The famous cuckoo clock, with its moving, chirping mechanical bird indicating various divisions of time, has been around since at least the 1600s. The most famous of them come from the Black Forest area of Germany, and are still being made worldwide even today. Other clocks with different themes take their inspiration from the standard bird-based clocks from history, and thanks to modern 3D printing and other technologies we can make clocks with almost any type of hour indicator we’d like with relative ease like [Jason]’s golf clock.
While the timekeeping mechanism is a fairly standard analog clock, the hour indicator mechanism in this build is a small figure which putts a golf ball into a hole once every hour. It uses an ESP32-C3 at its core, which controls a pair of servos. One controls the miniature golfer, and the other lifts the ball up into position on the green at the appointed time. Once the ball is in place, the figure rotates, striking the ball towards the hole. Although it looks almost like the ball is guided by a magnet of some sort at first glance, the ball naturally finds its way into the hole by the topography of the green alone.
Almost all of the parts in this build are 3D printed, including the green, the golfer, the frame, and a number of the servo components. There’s also a small sensor that detects if the ball has actually made it into the hole and back to the lifting mechanism, and to that end there’s also a number of configurations that can be made in the software to ensure that the servos controlling everything all work together to putt the ball properly.
While not a cuckoo clock in the strict sense, we always appreciate a unique clock around here, but if you demand your clocks have ideological purity we’ll point you to this cuckoo clock built into a wristwatch.
Very clever. Funnily enough this could have been built in the late 19th century with purely mechanical components!
He should have put a old bell underneat the hole so you get a oldschool “ping” when it rings.
Multiple balls for a bit faster hour indication would be easy to add.
Very fun, good job.
Real golf has dragons and seesaws and a windmill that you hit the brightly colored balls through.
“It’s in the hole’”
I’d rather have one of Greg Norman choking at Amen Corner
