brains is currently limited to the scope of science fiction and a few cutting-edge laboratories.”
    Particular brainwaves as a trigger.
    1. Actually, it’s even easier than that when you take into account that most people can’t understand it…
  2. This sounds more like the sort of device described in Galactic Odyssey by Keith Laumer.
    It was used to train the protagonist to operate a sorting machine, if I remember correctly.
