Changing Color Under Pressure
When you saw the picture for this article, did you think of a peacock’s feather? These fibers are not harvested from birds, and in fact, the colors come from transparent rubber. As with peacock feathers, they come from the way light reflects off layers of differing materials, this is known as optical interference, and it is the same effect seen on oil slicks. The benefit to using transparent rubber is that the final product is flexible and when drawn, the interference shifts. In short, they change color when stretched.
Most of the sensors we see and feature are electromechanical, which has the drawback that we cannot read them without some form of interface. Something like a microcontroller, gauge, or a slew of 555 timers. Reading a single strain gauge on a torque wrench is not too tricky, but simultaneously reading a dozen gauges spread across a more complex machine such as a quadcopter will probably require graphing software to generate a heat map. With this innovation it could now be done with an on-board camera in real-time. Couple that with machine learning and perhaps you could launch Skynet. Or build a better copter.
The current proof-of-concept weaves the fibers into next-generation bandages to give an intuitive sense of how tightly a dressing should be applied. For the average first-aid responder, the rule is being able to slide a finger between the fabric and skin. That’s an easy indicator, but it only works after the fact whereas saying that the dressing should be orange while wrapping gives constant feedback.
3 thoughts on “Changing Color Under Pressure
    1. Great idea :-)
      Not as kinky as some, a nurse up the road has this wry smile now and then and her name Berenicki, some months ago I joked I could call her Berekinki under the right circumstances, I get more wry smilee, just need to raise my eyebrows ;-)
      Anyways, interesting Erik Johnson, a new entertainment option in such things as jazz ballet and expressive dance etc The dancer’s clothing changes colour as pressure gradients shift across the torso – add to that with maybe permutations of some thermal sensing with LEDs too – offers a kaleidoscope of possibilities.
      Hey, with even more and a very subtle option, the “colour” changes a fluorescent dye’s wavelength susceptibility to UV. Then the observed colour and the changes only become visible when the dancer is (selectively) illuminated by the conductor or scenery or “other” etc.
Leave a Reply to Mike Massen Cancel reply
