UScope: A New Linux Debugger And Not A GDB Shell, Apparently
[Jim Colabro] is a little underwhelmed with the experience of low-level debugging of Linux applications using traditional debuggers such as GDB and LLDB. These programs have been around for a long time, developing alongside Linux and other UNIX-like OSs, and are still solidly in the CLI domain.  Fed up with the lack of data structure support and these tools’ staleness and user experience, [Jim] has created UScope, a new debugger written from scratch with no code from the existing projects.
GBD, in particular, has quite a steep learning curve once you dig into its more advanced features. Many people side-step this learning curve by running GDB within Visual Studio or some other modern IDE, but it is still the same old debugger core at the end of the day. [Jim] gripes that existing debuggers don’t support modern data structures commonly used and have poor customizability. It would be nice, for example, to write a little code, and have the debugger render a data structure graphically to aid visualisation of a problem being investigated. We know that GDB at least can be customised with Python to create application-specific pretty printers, but perhaps [Jim] has bigger plans?
Anyway, Uscope currently supports only C and Zig, but work is in progress to add C++ and Go support, with plans for Rust, Odin and Jai. Time will tell whether they can gather enough interest to really drive development to support the more esoteric languages fully. Still, Rust at least has a strong support base, which might help get other people involved. It looks like early doors for this project, so time will tell whether it gets traction. We’ll certainly be keeping an eye on it in the future!
If you wish to play along at home, you’ll want to start with the GitHub page, read on from there, and maybe join this discord.
If you’re new to debugging on Linux, we’ve got a quick guide to GUI frontends to ease you in. If you’re less interested in code and more of a script junkie, here’s how to debug BASH script or even SED.
8 thoughts on “UScope: A New Linux Debugger And Not A GDB Shell, Apparently
  1. GDB has many front ends which let you use it without ever seeing the terminal window, all through a UI
    I use vscode gdb plugin, its pretty good for the simple features i use (viewing variables, breakpoints, etc)
  2. Pretty similar to what libdebug is doing, but it seems like that uscope is UI-first while libdebug is library-first. Let’s see who gets the other part done first, libdebug with the UI or uscope with a proper scriptable debugging library.
  3. My relationships with debuggers have been always been viewed through my (then) youthful initial debug experiences using the built-in stuff for Borland’s TP and TC, then later the stand-alone Turbo Debugger. I really miss the Turbo Assembly/Turbo Debugger combo. Sigh.
    You kids get off of my dirt.
  4. The bottom line is that if somebody finds investing the effort to do this for anything other than “Not Invented Here” or “personal growth” rather than building on the substantial cross-platform support etc. that’s already in a project like GDB, it suggests that the project has outgrown the ability anybody has to document it and the enthusiasm of existing developers to explain its foundations to an experienced newcomer.
    I wonder where GDB and most of the major development tools will be in ten or twenty years when not just the first but the second generation of authors and maintainers have moved on?
Leave a Reply to Mark Morgan LloydCancel reply
