This Week In Security: Cloudflare Wasn’t DNS, BADAUDIO, And Not A Vuln
You may have noticed that large pieces of the Internet were down on Tuesday. It was a problem at Cloudflare, and for once, it wasn’t DNS. This time it was database management, combined with a safety limit that failed unsafe when exceeded.
Cloudflare’s blog post on the matter has the gritty details. It started with an update to how Cloudflare’s ClickHouse distributed database was responding to queries. A query of system columns was previously only returning data from the default database. As a part of related work, that system was changed so that this query now returned all the databases the given user had access to. In retrospect it seems obvious that this could cause problems, but it wasn’t predicted to cause problems. The result was that a database query to look up bot-management features returned the same features multiple times.
That featurelist is used to feed the Cloudflare bot classification system. That system uses some AI smarts, and runs in the core proxy system. There are actually two versions of the core proxy, and they behaved a bit differently when the featurelist exceeded the 200 item limit. When the older version failed, it classified all traffic as a bot. The real trouble was the newer Rust code. That version of the core proxy threw an error in response, leading to 5XX HTTP errors, and the Internet-wide fallout. Continue reading “This Week In Security: Cloudflare Wasn’t DNS, BADAUDIO, And Not A Vuln”
Remember XBMC? It’s Back!
The original Xbox was different from the consoles that had gone before, in that its hardware shared much with a PC of the day. It was found to be hackable, and one of the most successful projects to take advantage of it was a media centre. You know it as Kodi, but its previous name was XBMC, for Xbox Media Centre. The last version that still ran on an original Xbox saw the light of day in 2016, so it’s definitely a surprise that a new version has appeared.
XBMC version 4.0 brings a host of new features to the venerable platform, including the Estuary user interface that will be familiar to users of more recent Kodi versions, a better games library, and more. The plugin system has been revamped too, and while it retains the Python 2 version from back in the day it’s promised that a Python 3 update is in the works. That’s right, it sounds as though there will be more releases. Get them from the GitHub repository.
We’re not sure how many of you have early Xbox hardware along with the inclination to use it as a media centre, after all Kodi runs so well on a lot of very accessible hardware. But we’re impressed that the developers of this release have managed so much within the confines of a machine with a 2000s-era spec, and have released it at all.
If you’re curious about Xbox hacking, take a look at some of its early history.
Handling Human Waste In The Sky
Have you ever wondered what goes into making it possible to use the restroom at 30,000 feet (10,000 m)? [Jason Torchinsky] at the Autopian recently gave us an interesting look at the history of the loftiest of loos.
The first airline toilets were little more than buckets behind a curtain, but eventually the joys of indoor plumbing took to the skies. Several interim solutions like relief tubes that sent waste out into the wild blue yonder or simple chemical toilets that held waste like a flying porta-potty predated actual flush toilets, however. Then, in the 1980s, commercial aircraft started getting vacuum-driven toilets that reduce the amount of water needed, and thus the weight of the system.
These vacuum-assisted aircraft toilets have PTFE-lined bowls that are rinsed with blue cleaning fluid that helps everything flow down the drain when you flush. The waste and fluid goes into a central waste tank that is emptied into a “honey truck” while at the airport. While “blue ice” falling from the sky happens on occasion, it is rare that the waste tanks leak and drop frozen excrement from the sky, which is a lot better than when the lavatory was a funnel and tube.
The longest ever flight used a much simpler toilet, and given the aerospace industry’s love of 3D printing, maybe a 3D printed toilet is what’s coming to an airplane lavatory near you?
