Macro Pad Cheap Enough To Give Away
Supercon 2022 showed that hackers are starting to come together again in Maker Faires, conventions, and festivals. [Toby Chui] plans to be one of those hackers and wants something to give to fellow attendees. Thus, the $3 Macro Pad was born.
We’ve seen our fair share of macro pads, so a simple four-key pad isn’t exactly novel. However, the focus on size and cost makes it stand out. The pad is the size of a business card, making it easy to give away. For a microcontroller, [Toby] used a CH552G, which is cheap and compatible with the Arduino IDE. Although, with 10 GPIO, a matrix layout could have supported a full-sized number pad, the diodes required would have added to the cost significantly. A cheap PCB and 3d-printed base make up the device’s bulk.
[Toby] provides a handy tool for assigning keys from your browser without coding. However, the source code is on GitHub if you want to develop a more complicated scheme. This isn’t the first time we’ve featured the CH552 chip, and it likely won’t be the last.
Continue reading “Macro Pad Cheap Enough To Give Away” →
ChatGPT V. The Legal System: Why Trusting ChatGPT Gets You Sanctioned
Recently, an amusing anecdote made the news headlines pertaining to the use of ChatGPT by a lawyer. This all started when a Mr. Mata sued the airline where years prior he claims a metal serving cart struck his knee. When the airline filed a motion to dismiss the case on the basis of the statute of limitations, the plaintiff’s lawyer filed a submission in which he argued that the statute of limitations did not apply here due to circumstances established in prior cases, which he cited in the submission.
Unfortunately for the plaintiff’s lawyer, the defendant’s counsel pointed out that none of these cases could be found, leading to the judge requesting the plaintiff’s counsel to submit copies of these purported cases. Although  the plaintiff’s counsel complied with this request, the response from the judge (full court order PDF) was a curt and rather irate response, pointing out that none of the cited cases were real, and that the purported case texts were bogus.
The defense that the plaintiff’s counsel appears to lean on is that ChatGPT ‘assisted’ in researching these submissions, and had assured the lawyer – Mr. Schwartz – that all of these cases were real. The lawyers trusted ChatGPT enough to allow it to write an affidavit that they submitted to the court. With Mr. Schwartz likely to be sanctioned for this performance, it should also be noted that this is hardly the first time that ChatGPT and kin have been involved in such mishaps.
Continue reading “ChatGPT V. The Legal System: Why Trusting ChatGPT Gets You Sanctioned” →
A man playing an automated recorder
Musical Robot Lets You Play The Recorder Hands-Free
Although many people might remember the recorder as just a simple instrument from their introductory music classes, it can nevertheless produce rich and varied melodies in the hands of a virtuoso like Frans Brüggen. [Luis Marx] also took music lessons as a child, but never progressed much beyond an elementary level. Instead, he preferred to spend his time honing his engineering skills, which eventually enabled him to get back into music.
Initially, he wanted to build a piano-playing exoskeleton, to marionette his fingers up and down the ivories, but had to bail on that one because of the insane complexity. So instead, he built himself a robot that helps him play the recorder. (Video, in German, embedded below, fast-forwarded to the recorder part.)
A set of solenoids and an Arduino on a 3D-printed frameA recorder has eight finger holes, which can be covered or uncovered in various combinations to produce tones. [Luis] therefore used eight solenoids, mounted on a 3D-printed frame, to actuate the finger holes. The basic idea worked, but getting the solenoids to fully cover the holes each time turned out to be a challenge: even a slight misalignment would cause air to leak past the plug and produce a horrible off-key sound.
After a lot of trial and error, [Luis] found foam earplugs to be a pretty good material for emulating human fingertips. He also discovered that relying on the solenoids’ spring tension to keep the holes closed was not reliable; a better solution was to flip the solenoids around and use the much larger force from their powered stroke to create an air-tight seal.
The solenoids are driven by an Arduino Nano through a set of MOSFET modules, powered by a lithium battery. [Luis] wrote some Arduino sketches with famous melodies like Beethoven’s Für Elise, which sound quite decent on the robo-recorder: perhaps not on Frans Brüggen’s level, but pretty impressive for a self-declared “music noob” like [Luis].
Many robotic musicians play instruments like pianos or xylophones. Instruments from the flute family are harder to automate, but it has been done before. We’ve even seen a MIDI-powered harmonica.
Continue reading “Musical Robot Lets You Play The Recorder Hands-Free” →
The CCTV Cameras That Recorded The Chernobyl Disaster And Aftermath
The Soviet KTP-63-based remote controlled camera system, including switch and control panel. (Credit: Chernobyl Family on YouTube)
The Soviet KTP-63-based remote-controlled camera system, including switch and control panel. (Credit: Chernobyl Family on YouTube)
When we picture the Chernobyl Nuclear Power Plant disaster and its aftermath, we tend to recall just the commonly shared video recorded by television crews, but the unsung heroes were definitely the robotic cameras that served to keep an eye on not only the stricken reactor itself but also the sites holding contaminated equipment and debris. These camera systems are the subject of a recent video by the [Chernobyl Family] channel on YouTube, as they tear down, as well as plug in these pinnacles of 1980s vidicon-based Soviet engineering.
When the accident occurred at the #4 reactor at the Chernobyl Nuclear Power Plant (ChNPP) in 1986, engineers not only scrambled to find ways to deal with the immediate aftermath but also to monitor and enter radioactive areas without exposing squishy human tissues. This is where the KTP-63 and KTP-64  cameras come into play. One is reminiscent of your typical security camera, while the other is a special model that uses a mirror instead of directly exposing the lens and tube to radiation. As a result, the latter type was quite hardy. Using a central control panel, multiple cameras could be controlled.
When mounted to remotely controlled robots, these cameras were connected to an umbilical cord that gave operators eyes on the site without risking any lives, making these cameras both literally life-savers and providing a solid template for remote-controlled vehicles in future disaster zones.
Editor’s note: Historically, the site was called Чернобыль, which is romanized to Chernobyl, but as a part of Ukraine, it is now Чорнобиль or Chornobyl. Because the disaster and the power plant occurred in 1986, we’ve used the original name Chernobyl here, as does the YouTube channel.
Continue reading “The CCTV Cameras That Recorded The Chernobyl Disaster And Aftermath” →
