Hackaday Podcast 054: Xenomorph Cookies, 101 Uses For Hot Glue, Rolling Robots, And A Clippy Computer
Hackaday editors Elliot Williams and Mike Szczys reflect on great hacks of the past few days. Strain relief is something every electronics geek encounters and there’s a spiffy way to make your hot-glue look like a factory connector. There’s something in the air and it seems to be recreating early computers. Did you know astronauts are baking cookies they’re forbidden to eat? And did you hear about the 3D printer that’s being fed oil from the deep fryer?
Take a look at the links below if you want to follow along, and as always tell us what you think about this episode in the comments!
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (60 MB or so.)
Episode 054 Show Notes:
New This Week:
Interesting Hacks of the Week:
Quick Hacks:
Can’t-Miss Articles:
8 thoughts on “Hackaday Podcast 054: Xenomorph Cookies, 101 Uses For Hot Glue, Rolling Robots, And A Clippy Computer
    1. Cool! Thanks. I totally botched that bit talking about the original, b/c I was fixated on Mike’s. Now that you mention it, those are clearly tacks or screws and not solder blobs.
      Using normal switches instead of paper clips is pure win, though.
  1. The component for the laser detector tachometer that you mention in your podcast is an optical schmitt trigger OR OPIC light detector. So basically an amplified detector. There’s a sharp IS485 or IS486 component with similar pinout – see datasheet. Maybe there is a chinese equivalent. Try looking for OPIC .
Leave a Reply to David ContreniCancel reply
