Adding Perlin Noise To 3D Printed Parts, With Python
Want to add a bit of visual flair to 3D printed parts that goes maybe a little more than skin-deep? That’s exactly what [volzo] was after, which led him to create a Python script capable of generating a chunk of Perlin noise, rendered as an STL file. What does that look like? An unpredictably-random landscape of hills and valleys.
The script can give printed parts a more appealing finish.
The idea is to modify a 3D model with the results of the script, leaving one with something a bit more interesting than a boring, flat surface. [volzo] explains how to use OpenSCAD to do exactly that, but it’s also possible to import the STL file the script creates into the CAD program of one’s choice and make the modifications there with some boolean operations.
If the effect looks a bit bit familiar, it’s likely because he used the method to design part of the 3D printed “toy” camera that we featured recently.
[volzo]’s method isn’t entirely plug and play, but it could still be a handy thing to keep in your back pocket when designing your next part. There are also other ways to modify the surfaces of prints for better aesthetics; we’ve previously covered velocity painting (also known as ‘tattooing’ in some slicers) and also fuzzy skin.
Perlin noise was created by [Ken Perlin] in the early 80s while working on the original Tron movie as a way to help generate more realistic-looking textures. It still fulfills that artistic function in a variety of ways, even today.
16 thoughts on “Adding Perlin Noise To 3D Printed Parts, With Python
    1. I’ve done this exact thing. Basically I use a walk to create a basic pattern, then apply some transforms to make it more wood-like. I’ll try to find my old code and do a short write-up on my site. I’ll reply here with a new link when I do if you’re still interested.
  1. The IdeaMaker slicer has this feature built in. You can apply any texture to a 3D print that you want, scale it, rotate it, determine how deep the greyscale image goes, and they even have a library of online textures to choose from.
  2. If you want to use code in your slicer to generate extra functionality such as this I can’t recommend IceSL enough, it’s not Python but Lua which of course is easy to use as well.
    IceSL has the most accurate slicing from my experience which is why I use it.
Leave a Reply to thantikCancel reply
